Freewheels & freewheel accessories
Old 06-08-19, 10:03 PM
wesmamyke
Quoted: 144 Post(s)
Flat rate boxes of freewheels & stuff. More pictures available if you want a close up of something.
Misc cosmetically challenged freewheel bodies, cogs and bits. Grime and corrosion on anything that was black oxide coated. The gold/zinc coated stuff is in better shape. Technically some NOS in there, but was stored very poorly. FW bodies are a little crunchy, mostly ultra 6 Suntour, I think the pro-compe are 5spd maybe? Suntour, some Maillard.
$75 shipped OBO
Suntour freewheels with big cogs, and misc parts. Came from a good home and stored properly, but not perfect. One of the freewheels is sticky if I recall, probably grease injected a tad much. Big climbing cogs, I think the biggest is 34t, maybe five 32t cogs all together. Original boxes come with if you want them, they have been switched around and have writing on them.
$100 shipped OBO.
Sachs Maillard Aris stuff. I was going to offer this as a lot, but realized it's a mix of standard threading and Helicomatic. Happy to sell it all for $110 shipped OBO. Or broken into two lots...
8spd standard threading: The two 12-32t huge guys, and close ratio on bottom left. Maybe you have a tandem or e bike that needs one? If I recall you can run these minus one or two cogs. New with shop wear. All 3 for $80 shipped OBO.
6spd Helicomatic: Two on the bottom right, new with shop wear. $40 shipped OBO.
Lot of freewheel tools: Bicycle research FW vise, VAR FW vise, Stein grease/oil injector and misc FW socket tools.
VAR tool is frozen solid, soaked in evaporust, still stuck. Stein tool needs repair, the bottom bracket cup that provides the threaded section is bonded in place and is loose. FW removers have typical shop wear, but should be usable. $60 shipped OBO
wesmamyke is offline
Old 06-15-19, 12:56 PM
wesmamyke
Quoted: 144 Post(s)
Bump with lowered prices.
Old 06-15-19, 01:11 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 215 Times in 179 Posts
I have more .. And a custom machined lube/flush tool for new winner pro , with labyrinth seals ..
that lube hole is only seen when freewheel off the hub.. ...
fietsbob is offline
