Tire width equivalenices: 27" to 700c ?
Old 05-28-19, 10:56 AM
the sci guy
bill nyecycles
the sci guy's Avatar
Quoted: 472 Post(s)
Liked 17 Times in 9 Posts
I used the googles and couldn't find a chart...
I'm wondering what the basic equivalency is for a 27 x 1.25 tire is in 700c width? Like 700x32 or 35?
I've got the 27" wheels on one bike and 700c on another and the 700c one is in the market for new tires and I want to go wider. I did a test fit of the 27" on the other bike (since it originally had 27" wheels) and that width fit the frame, so I'm looking to go about that width or just slightly less in a 700c.
Thanks.
Twitter@theSurlyBiker
Instagram@theSurlyBiker
the sci guy is offline
Old 05-28-19, 11:03 AM
BFisher
Quoted: 48 Post(s)
Liked 31 Times in 27 Posts
27x1 1/4 is usually like 32mm, but of course manufacturer tolerances and rim width play their parts. I believe many, if not all, 27x1 1/4 tires are also marked ISO 630x32.
BFisher is offline
Old 05-28-19, 11:04 AM
malcala622
malcala622's Avatar
Bikes: Bianchi Trofeo/Limited/Giro.Tommasini Prestige. Bottecchia Cromor. Gios Torino. Torelli Strada?
Quoted: 519 Post(s)
Liked 16 Times in 14 Posts
On the bike with 700c rims the biggest/widest tires will depend on how much clearance you have under the brake calipers.
What frameset and brake calipers do you have paired with the 700c wheels?
Personally I build all my wheels with 700x23/25 to ensure clearance.
malcala622 is online now
Old 05-28-19, 11:05 AM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2028 Post(s)
Liked 98 Times in 81 Posts
1-1/4" = 32mm
In a pinch, you can multiply/divide by 25.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 05-28-19, 11:08 AM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1639 Post(s)
Liked 60 Times in 51 Posts
Roughly, 27 x 1 1/4 is going to be 1.25" X 25.4 mm/in = 31.8mm or 32c. Roughly because tire sizes are like shoe sizes. You have to try them on.
Ben
79pmooney is offline
Old 05-28-19, 11:11 AM
the sci guy
bill nyecycles
Quoted: 472 Post(s)
Tektro R559 long reach's on a 1984 Raleigh Sportif. Currently have 700x28 in a Kenda tire.
Tons and tons of pics of the bike on my Instagram.
1-1/4" = 32mm
Perfect, thanks. Thinking of getting some Panaracer Pasaleas in a 700x32 gumwall then.
Old 05-28-19, 11:14 AM
Kabuki12
Kabuki12's Avatar
Bikes: 1973 Windsor Profesional,1976 Kabuki diamond formula with full Campy, 1977 Raleigh Competition GS , 1971 Stella original Campy equip. 1978 Raleigh Super Grand Prix, 1972 Italvega Gran Rally ,1972 Super Mondia Special
Quoted: 96 Post(s)
Liked 12 Times in 10 Posts
I have 27" x 1 1/4" Michelin ProTech tires on my Super Mondia and they measure 1.390" after inflation to 90lbs. This calculates out to over 35mm wide! Be careful on brand , I was fortunate they BARELY clear the frame . I backed up the axel stop and I was OK. I have to deflate the rear to remove the wheel. I also have two release levers for each wheel's brake, one at the handlebar lever and one on each cable hanger.That said, I love the tires and I am not afraid of dirt or gravel roads. Joe
Kabuki12 is offline
Old 05-28-19, 11:31 AM
ryansu
Ride.Smile.Repeat
ryansu's Avatar
Quoted: 464 Post(s)
Liked 40 Times in 33 Posts
Roughly:
27 inch size ISO rough metric equivalent width (Note look on your sidewall for the ISO measurement)
27 x 1 630x25c
27 x 1 1/8 630x28c
27 x 1 1/4 630x32c
27 x 1 3/8 630x37c
ryansu is offline
Old 05-28-19, 04:29 PM
palincss
Quoted: 160 Post(s)
Thanks.
