Why does bicycle industry do tire pumps backward?
Old 12-06-18, 05:58 AM
JonathanGennick
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 636 Post(s)
Liked 4 Times in 3 Posts
Every non-cyclist who borrows my pump is confused at first because of expecting the normal behavior seen in these videos:
Example 1: youtu.be/MtgVwSlsHkE?t=111
Example 2: youtu.be/lLDCU221YoQ?t=150
Pushing the lever down to lock the chuck onto the valve stem is the behavior I grew up with in the '60s and '70s. Every tire pump I ever used until I got back into cycling in the 2000s operated by pushing the lever down to lock the chuck in place.
When did the bike industry decided to be backward? Why did the standard change? Why do we pull up today instead of pushing the lever down?
JonathanGennick is offline
Old 12-06-18, 06:09 AM
sweeks
sweeks's Avatar
Bikes: Airborne "Carpe Diem", Trek 6000, Strida 2, Dahon "Helios XL", Dahon "Mu XL", Tern "Verge S11i"
Quoted: 512 Post(s)
Liked 12 Times in 11 Posts
I'll suggest that the pump head is more compact with the lever down. On a bicycle, when the pump is not in use this could be preferred for esthetics, packing purposes or (who knows?) aerodynamics. That's all I got. :-)
sweeks is offline
Old 12-06-18, 06:35 AM
prathmann
Quoted: 657 Post(s)
Agreed. Having the lever sticking out would also make it more likely to snag on things.
prathmann is offline
Old 12-06-18, 06:36 AM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 3912 Post(s)
Liked 61 Times in 46 Posts
Just get a Silca head like this. Problem solved.
LesterOfPuppets is online now
Old 12-06-18, 06:47 AM
JonathanGennick
Quoted: 636 Post(s)
That makes logical sense, actually. I can see where that might have begun with frame pumps and spread to floor pumps.
Old 12-06-18, 06:51 AM
Marcus_Ti
Frozen Solid.
Marcus_Ti's Avatar
Quoted: 1930 Post(s)
Liked 59 Times in 39 Posts
My only guess is that with presta valves the user puts less stress on the valve-stem lifting a lever than pushing it....and pump makers did not realize it until recently?
Presta has been around for almost 100 years now IIRC.
Marcus_Ti is online now
Old 12-06-18, 07:29 AM
prathmann
Quoted: 657 Post(s)
Yes, the first bike thumb-lock I remember was on the original Zefal HP framepump back around '75.
Old 12-06-18, 08:08 AM
GeezyRider
GeezyRider's Avatar
Bikes: 1974 Fuji Special Road Racer, 1980 Dawes Lightning, 1989 Trek 420, 1992 Trek 5200, Catrike Trail, Mercier SC1, Giant Iguana
Quoted: 11 Post(s)
Liked 3 Times in 3 Posts
Perhaps with newer aero rims there is less chance of pushing the tube valve into the rim when pulling the lever opposed to pushing on it? Presta valve nuts would prevent this but I don't use them.
GeezyRider is offline
Old 12-06-18, 08:11 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara/Centurion Ironman, '18 Diamondback Syncr, '18 handmade steel roadbike
Quoted: 2968 Post(s)
Liked 149 Times in 105 Posts
My main pump is something called 'Ironhorse' that I bought for $10 about 8 years ago. Its fast, accurate, has taken a beating for years(kids), and better than pumps I use that cost 6x more.
The only odd thing is that to lock the head on, you push down, so reverse of all other pumps.
mstateglfr is offline
Old 12-06-18, 08:21 AM
BobbyG
BobbyG's Avatar
Bikes: 2015 Charge Plug, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 814 Post(s)
Liked 94 Times in 53 Posts
Either beats a cheap plastic thumb-wheel that used to be more prevalent on cheap frame pumps.
BobbyG is offline
Old 12-06-18, 10:31 AM
Ogsarg
Bikes: 2009 Specialized Roubaix, early 90's Giant Iguana
Quoted: 254 Post(s)
Liked 39 Times in 24 Posts
My guess (and its just a guess) would be that you lose less air during release of the chuck by putting it down as opposed to lifting it up.
Ogsarg is offline
Old 12-06-18, 11:18 AM
coffeesnob
coffeesnob's Avatar
Bikes: Trek DS 8.3 - cannondale M500
Quoted: 2418 Post(s)
pumps we had back then had valves that screwed onto the valve stem. Had to unscrew them fast so it wouldn't let air out
coffeesnob is offline
Old 12-06-18, 01:38 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 217 Times in 180 Posts
I got some 90 degree Schrader valve extenders *,
To more easily top up the tires on my bike trailer,
which has 12.5" tires ..
On trucks with dual wheels there are even longer ones to inflate the inside tire..
fietsbob is offline
Old 12-06-18, 02:12 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Old 12-06-18, 02:31 PM
Mansram01
Mansram01's Avatar
Bikes: '17 Trek Emonda, '16 Yeti ASR5, '08 Orbea Orca. Wife's: Felt FW35.
This is great! Just ordered a pair. More for other reasons than the bike. LOL.
Mansram01 is offline
Old 12-06-18, 02:56 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
they include their own valve core too.. so can go on presta to schrader adapters....
fietsbob is offline
solbrothers
Classic & Vintage
12
11-22-11 08:18 PM
EddyR
Classic & Vintage
2
07-27-11 08:17 PM
nycphotography
Road Cycling
4
06-01-09 03:58 PM
ModoVincere
Foo
25
12-08-08 11:41 AM
2packaday?
General Cycling Discussion
3
10-15-07 09:02 AM
