50/19 gear ratio
Old 11-10-18, 03:30 PM
2wheelcyclone
Quoted: 5 Post(s)
50/19 gear ratio
I just bought a used fixie and it has a 50t crank and 19t on the axle. Iím trying to figure the ratio and if I should change it. I live in a hilly area and most hills I can climb with some effort but I can climb them. I canít do a skid stop but it does have 700x45c xc tires on it right now. I have some 700x23c laying around Iím going to see if they will fit tomorrow. Can anyone tell me the gear ratio or if I would be better with a 44/16
2wheelcyclone is offline
Old 11-10-18, 03:52 PM
prathmann
Quoted: 657 Post(s)
The ratio of 50t/19t is 2.63 while the 44t/16t ratio is 2.75, i.e. slightly higher. So it would be a little harder to climb hills with the 44t & 16t gears. If you want to make it easier to climb steep hills then either swap the 50t ring for one with fewer teeth or use a cog with more than 19 teeth.
prathmann is offline
Old 11-10-18, 04:51 PM
seamuis
aire dŪthrub
seamuis's Avatar
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Cielo Sportif Classic, Mercian Vincitore Speciale
Quoted: 241 Post(s)
Liked 35 Times in 22 Posts
seamuis is offline
Old 11-10-18, 11:07 PM
seau grateau
seau grateau's Avatar
Bikes: Litespeed, IRO
Quoted: 1172 Post(s)
Liked 97 Times in 51 Posts
It will definitely be easier to push with skinnier tires. I'd go for 25s over 23s but if you already have them laying around, might as well.
seau grateau is offline
Old 11-11-18, 03:15 AM
Mikefule
Quoted: 35 Post(s)
Liked 5 Times in 3 Posts
Your effective gear needs to take into account chainring teeth, sprocket teeth, wheel diameter and, theoretically, crank length — although bicyclists usually use a fairly standard crank length.
The wheel diameter can be ignored only if you are certain that everyone is talking about the same diameter wheels. When 700c was universal, this was OK. Now that 29 inch, 26 inch and 650b wheel sizes are also common it has become more important.
The calculation is
Chain ring teeth, divided by sprocket teeth, multiplied by wheel diameter in inches.
That gives you a gear size in "inches" which is the theoretical equivalent size of the front wheel if you were riding an "ordinary bike" which is what they used to call penny farthings. Ordinaries had direct drive with no gearing, and the gear inches idea was to enable people to compare the later "safety bicycles' (the earliest bikes we would recognise as "bikes") with ordinaries.
So, 50/19 x 28 would produce a gear of 73.7 inches. (A 700c road tyre is roughly 28 inches diameter.)
For comparison, I ride 49/20 or 49/18 giving me choices of 68.6 or 76.2 inches. I'm 55 and not as fit as I was and I can ride either of these comfortably on rolling country lanes and up all of our local hills, such as they are. Your gear sounds "not unreasonable".
Mikefule is offline
Old 11-11-18, 04:49 AM
seamuis
aire dŪthrub
seamuis's Avatar
Quoted: 241 Post(s)
Originally Posted by Mikefule View Post
Your effective gear needs to take into account chainring teeth, sprocket teeth, wheel diameter and, theoretically, crank length ó although bicyclists usually use a fairly standard crank length.
The calculation is
or you can just go to BikeCalc.com - Fixed Gear Calculator
seamuis is offline
Old 11-11-18, 08:02 AM
Mikefule
Quoted: 35 Post(s)
Originally Posted by seamuis View Post
Yes indeed, you can, but being able to understand and work something out for yourself is always better than relying on a 3rd party that may not be available when you need it.
Mikefule is offline
Old 11-11-18, 08:37 AM
seamuis
aire dŪthrub
seamuis's Avatar
Quoted: 241 Post(s)
I agree, but we donít know if the OP wants to learn. Especially given the premise of the question. I applaud the time you put in to explain it all out, Iím just not sure it was worth it. I could be wrong though, so Iím not pissing on your effort.
seamuis is offline
Old 11-11-18, 07:49 PM
2wheelcyclone
Quoted: 5 Post(s)
Thanks for all the replies! Great info and yes Iím trying to lean all about the gearing. I put 25 on rear and 23 on front today and I like it. Iíll be playing around, I have a 16t rear and a few chainrings.
Gluteus
Road Cycling
31
12-26-08 09:44 AM
DM31
Professional Cycling For the Fans
0
07-03-08 09:51 PM
barry.cohen
Tandem Cycling
0
06-28-08 09:41 PM
eric von zipper
Southeast
0
06-18-08 07:41 PM
Fredo0709
Road Cycling
7
06-04-08 12:08 PM