There is no such thing as 27 x 1.25. It's 27 x 1 1/4. As you'll see on Sheldon's site, two tires with what should be identical widths, one expressed as a decimal and one as a fraction, will never be the same. What you need to pay attention to is the ERTRO designation, which is the bead seat diameter. 27" is 650, 700C is 622. Regardless of the width, those two tires will never fit on the same rim. It gets even hairier when you get to 26". There are quite a few 26" sizes: MTB 26" is ERTRO 559; 650B aka 26 x 1 1/2" is 584; 26 x 1 3/8" English 3-speed size is 590 and there are several other more obscure sizes called 26".
You may be able to convert your 27" bicycle to use 700C wheels by using longer reach brakes. At that point, the actual width of the tire -- what will actually fit -- should be your guide. In some cases, that may actually be wider than the original.
palincss is offline
Old 05-28-19, 04:54 PM
SurferRosa
SurferRosa's Avatar
Quoted: 370 Post(s)
Liked 47 Times in 33 Posts
You know society is in trouble when "the science guy" can't convert inches to millimeters.
SurferRosa is offline
Likes For SurferRosa:
Old 05-28-19, 06:52 PM
the sci guy
bill nyecycles
Quoted: 472 Post(s)
1.25 is just another way (faster) to write 1 & 1/4.
I wasn't looking to put 700c tires on a 27" rim or vice versa. I have 2 bikes, one with 27" wheels and one with 700c wheels. I liked the width of the new tires I just put on the 27" wheels, and wanted to know the 700c equivalent to pick out new tires for that bike.
I actually didn't know it was literally just doing this. I'm well versed in sciencey science, but still new to bike science. :-)
Old 05-28-19, 07:03 PM
palincss
Quoted: 160 Post(s)
No! Mathematically it may be, but in terms of tire sizing, no. The fractional size indicates that it is a different tire, almost certainly with a different bead seat diameter. And it may be wildly different. Today, 26xdecimal = mountain bike 559mm bead seat diameter. 26xfraction almost always means something very much larger. 26x1 1/2 = bead seat diameter 584. Read the Sheldon Brown article I linked earlier about tire sizing systems.
palincss is offline
Old 05-28-19, 08:00 PM
Road Fan
Road Fan's Avatar
Quoted: 805 Post(s)
Liked 10 Times in 9 Posts
Steve, isn't 27" a monniker for ERTRO 630? 8 mm more bead seat diameter than the 622 mm of ERTRO 700?
Road Fan is offline
Old 05-28-19, 08:06 PM
Road Fan
Road Fan's Avatar
Quoted: 805 Post(s)
My understanding is that there are two basic designs of 630 rims: hooked-bead and smooth-bead. Smooth-bead was the original, and nearly perfectly fits modern wired-bead 27" 630 tires. The more modern hooked-bead rims may be marked 1.25."
Road Fan is offline
Old 05-28-19, 10:11 PM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 654 Post(s)
Liked 39 Times in 34 Posts
1.25 is just another way (faster) to write 1 & 1/4.)
Not in the bicycle world. Decimal will not equal fraction. If you want a real headache, try 26 inch tires sometime. There's the 559 26'r, typical old school MTB which will be decimal sized (like 1.5). Then you have the 571, which will be fractional, then you have the 584 which can be 26- 1 1/2, then you have the 590. Last is the 597. Five different sized 26 inch rims, four of which are fractional sized. Had a bike once with a 590 rear wheel, and a 597 front. Both used 1 3/8 inch wide tires! (One was the old Schwinn standard). So two different sizes for 26 - 1 3/8 tires.
Then you have 29'rs, which are smaller than 27'rs. Go figure.
wrk101 is offline
Old 05-29-19, 04:13 AM
verktyg
verktyg
verktyg's Avatar
Quoted: 502 Post(s)
Liked 21 Times in 19 Posts
700C not 29'ers
This chart shows a comparison of the various 26" tires and rims with the ERTRO designations at the top, inch sizes and metric equivalents in the middle and "650" variants at the bottom. Note: the 650 lettered sizes were originally French designations but other European countries used those call-outs too.
Comparative tire cross-section sizes - note, 1 1/4" should be 32mm not 31mm.
THEY'RE FRIGGIN 700C's NOT 29'ers!!!!
The root of my rant goes back to around 1975-76 when the revered clowns of Marin County, California started mounting derailleurs on 40 Lb. 26" balloon tired "kids" bikes and ridding them down Mt. Tamalpais on the "Repack Rides". They were "getting a lot of ink in the bicycle rags". In SoCal guys were doing the same thing but calling them "beach bombers" and riding around Venice Beach and other seaside communities.
