Squealing disc brakes when wet - normal?
Old 12-30-18, 04:21 PM
NoWhammies
NoWhammies's Avatar
Bikes: Argon 18 Gallium, BH G7
Quoted: 341 Post(s)
Liked 31 Times in 25 Posts
Had my bike out in the rain/wet roads for the first time. After riding the bike all summer, the disc breaks were quiet when stopping. Today though when the brakes were applied the squeal was pretty damn loud. I'm sure the cars around me knew I was stopping, that's for sure.
Just curious to know if this is normal behaviour for wet disc brakes. Thank you.
NoWhammies is offline
Old 12-30-18, 04:49 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6839 Post(s)
Liked 217 Times in 180 Posts
No specifics? what brake caliper, what pads? rigid steel fork? Or what ?
Anecdotal .02 My BB7 with Kool Stop organic compound replacement pads were quiet in the rain, Avid stock were not. wet or dry..
I don't ride very fast or far in the winter, like you in the big city probably do .. so Id just live with it..I replaced my BB7 with TRP HyRd, Only the front squeals when its wet
Might try an organic compound pad on the front, they use a Shimano Deore style pad , Koolstop does not make one in that shape..
J&B has a couple in their stock list ..
fietsbob is offline
Old 12-30-18, 06:32 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1734 Post(s)
Liked 47 Times in 34 Posts
Sometimes yes. What kind of pads? Have you done any cleaning yet? Andy
AndrewRStewart
Andrew R Stewart is offline
Old 12-30-18, 06:57 PM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 70 Post(s)
Liked 6 Times in 5 Posts
My front is annoyingly bad but the rear only squeals when it feels like it. Sometimes it does, and most times it doesn't. Sorry, I'm no help.
Bigbus is offline
Old 12-30-18, 07:01 PM
spdntrxi
Bikes: Parlee,BMC,Specialized and Trek
Quoted: 105 Post(s)
most of the times yes.... mine make noise at first then tend to quiet down with more use.
spdntrxi is offline
Old 12-31-18, 01:07 PM
NoWhammies
NoWhammies's Avatar
Quoted: 341 Post(s)
Standard Shimano pads. And yes. I cleaned both the front and rear pads the day before.
Old 12-31-18, 02:48 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
If semi metallic, consider Organic compound pads as a test ..
fietsbob is offline
Old 01-01-19, 10:23 AM
JonathanGennick
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 637 Post(s)
Liked 4 Times in 3 Posts
FWIW, I avoid cleaning and leave well enough alone when my brakes are quiet. That said, I've seen wet weather and even just riding through mud lead to squealing brakes.
Is the squeal continuing? Or have they quieted down?
JonathanGennick is offline
Old 01-01-19, 02:42 PM
NoWhammies
NoWhammies's Avatar
Quoted: 341 Post(s)
@JonathanGennick I've had good luck cleaning the pads on my bike throughout the summer. The bake dust, etc. Normally in the summer the squeal goes away after one or two stops. But the advice to leave well enough alone is good advice. I'm always worried I'm going to make things worse off, or do something I have no clue about.
I haven't been out on my bike since, so I can't comment on if they have quieted down or not. I hope to get out for a spin later today so we'll see.
Old 01-17-19, 04:27 PM
Lars Halstrom
Lars Halstrom's Avatar
Quoted: 13 Post(s)
Liked 3 Times in 1 Post
Since you live on the coast, your rainwater contains salt. Don't forget to rinse them off when you get home. If you clean the rotors, you remove the bedding in material rubbed off from your brake pads. You'll have to re-bed the brakes again. What I do is find a long downhill and ride down it and squeeze the brakes until you're almost stopped and then release the brakes. Do this about 15-20 times as you go down the hill. Avoid coming to a complete stop during these braking intervals because this will leave an uneven surface of brake pad material. Riding on the road in the rain your tires can pick up oil fluids from cars and trucks. This will make your brakes squeal as well. You should clean off the rotors with alcohol and the brake pad surfaces. Then re-bed the brakes all over again.
Lars
Seattle
Lars Halstrom is offline
Old 01-17-19, 05:42 PM
delbiker1
delbiker1's Avatar
Bikes: 1991 Ochsner steel frame, 2002 Airborne Zeppelin titanium, Schwinn DBX SS aluminum, Orbea MD 40 carbon fiber
Quoted: 188 Post(s)
Liked 40 Times in 32 Posts
I have Avid mechanical disc brakes and they do squeal when wet, but less so when they are dripping wet. The front is much noisier. I have never cleaned the pads or the rotors. I am going to get new pads/rotors soon as they have had a lot of use and have lost some stopping power,
delbiker1 is offline
Old 01-17-19, 06:06 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
My BB7 with Kool Stop Organic compound pads were OK , in the wet, at my slow speeds..
fietsbob is offline
Old 01-19-19, 09:32 AM
Glenn6870
Bikes: 2017 Giant Contend SL2 Disc; 1997 Trek Singletrack
IMO, it’s normal. When i ride in the rain, the next time out, it sounds like i’m Skinning a cat every time i hit the brakes. It goes away after a few stops and it’s back to normal. so on the surface, I would say you have no issues. If it persists after you ride, then something may be wrong. But i wouldn’t do anything short term.
Glenn6870 is offline
Old 01-19-19, 10:49 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3609 Post(s)
Liked 168 Times in 125 Posts
^^^ Pretty much this. Every type of caliper I've ever used, with every pad compound, has honked like a goose when riding in the rain. I consider it a feature, not a bug. People notice.
Absolutely no need to change anything. If the brakes were quiet when dry, they'll be quiet again.
DrIsotope is offline
Old 01-19-19, 11:53 AM
NoWhammies
NoWhammies's Avatar
Quoted: 341 Post(s)
Thanks folks. I haven't been out on my bike since this post. I keep waiting for a good day to get a ride in. With some luck that will happen this weekend. Ideally the roads will be dry and I can a full inspection of the whole braking process.
Old 01-19-19, 04:01 PM
wipekitty
vespertine member
wipekitty's Avatar
Bikes: Yes
Quoted: 571 Post(s)
Liked 71 Times in 53 Posts
Squealing disc brakes in the rain are common, in my experience.
I was on a group gravel ride in the rain one time, and with ruts and random washouts, the descents got pretty loud!
wipekitty is offline
Old 01-19-19, 09:36 PM
Slightspeed
Slightspeed's Avatar
Quoted: 494 Post(s)
Liked 78 Times in 57 Posts
Mine do, too. Squeal when it rains, but not as much as I do. 😂
Slightspeed is offline
Old 01-20-19, 09:42 PM
NoWhammies
NoWhammies's Avatar
Quoted: 341 Post(s)
I don't know why, but I just assumed disc brakes would be silent in the rain. Glad to hear that my bike/brakes making noise mean I'm not the only one.
speedevil
Classic & Vintage
26
01-24-19 12:50 PM
WPeabody
Advocacy & Safety
32
06-06-12 10:59 AM
GuitarWizard
Northeast
2
03-13-07 04:32 AM
