Hanging bike on the wall without wheels...any solutions out there?
Old 08-22-18, 03:54 AM
Sito
Sito's Avatar
Bikes: Canyon Aeroad, Votec VRC, Sensa Fermo, Principia R700, Cannondale Bad Boy Ultra, Ciöcc Singlespeed
Quoted: 29 Post(s)
Hi there, not sure this is the best sub-forum for this question but it seemed the best fit, so here we go
I am somehow space-limited in my apartment and need to find a good way to store my spare-bike. There is a piece of wall where I could hang it vertically (front wheel up) but it's a big bike and the saddle will reach too far into the room. So my idea was to hang it up without wheels and store the wheels somewhere else. To do this I'd need some sort of contraption that I can attach the fork and rear dropouts to via quick releases, similar to some inserts I have seen for bike travel bags.
Is anyone aware of such a solution that is wall-mountable and readily available? Otherwise I guess it could be self-fabricated pretty easily but I am not sure what to use for the "axes"...maybe some spare parts from a roof rack?
Any ideas will be much appreciated
Sito is offline
Old 08-22-18, 05:02 AM
Stormsedge
Stormsedge's Avatar
Bikes: 2017 Trek Domane SL6 Disc, 1990 Schwinn Crosscut Frankenroadbike, 2015 KHS Team 29 FS *NEW BIKE*, 2000 Gary Fisher Tassajara--gone but not forgotten
Quoted: 134 Post(s)
Liked 9 Times in 4 Posts
Try searching "bike fork mount" on your browser...may be the solution you are looking for...cheap, just make sure you get the correct size for your bike/axle. If you go this route, be sure to have a grip on your bike before releasing the qr...these mounts are usually used with the bike upright (I've carried mine many miles in my vehicle using these mounts).
Stormsedge is offline
Old 08-22-18, 05:39 AM
SJX426
SJX426's Avatar
Bikes: '72 Motobecane Le Champion(totaled), '73 Bottecchia Giro d'Italia, '83 Colnago Superissimo, '84 Trek 610, '84 Trek 760, '88 Pinarello Tre Cime, '91 Pinarello Montello, '94 Burley Duet, 97 Specialized RockHopper, 2010 Langster, Tern Link D8
Quoted: 468 Post(s)
Find a low cost rear hub with a QR and hang it by the hub with a single hook using the forks to keep it straight on the wall. This will place the saddle higher. I assume you don't have room to hang the frame against the wall, just a narrow open wall.
SJX426 is offline
Old 08-22-18, 05:40 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1734 Post(s)
Liked 47 Times in 34 Posts
There have been wall mounted "hook like arms" that allow the handle bars to be used and the seat becomes the third point contacting the wall. So the crank/BB is facing out. Andy
AndrewRStewart
Andrew R Stewart is online now
Old 08-22-18, 06:48 AM
rm -rf
don't try this at home.
rm -rf's Avatar
Quoted: 623 Post(s)
Liked 14 Times in 13 Posts
Is your wall space too narrow to hang the bike along the wall?
Like this:
That's a lot easier than trying to clamp both dropouts. The downside is the the oily chainring is facing out.
With dropout clamps, the rear dropout would have to be extended from the wall so that the chainring doesn't touch the wall. It would be a little difficult to hold the frame up and tighten one of the clamps at the same time.
THIS: Perhaps each clamp could be mounted to a piece of wood, then the top clamp's wood base would be set on wall hooks, like those available for garden tools. That sounds easier!
To hang by handlebars & saddle:
A pair of these hardware store hooks mounted on a board. Hang by the bars, with the saddle against the wall. (Bike specific wall hangers are for top tubes, extending out from the wall. That wouldn't work as well.)
rm -rf is offline
Old 08-23-18, 12:26 PM
Sito
Sito's Avatar
Quoted: 29 Post(s)
Thanks, I've got something very similar to your picture already for bike 1 and 2. Bike 3 is the problem Can't hang it the same way, the space is very narrow. I like the idea of hanging the bike by the handlebar but I don't like the chain and chainrings facing outwards...I guess I could cover them with something but that might look a little weird....the bike fork mounts look good, I guess that could be worth a try. I'll report back when I've built something Thanks again, everybody!
Like this:
Sito is offline
Old 08-23-18, 12:41 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 215 Times in 179 Posts
Put a hub in rear, keep the chain from dangling.. Pedros has a widget to function that way too.
these look good ; https://cycloc.com/ps/
fietsbob is offline
Old 08-23-18, 01:01 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1639 Post(s)
Liked 60 Times in 51 Posts
Or ... Two metal shelf brackets and some pipe insulation. $12 (I'm guessing) at Home Depot. Find two adjacent studs, screw in the brackets with lag screws, fit the insulation over the bracket arms and just hang the bike by the top tube. (If you have exposed brake cable that run along the bottom of the top tube, you may want to put some electrical or packing tape on the tube in that area. I hate thos1e exposed cables.)
Ben
79pmooney is offline
Old 08-23-18, 09:19 PM
Le Mechanic
Le Mechanic's Avatar
Bikes: Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 46 Post(s)
Liked 9 Times in 9 Posts
I just moved into an apartment and needed a way to store my bikes indoors without drilling holes in the walls. I built this one with 3 - 2x4's. It's been working great so far!
Le Mechanic is offline
Old 08-24-18, 09:13 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 2207 Post(s)
Liked 32 Times in 30 Posts
What happens if you hang from the ceiling and run something (hook) to hang bike from the headtube? might need a extension or two from the wall to keep bike from spinning to left or right (eg. longer shelf brackets?)
Sy Reene is offline
Old 08-24-18, 02:18 PM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2028 Post(s)
Liked 98 Times in 81 Posts
Could you install a hook high on the wall, remove the wheels, and hang it by the rear triangle, near the dropouts? That's how I store my spare frames, and would get the saddle out of the way if you leave it installed.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 08-25-18, 07:07 AM
Glenn6870
Bikes: 2017 Giant Contend SL2 Disc; 1997 Trek Singletrack
It wouldn’t be cheap, but here is what i was thinking. You know the Pro Mechanic bike stands that you put the bike on without the wheels? Somehow remove the part that holds the bike and mount that to the wall vertically. That way the bike would hang from the front dropouts and the BB would be supported by the stand against the wall.
Not sure these stands come apart like that, and no idea how you would mount it, but just figured i’d throw it out there for an idea.
Hopefully you know the kind of bike stand i’m Talking about, i tried to post a URL, but i don’t have 10 posts yet.
Glenn6870 is offline
Old 08-26-18, 12:55 PM
Sito
Sito's Avatar
Quoted: 29 Post(s)
HI, thanks, yes, I know what you mean, but, yes, was hoping for a more economical solution I think I can fashion something similar out of the fork mount mentioned above pretty easily (hopefully)
Sito is offline
Old 08-26-18, 01:25 PM
Crandall
My local Harbor Frieght has rubberized screw in hooks for hanging stuff in the garage. There’s all sizes and shapes. Should be perfect for what your doing. On the cheep too!
Crandall is offline
Glyndwr
Classic & Vintage
14
05-22-14 09:04 AM
stien
Classic & Vintage
4
11-10-10 07:35 AM
mccainphn
Road Cycling
13
06-06-10 12:20 PM
B + M
Utility Cycling
35
03-25-08 08:41 PM
Evilbee
Mountain Biking
2
10-19-07 07:38 PM
