Bosch Announces New Motor: Smaller, Lighter, More Efficient
Old 05-27-19, 09:45 PM
radroad
Quoted: 313 Post(s)
Liked 15 Times in 13 Posts
After a long wait and many rumours, here is the new 2020 motor from Bosch.
  • 2.9KG (down from 4KG in the old Performance CX line)
  • Regular chainring (no small sprocket like the outgoing model)
  • New chassis
  • Almost all resistance removed after motor cut off
  • All new 600Wh power tube battery
Spotted first on the French website Le Marché Du Vélo there area also some rumours that Bosch have developed a Bluetooth suspension integration, allowing the rider to change all of the suspension settings via the Bosch Nyon display.
edit: this new system will also have built in anti-theft GPS
https://www.emtbforums.com/here-is-the-new-2020-bosch-motor/
radroad is offline
Likes For radroad:
Old 05-27-19, 10:33 PM
ColonelSanders
ColonelSanders's Avatar
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1242 Post(s)
Liked 14 Times in 12 Posts
Very good.
ColonelSanders is offline
Old 05-28-19, 12:56 AM
2old
Quoted: 211 Post(s)
Liked 8 Times in 7 Posts
Step in the right direction, but it only means the weight of OEM bikes will go from 48 - 58 (or so) pounds to 46 - 56 (or so) pounds.
2old is offline
Old 05-31-19, 01:29 AM
01 CAt Man Do
01 CAt Man Do's Avatar
Bikes: Mountain bike & Hybrid tour bike
Quoted: 170 Post(s)
Liked 3 Times in 3 Posts
Yep, if they could get the whole shebang down to something like 30-35 pounds ( bike, motor, battery and accessories ) , now that would be worth swooning over.
01 CAt Man Do is offline
Likes For 01 CAt Man Do:
Old 05-31-19, 09:28 AM
2old
Quoted: 211 Post(s)
Eventually it will happen. I built a sub 35 pound 2000 GT Zaskar with lots of light parts that I already had (carbon Ritchey fork, titanium seatpost, DT 240 wheels etc) and a 10 pound BBS02, 3.5 pound Luna 52V - 6 ah battery. Will be sub 30 when a lighter DIY mid-drive is available.
2old is offline
Old 06-04-19, 08:54 PM
larrynove
Motor is likely to be lot more efficient than CX combined with 600wh battery, would be close to same range as CX with 700wh battery. Good enough for full day of MTBing without need use eco 90% of time.
A 600wh powerpack maybe bit much to ask for they can't change physical size as needs to be interchangeable with 400 and 500wh versions.
Hopefully there is option adjust power settings via phone app.
Expect there to be Performanceline (63nm) replacement along with 45kmhr speed version.
I'm not expecting much change from current CX 75nm, which is more than enough for most eMTBing and enough to match Shimano E8000 which has been eating into CX market share.
Still large market for current CX drive especially in cargo ebike market which it dominates and entry level MTBs. Saves manufacturers designing expensive new frames.
larrynove is offline
Old 06-04-19, 11:10 PM
maria.owenby
Battery weight is the issue here. And i see companies have vision of making range longer rather than making bikes lighter. So even battery technology progress for certain time we won't see such major weight drops
maria.owenby is offline
Likes For maria.owenby:
Old 06-05-19, 05:39 AM
elainehillrider
Newbie question but is it only for e-mtb or also for electra townie or tern kind of e-bikes too ?
elainehillrider is offline
Old 06-05-19, 09:33 AM
2old
Quoted: 211 Post(s)
We'll need to see what the marketing hype dictates; maybe more companies will go on the "two smaller batteries" bandwagon (use just one for shorter rides, two for longer). My LeBS, Luna Cycle, can't seem to keep their 52V, 6 ah, 3.5 pound batteries in stock. I used one to assemble a light mid-drive.
2old is offline
Old 06-09-19, 01:57 PM
veganbikes
Clark W. Griswold
Bikes: Foundry Chilkoot Ti W/Ultegra Di2, Salsa Timberjack Ti, Cinelli Mash Work RandoCross Fun Time Machine, 1x9 XT Parts Hybrid, Co-Motion Cascadia, Specialized Langster, Pink Klein MTB, Phil Wood VeloXS Frame (w/DA 7400), Cilo Road Frame, Proteus frame
Quoted: 1178 Post(s)
Liked 43 Times in 30 Posts
I wonder when Riese and Muller will do a Supercharger in this configuration with 2 600WH batteries with Rolhoff E-14. That will be the dream for heavy loaded and hilly touring.
veganbikes is offline
Old 06-11-19, 01:35 PM
Bikewolf
Quoted: 112 Post(s)
Good remark. Only for e-mtb as far as I know. Current line-up for city e-biking is still good, IMHO.
Bikewolf is offline
Old 07-03-19, 01:57 AM
AlanK
AlanK's Avatar
Quoted: 36 Post(s)
Exactly. Mid-drive motors typically don't weight that much; it's the battery that ads most of the weight.
As for the Bosch system, to me it seems like they're sort of ripping off Brose. That's not necessarily a bad thing; Brose motors are efficient and function more similarly to conventional bikes. Obviously the new Bosch doesn't have much field testing, so we'll see how it does, but I still prefer Brose since they've employed this approach longer.
AlanK is offline
anuxxer
Bicycle Mechanics
7
09-06-11 06:20 PM
defx
Singlespeed & Fixed Gear
0
05-31-09 08:30 PM
eraven
6
05-17-09 12:04 PM
maddmike
General Cycling Discussion
9
05-22-06 04:20 PM
blue_neon
0
02-11-05 06:45 PM
