Seat Post Lock for a Juiced CCX
Recently bought a Juiced CCX
I emailed juiced before my bike arrived and they said seat post is 34.9mm, so i ordered 34.9mm nutfix (largest they have). Doesn't fit: there's no way I can expand it to get it over the frame tube. I tried using the nutfix nut, with existing collar, but it's too wide to tighten all the way down.
I have a suspension seatpost so very eager to protect it for theft. Seem largest that pinhead do is 34.9mm.
Anyone found anything or got any suggestions?
Mark
Mark
Quoted: 882 Post(s)
Liked 821 Times
Did you measure the ID of the new collar and the one that came with the bike? I think there's a chance that the one you received isn't as large as stated.
Cycleway town
How often do you adjust your seat? If it's as never as I do, then try my approach - I use a normal collar, complete with countersunk 5mm slot head bolt, and drilled the bolt slot round with a 6mm drill bit.
If I need to undo it, it's gonna take me 20 seconds to drill the bolt head off. It's worth it, knowing my seat's safe.
Quoted: 77 Post(s)
Pitlock sells just the binder bolt to use with your existing clamp. It may not work with your clamp though if the bolt on the clamp is recessed.
https://www.peterwhitecycles.com/pitlock.php
