Fazua Evation
Fazua Evation
Old 04-02-19, 04:25 AM
Auldian
Fazua Evation
I only had my Focus Paralane2 for a few days but have had issues already. Have any users of the Fazua system had any problems with the following.
Breakage of the battery/motor securing lock - not the key style but the simple button recessed into the downtube. Mine broke - piece of plastic inside the lock broke leaving the button loose and sticking out of the frame - luckily the motor unit stayed in place.
Also has anyone experienced the motor coming on and going off rapidly when pedalling up steep hills at low cadence (feels like the clutch is engaging then disengaging). Is this normal?
Any other tips from users who have been using the Fazua system for a while would be useful.
Cheers.
Auldian is offline
Old 04-04-19, 01:20 PM
tegnamo
Quoted: 27 Post(s)
Can you post a photo of the broken part? I think the eject button on the down tube can be removed actually, if you just pull on it gently.
tegnamo is offline
Old 04-04-19, 04:14 PM
Auldian
Unable to send photo as bike in dealer to replace part (under warranty I hope !). I realise the button can be removed (this needs to be done to access the adjuster screw used to set the line of the battery case to the frame), but what’s happened to my bike is that the plastic bridge into which that screw is screwed, has broken away from the main body of the lock assembly, leaving the button and its surrounding bezel free to move out of the frame courtesy of the spring. My query about anyone else having similar problems was to gauge if this is a inferior part which will be prone to breaking.
Are you able to help me with the “phasing” action of the motor?
Auldian is offline
Old 04-04-19, 04:56 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6833 Post(s)
Liked 214 Times in 178 Posts
https://fazua.com/en/
fietsbob is offline
Old 04-05-19, 09:23 AM
tegnamo
Quoted: 27 Post(s)
Not sure about your phasing issue unfortunately. Hopefully your dealer can find out.
tegnamo is offline
Old 04-13-19, 01:21 PM
marcomilani@blu
I have a Pinarello Nytro (Fazua motor) and I am experiencing exactly the "phasing" issue that you have described. I contacted more than one dealer and they promised to get an answer from Fazua but so far no solutions have been provided. I have been told that the issue is a software one as it is enough to change the sensitivity of the pedal pressure sensor. I tried to enter the Fazua software system (Evation service Toolbox) but I could not find any available options. I hate this issue and I am therefore not using the bike.
marcomilani@blu is offline
Old 04-14-19, 07:03 AM
Auldian
marcomilani@blu sounds like we have the same issue. My firmware is up to date. I assume yours is too. The only extra you get with the dealer Service Toolkit, over the one end users like you and I have access to, appears to be a Calibration Function. This allows the %'s of assisted power delivered at Breeze, River and Rocket to be altered to suit a riders needs, and also to re-calibrate the torque (and possible Cadence) sensors following removal and replacement of the crank arms and chainring spider. I don't think the Calibration facility can alter anything to do with pedal pressure (torque) sensor. Think I agree that it something Fazua has to adjust with a firmware update, assuming of course they are aware some end users are experiencing such a problem! I find the issue is most noticable when cycling uphill in a group where the cadence and speeds can go up and down a lot as other riders get tired or change gears or get out of the saddle and temporarily slow. On a standard bike the micro adjustments to avoid collisions are made seamlessly. Those same adjustments the Fazua system just isn't happy with. Riding on the front of the group, or indeed away from the group is the only way I have found to counter this.
Auldian is offline
Old 04-14-19, 07:16 AM
Auldian
I did a 87mile ride yesterday with over 3500 ft of climbing and the back half of the ride into a 18mph headwind. The average speed was 16.5mph so a lot of the ride was done with no assistance. Careful use of the motor (only on the hills) allowed the battery to last the whole way (it went totally flat yards from my house). I have to say that apart from the climbs the rest of the ride was far from enjoyable especially the 30+ miles into the headwind with no motor assist (rolling terrain and battery switch off to conserve power for climbs at end of the ride). With the aerodynamics of a brick and the 15kg weight (bottles cameras saddle bag etc) the windward leg was made all the more difficult, in fact bloody hard. Got the Paralane2 to help me stay with my club mates on our normal 60 - 80 mile rides, but I think I will have to reevaluate the benefits of an eBike for this sort of use. For someone who is prepared to ride 30 miles or so within the 25kph EU legal limit, and enjoy the feel of a drop bar road bike, these are perfect. Perhaps need to wait till the overall weight comes down and the battery life increases to make it a viable option for a dedicated club cyclist with health issues.
Auldian is offline
Old 04-14-19, 10:23 PM
marcomilani@blu
I completely share your view. The only difference is that, for long rides, I carry a spare battery in my backpack. What
is noticeable, though, is that I have also a Bianchi Impulso e-road with a Polini motor, which does't suffer at all from such a problem.
