Can a 7 Spd Cassette go 6 Spd Bike???
Old 05-01-19, 07:41 AM
allout1
allout1's Avatar
Quoted: 57 Post(s)
My parts bike has the new 7 spd shifter on it, and my current riding bike has the 6 spd cassette and frame.
So what happens when people put their 7 spd wheel and cassette into the 6 spd frame? I could squeeze it in there, but I'm leery that things will wobble out of their fixed stations. This bike takes MTB abuses and usage, so...
allout1 is offline
Old 05-01-19, 08:05 AM
Viich
Hack
Bikes: 88 Bianchi Strada (currently Sturmey'd), 90's Giant Innova (now with drop bars), FMF Race BMX
Quoted: 192 Post(s)
Liked 11 Times in 9 Posts
It depends......
Frame may be built for a narrower OLD (wider hub) for the 6 speed, or it may not. Unlike 8-9-10 speed, which are all the same width cassette with narrower gears, 7 speed is very close to the same spacing and wider.
I guess I should specify that I am assuming Shimano components.
If the OLD (outside locknut distance, the distance between the dropouts with the wheel installed) is the same, you should be able to swap to 7 speed very easily.
MTA: The 6 speed is probably a freewheel, not a cassette (threaded interface vs. splined), the 7 speed could be either but likely a freewheel as well.
Viich is offline
Old 05-01-19, 08:09 AM
_ForceD_
_ForceD_'s Avatar
Bikes: Several...from old junk to new all-carbon.
Quoted: 391 Post(s)
Liked 9 Times in 7 Posts
Also just pointing out that shifting might be FUBAR....indexing will probably be off. You might want to change rear shifter to the friction option.
Dan
_ForceD_ is offline
Old 05-01-19, 08:20 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 630, '79 Peugeot PXN10LE, '83 Fuji America, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 567 Post(s)
Liked 77 Times in 51 Posts
Originally Posted by allout1 View Post
... my current riding bike has the 6 spd cassette and frame.
So, 6-speed Uniglide freehub? Have you removed the lockring and looked at the freehub body? Bolt-on or press fit. These are important things...
If bolt-on type, you can replace the freehub body with a modern Hyperglide replacement. Then, you're good. If press-on type, then you must modify the Hyperglide cog inner tabs to fit over the freehub body.
https://www.sheldonbrown.com/k7.html
^This page should help you.
Phil_gretz is offline
Old 05-01-19, 10:44 AM
Obeast
100% Certified Beast
Quoted: 251 Post(s)
Liked 6 Times in 6 Posts
you need to identify if you have cassette or freehub first (watch park tools cassette type video on youtube) then go from there.
Obeast is offline
Old 05-01-19, 10:51 AM
shelbyfv
shelbyfv's Avatar
Quoted: 1102 Post(s)
Liked 136 Times in 90 Posts
ooooo, together forever! ^
shelbyfv is offline
Likes For shelbyfv:
Old 05-01-19, 11:27 AM
Hiro11
Bikes: To the right: opinions, not facts.
Quoted: 447 Post(s)
Liked 22 Times in 14 Posts
This guy just joined and is posting thread after thread about really strange stuff. A good chain is $25 and will last a while, who asks about a "cheap" chain? Was a six speed cassette ever even made, I thought it was all freewheels back then? What are we talking here anyway, a 35 year old bike? Where exactly does one procure a "new 7 speed shifter"?
Please stop spamming the board.
Hiro11 is offline
Likes For Hiro11:
Old 05-01-19, 08:31 PM
MikeyMK
Cycleway town
MikeyMK's Avatar
Bikes: 2.6kw GT LTS e-tandem, 250w Voodoo, 250w solar recumbent trike, 3-speed shopper, Merlin ol/skl mtb, 80cc Ellswick
Quoted: 403 Post(s)
Liked 50 Times in 43 Posts
New 5,6,7 speed shifters are widely available, as are the cassettes and freewheels. They're almost all compatible as the ratio is common. They also fit almost all bike frames.
To swap an old 6sp set up for a new 7sp set up, simply remove the cassette/freewheel and shifter, and fit brand new ones. Each cost from less than a tenner.
Tip - use 8-speed. It's the sweet-spot of set-ups imo.
MikeyMK is offline
Old 05-05-19, 12:07 PM
allout1
allout1's Avatar
Quoted: 57 Post(s)
Okay, I'll go with this, and start to figure it out. I'll update this as it goes.
allout1 is offline
mycoatl
Touring
11
10-25-06 05:40 PM
concernicus
Singlespeed & Fixed Gear
1
03-02-06 08:28 PM
dirtbikedude
Forum Suggestions & User Assistance
0
06-08-03 11:00 AM
MoshB
BMX
0
03-20-02 12:43 PM
