Bottom Bracket question
Old 06-03-19, 11:57 AM
StodaD
Hi guys, im new to this forum and delighted to be part of it.
I have a question regarding my bottom bracket. I have a BB on my bike that is compatible for shimano dura ace gxp crankset. I got myself a quarq d zero gxp powermeter and sram chainrings and i assembled the rings together onto the quarq arms. That was fine.
However when trying to remove the cup of the bottom bracket of the shimano BB on the right hand side of the bike with the removal tool, the left cup rotates as well and cannot get that to stop rotating while i try to remove from the right hand side. I am turning it in a clockwise position (RHS cup) . The cup on the left hand side rotates as well and i dont have any other tool to stop this rotating while i try remove the bottom bracket off the bike. I want to install a sram BB which i have bought as there is a gap with the shimano BB on the bike if you install the quarq powermeter on it, whereas the sram BB is the correct fit size.
Any solutions for me to try out?
Thanks again.
StodaD
StodaD is offline
Old 06-03-19, 12:15 PM
BobFishell
BobFishell's Avatar
Bikes: 1990 Klein Quantum, 1995 Klein Quantum Pro, 1997 Klein Pulse Comp, Cannondale 3.0 (junk box build - year unknown)
Quoted: 15 Post(s)
Liked 6 Times in 6 Posts
Thanks again.
StodaD
Can you use a flat screwdriver, hold the shank against the spindle, jam the blade into one of the splines? A picture would help.
BobFishell is offline
Old 06-03-19, 02:50 PM
3alarmer
3alarmer's Avatar
Bikes: old ones
Quoted: 14546 Post(s)
Liked 74 Times in 63 Posts
...if it were me, I'd just buy another Shimano BB tool for the other side, so you can use both of them at the same time. They're not real expensive.
3alarmer is offline
Old 06-03-19, 05:28 PM
dsaul
Quoted: 235 Post(s)
Liked 30 Times in 23 Posts
The cups should only be connected by a plastic sleeve with some o-rings holding it together. There is no reason why you can't just keep turning the drive side and pull it out.
By the way - GXP is a SRAM thing. Shimano 24mm is called Hollowtech II and they are not compatible, as you have discovered.
dsaul is offline
Likes For dsaul:
Old 06-03-19, 06:49 PM
alcjphil
alcjphil's Avatar
Quoted: 563 Post(s)
Liked 23 Times in 22 Posts
Exactly, just keep turning the external cup until it comes out, then remove the other one
alcjphil is offline
Old 06-04-19, 07:10 PM
StodaD
I find when i keep turning the drive side cup. The left one keeps turning too. I will take a photo and upload for you guys to see.
StodaD is offline
Old 06-05-19, 06:07 AM
dsaul
Quoted: 235 Post(s)
Definitely need some pics of what you are talking about. Both sides are threaded such that, if they are both turning at the same time, they are both unthreading. This is assuming that this is an english threaded bottom bracket, which is not clear from the information provided.
dsaul is offline
Old 06-05-19, 07:16 AM
Road Fan
Road Fan's Avatar
Quoted: 805 Post(s)
Liked 10 Times in 9 Posts
If they’re both turning and not extracting, that suggests there’s no thread engagement.
Road Fan is offline
Old 06-05-19, 06:33 PM
StodaD
I will try and get photos up but im not allowed at the moment as im new to this forum.
StodaD is offline
Syndicate
Mountain Biking
1
01-11-08 05:03 PM
