Go Back  Bike Forums > Bike Forums > Fatbikes
Finally found a tire
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 02-14-19, 11:14 PM
MarcusT
MarcusT's Avatar
Quoted: 284 Post(s)
Liked 13 Times in 12 Posts
So, my fat bike is a no name chinese made frame with a decent component set. Anyway, It came with the CST BFT 26" X 4" tires. Basically, one of the cheapest tires on the market. They are not bad, but I get a thorn puncture half the times I go out. When I was ready to replace the tires, I wanted to go with the Schwalbe Jumbo Jims. Had to order online, when they came in, mounted, put on the bike and... the knobs were hitting the chain stay. It seems that my bike can fit at a max a tire width of 4" (104mm) and the Jims with the knobs were wider than that. So, I spent the last 6 months trying to find a tire that would fit, meanwhile patching tubes after rides.
Finally, found the Surly Knard 26" X 3.8". With fingers crossed, Ordered. They just came in, mounted and........they fit perfect!
Quite the relief, as I was seriously considering buying a new fatty if these tires did not work out
MarcusT is offline
Old 03-24-19, 07:48 AM
MarcusT
MarcusT's Avatar
Quoted: 284 Post(s)
To continue: I was able to take the Surly tires out for a ride, went with a friend who has a 29er MTB.
I can say the the Knards are 10 times better than my old tires. With the old tires, going uphill was like pushing a wheel barrow uphill, and I detested anything with an incline. The Surlys were so cooperative I was able to keep up with the MTB on the up and was passing him on the down hills without pedaling.
Great tire!
MarcusT is offline
Old 03-29-19, 12:40 AM
taz777
taz777's Avatar
Bikes: 5
Liked 12 Times in 10 Posts
What tyre pressures were you using for the original tyres, and is it different to the pressures you’re using for the new tyres?
I’m just surprised that you were getting so many punctures. Did you check the inside of the old tyres to ensure that nothing sharp was felt?
taz777 is offline
Old 05-20-19, 06:48 AM
iCollector
try the big Knards.... awesome!
iCollector is offline
Old 05-20-19, 09:58 PM
MarcusT
MarcusT's Avatar
Quoted: 284 Post(s)
Originally Posted by taz777 View Post
What tyre pressures were you using for the original tyres, and is it different to the pressures youíre using for the new tyres?
Iím just surprised that you were getting so many punctures. Did you check the inside of the old tyres to ensure that nothing sharp was felt?
The old tires are the cheapest you can find: CST BFT. It was a new puncture every time. I ride pressure from 8 to 15psi. Some tires were just not meant to resist thorns
MarcusT is offline
spectastic
Bicycle Mechanics
4
07-05-19 06:39 PM
superduper54
Singlespeed & Fixed Gear
8
07-03-09 01:48 PM
alwaysbefirst
Road Cycling
1
07-25-05 03:26 PM