Old 05-18-19, 02:16 PM
PhilipB
Motor cut out at low cadence on steep climb
I have a Cube Agree Hybrid purchased a week ago with the Fazua Evation system and have the same problem with motor stopping and then starting on steep climbs at low cadence. Have contacted Fazua with regard to this problem and will keep forum posted if any positive information received. I bought this bike to climb a steep hill home! Not suitable!
PhilipB is offline
Old 05-20-19, 09:28 AM
PhilipB
Received a quick response from Fazua :-
"Thank you for your e-mail and your interest in our e-bike motor system.
As you describe it i assume as well too low cadence as the root cause.
As the optimal support depends on the cadence and torque. Hereby we demand from our drivers a round kick and constant pedal pressure,
just to get the optimal support from our system. Should an irregular kick or not even pedal pressure take place, in exceptional cases, it may be that the system feels that it is losing performance or support."
It seems down to low cadence and not having a smooth pedal stroke! Have arranged to take to dealer to have software checked,
PhilipB is offline
Likes For PhilipB:
Old 05-26-19, 11:10 PM
marcomilani@blu
I contacted Fazua too. They were very cooperative. I described the issue on a phone call and finally they offered to remotely connect to my bike via my computer. They checked everything and everything, unfortunately, was ok. No solution, for the moment. The day after I bought a Bianchi Aria e-road (Ebikemotion X35 motor in the rear hub) and traded in my Pinarello. The Bianchi works very well. It is a pity, though, as I liked the Pinarello a lot.
Old 05-27-19, 09:09 AM
Auldian
marcpmillani@blu is it the carbon Aria you got? Is it the same weight or lighter? Any other comparisons you could give on the Ebikemotion system would be useful.
Auldian is offline
Old 05-30-19, 12:19 AM
marcomilani@blu
Yes, it's the carbon model. The bike, according to my scale, is 12 kg with motor and battery but no pedals. On the same scale the Pinarello was 13.6 kg. The impression is that the support you get by the motor is very similar in the two bikes. The difference is that, when you release for a moment the pressure on the pedals, the Bianchi motor keeps pushing for a fraction of a second: you don't get stopped on a steep hill and can keep a constant speed. I was concerned about the motor being in the rear hub but I don't actually perceive any difference in comparison with the Fazua. The Bianchi is Shimano and the Pinarello was Sram: both ok. Sram brakes are better and more silent. Both are 55 size but Bianchi is slightly smaller.
Old 05-30-19, 08:16 AM
2old
Quoted: 211 Post(s)
Liked 8 Times in 7 Posts
I've seen the Bianchi, and it's constructed beautifully. Did you install a rear tire with "flat protection". I would be concerned about changing a flat on the road.
2old is offline
Old 05-31-19, 12:36 AM
marcomilani@blu
No, I didn't. I changed the rear tyre in my garage and it was not more difficult than a traditional bike. You just need to carry an 8 mm allen key to loosen the two nuts and disconnect the electric wire plug.
Old 05-31-19, 09:12 AM
2old
Quoted: 211 Post(s)
That's encouraging they made it easy to disconnect the motor. The light motor helps too.
2old is offline
Old 06-01-19, 02:01 AM
marcomilani@blu
Ebikemotion. Something I discovered yesterday. On a flat or very light gradient (1%) if you start pedalling and then you reduce heavily the pedalling frequency, without making any effort, the motor keeps pushing, gaining speed up to the maximum that it can achieve. If you keep moving the pedals it goes ahead, if you stop moving your legs the motor stops. I think it is related to the fact that the system has no sensor on the pedal pressure. Obviously on steeper gradients the motor has not enough power to push the bike without human help.
Old 06-08-19, 10:16 AM
PhilipB
Had another mail from Fazua explaining their system:
"Thank you for your mail and the report. We get this question from time to time and this behavior of the engine is known to us. However, this is not a fault on the engine or the battery.
Our engine works according to the data and values ​​transmitted from the bottom bracket gearbox."
Borrowed another drivepack and did a comparison test - same result, motor 'phasing' on steep long climbs. Can only assume unless Fazua introduce new software nothing will change. 99.5% of time I have no problem and am happy with it. Steep and long climbs - not happy.
PhilipB is offline
RichSPK
Classic & Vintage
26
05-28-16 09:27 AM
Swoop
Bicycle Mechanics
1
04-09-14 07:36 PM
illdthedj
Singlespeed & Fixed Gear
12
02-16-12 01:59 PM
bja86
8
03-14-09 10:44 AM
Artkansas
Fifty Plus (50+)
3
07-24-07 11:18 AM
