Making your own brake mount holes?
Old 12-29-18, 08:46 PM
FaithsAngel
So I had bought a used bmx bike and it doesn't have break mounts on it and wanted to try and see if i could put breaks on it because using the bike going downhill for about 2 miles to get anywhere isn't safe at all. I need help here and if anyone would be willing to help I would really appreciate it. Here are the specs of the frame itself to give perspective:
  • Head Tube: 75.5
  • Seat Tube: 70
  • Rear End: 12.8" - 13.1" ( centred )
  • Stand over Height: 9"
  • Weight: 5 lbs 4.4 oz
The name of the frame is called the Stranger Ballast frame. It is a 20' wheel setup. Any tips?
FaithsAngel is offline
Old 12-29-18, 09:45 PM
prathmann
Quoted: 657 Post(s)
  • Head Tube: 75.5
  • Seat Tube: 70
In addition to those specs, the company website description says:
"The Ballast Frame is made from heat-treated 4130 chromoly and features an integrated headtube drilled for gyro tabs, top and downtube gussets, ... removable brake mounts, ..."
So if the brake mounts have been removed it might be possible to contact them and get a replacement.
prathmann is offline
Old 12-29-18, 10:04 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1732 Post(s)
Liked 45 Times in 32 Posts
First if the courts come calling I didn't say you should do this...
There's no real difference between a factory produced hole and a consumer one if both are aware of basic fabrication issues. For both the fork and the rear it's about placement WRT the amount of material around the hole to still deal with the stresses.
The rear is usually pretty straight forward. Does the frame have a brake bridge between the seat stays? If so and if it's distance from the rim allows an available caliper to reach then drilling a hole in the bridge's middle is the route. Check the caliper's mounting bolt diameter for the proper final dhole's size. It should be at least half, or less, of the bridge's diameter for safe strength of the remaining bridge material. One will want to deburr the hole best possible and dab some paint of the raw metal for corrosion protection. One problem with mounting a caliper to this cross tube (the bridge) is keeping the bridge from crushing with the tightening of the mounting bolt/nut. There are special washers that have a curved and a flat face to cup the tube better with, sometimes these come with the brake caliper.
For the fork the idea is the same but the fork does see much higher stresses so more thought is needed. Generally on a BMX bike the fork is a unicrown one with about a bottom to crown race seat, of the steer/blade welded area, of around 1.25" or more. You want the brake bolt hole below the weld bead best possible but still about 3/8 to 1/2" above the very bottom of the steerer. If your fork is different is design of dimension you better give us photos and numbers... Again checking that the hole's placement will allow an available caliper to reach the rim. Again deburring the hole and dabbing paint of raw metal.
When drilling either hole it's best to create a dimple in the surface with what's called a center punch (look it up). This will help keep the drill bit from "walking" away from the point you want the hole to be at. Start with a small bit, like a 1/8". Then work up to the final diameter in a couple of steps. If the initial small hole is slightly off you can drift the next step drilling over with a bit of care. For the rear you can really only drill from one side so keeping the drill perpendicular to the stays, or at a tangent to the rim, is important to keep the caliper well placed. For the fork you can drill the small pilot hole on each side first then drill through both holes from the front after.
Before you do anything that's not reversible do your homework and measure a few times. You might want to look at bikes with caliper brakes already installed to get the big picture first. Good luck. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 12-29-18, 10:06 PM
Andrew R Stewart
Seeing prathmann's post now- Of course you should seek out the OEM method as a first choice. Andy
AndrewRStewart
Old 12-30-18, 11:20 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6833 Post(s)
Liked 214 Times in 178 Posts
Of course wheels with hub brakes is another option ... drum brakes have proven themselves reliable , in my experience.. ..
BMX bikes are generally unsuitable for longer rides , since your saddle is so low *, you always are standing to pedal ..
* for stunts and jumps..
fietsbob is offline
PaddleShifter
Road Cycling
14
06-05-15 05:32 AM
swak
Road Cycling
1
11-15-09 05:41 PM
thirtyminbreak
Road Cycling
7
06-23-08 07:28 PM
Terrago
General Cycling Discussion
2
02-25-03 08:03 AM