In 1976 we started "Rough Stuff" riding in the British manor: off road riding on road bikes in northern New Mexico and southern Colorado. (we viewed ourselves as purists)
Initially there were only a handful of us crazy enough to ride sewups in the woods, dirt roads and mountains. We used 30-32mm wide d'Alessandro and Milremo badged versions of the same tires. There were several quality levels with either coarse pitch, medium pitch or fine pitch cotton casings. They all had tough treads with a coarse diamond pattern and a puncture resistant belt.
Several of the guys rode 27" x 1 1/4" clinchers as 700C wheels and tires were just coming into the US market. I started riding cheap Wolber 700C x 35 "de ville" clinchers for gravel grinding. They were made for the French town bike market and had about 25 threads per inch cotton casings. They were the only larger size 700C clinchers I could find in the US back then. We got them from Mel Pinto Imports.
Now to really muddy the water, some of the northern European tire makers labeled their sewups 27" x an inch size width. Continental was one example. I bought this Conti cyclocross sewup marked 27" x 1 1/8" about 1977-78. It still holds air and is actually 700C x 30 not 27".
Getting back on topic, there is an 8mm difference in rim sizes between 27" and 700C (ERTRO 630 vs 622) but wheels with the same cross-section tires will sit approximately 4mm higher or lower from the ground.
700C sized clinchers started becoming popular around 1975-76 when riders who used sewups wanted to switch back and forth between those and clinchers without having to readjust the brake blocks every time.
verktyg
Things aren't always what they seem... Don't believe everything you think!
Chas. ;-)
verktyg is offline
Old 05-29-19, 06:16 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 630, '79 Peugeot PXN10LE, '83 Fuji America, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 567 Post(s)
Liked 77 Times in 51 Posts
[stunned] Um, multiply inches by 25.4 to get millimeters. Right, @the sci guy ?
Phil_gretz is offline
Old 05-29-19, 06:26 AM
rumrunn6
rumrunn6's Avatar
Quoted: 3034 Post(s)
Liked 115 Times in 93 Posts
google does conversions just type in "32mm = inches" & it will give you 1.25984 or conversely type "1.25 inches = mm" & it will give you 31.75 which should be a good ballpark # so you can choose the tire size you want
rumrunn6 is offline
Old 05-29-19, 06:29 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1699 Post(s)
Liked 63 Times in 43 Posts
And so-called 27.5" are just 650B. What's wrong with people?
It would be so much easier if everybody used the ETRTO size designations.
JohnDThompson is offline
Likes For JohnDThompson:
Old 05-29-19, 06:46 AM
BFisher
Quoted: 48 Post(s)
Agree 100.25% (or maybe 100 1/4)!
The tire size situation in the bike world is beyond absurd.
BFisher is offline
Old 05-29-19, 08:45 AM
the sci guy
bill nyecycles
Quoted: 472 Post(s)
Old 05-29-19, 12:31 PM
ThermionicScott
hungry
Was there ever a competing 27" decimal standard, though?
RUSA #7498
Old 05-29-19, 12:47 PM
gugie
Crapmaster Emeritus
gugie's Avatar
Bikes: JP Weigle'd Raleigh Competition reconstruct, 73 Raleigh Competition 650b'ed, 96 Bike Friday NWT, 83 Lotus Classique, 78 Centurion ProTour, 73 Raleigh Grand Sports
Quoted: 2216 Post(s)
Liked 46 Times in 34 Posts
There are lies, damn lies, and tire widths matching what the sidewall sez.
Add to that the rim used will change the actual width, new vs old tire...
gugie is offline
Old 05-29-19, 02:16 PM
3alarmer
3alarmer's Avatar
Bikes: old ones
Quoted: 14547 Post(s)
Liked 74 Times in 63 Posts
...I might not know tyres, but I know what I like.
3alarmer is offline
Old 05-29-19, 02:57 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 1739 Post(s)
Liked 17 Times in 16 Posts
27" is bigger than 29".
29" is the same size as 28".
All three are bigger than 27.5".
And, of course, 27.5" is about halfway between 26" and 27".
It's quite simple really, once you release your tight grasp on reality.
My Bikes
Andy_K is offline
