Uncaged bottom bracket bearings?
Old 06-11-19, 07:28 PM
smontanaro
Bikes: many
Quoted: 442 Post(s)
Liked 12 Times in 9 Posts
I bought a Sugino MW-68 bottom bracket to use with an early Superbe crank on my Griffon. The cups and spindle are in good shape. It came with loose bearings. Is there any reason to prefer caged bearings over loose other than the challenge of keeping loose bearings in place during assembly?
smontanaro is offline
Old 06-11-19, 07:37 PM
Bandera
Quoted: 1057 Post(s)
Liked 74 Times in 47 Posts
No there is not, but I've never seen a Japanese OEM BB from the '60's onward w/ loose bearings.
Used I'd be very careful to get the bearing size/number correct.
-Bandera
'74 Raleigh Internat'l. '77 Trek TX900 FG. '90 Vitus 979. '10 Merckx EMX3. '13 Soma Stanyan
Bandera is offline
Old 06-11-19, 07:41 PM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 70 Post(s)
Liked 6 Times in 5 Posts
Ditto-just pack em in with grease.
Bigbus is offline
Old 06-12-19, 01:09 AM
SurferRosa
SurferRosa's Avatar
Quoted: 372 Post(s)
Liked 48 Times in 34 Posts
Is there any reason to prefer caged bearings over loose..?
Maybe if you have campy retainers.
SurferRosa is offline
Old 06-12-19, 05:17 AM
Kuromori
Quoted: 112 Post(s)
Liked 17 Times in 14 Posts
It's easier to install and harder to lose bearings.
Kuromori is online now
Old 06-12-19, 05:28 AM
cudak888
www.theheadbadge.com
cudak888's Avatar
Bikes: http://www.theheadbadge.com
Quoted: 326 Post(s)
Liked 86 Times in 73 Posts
Glob those BB cups full of nice, sticky grease, and pop them in. You should be fine
-Kurt
cudak888 is offline
Old 06-12-19, 07:44 AM
SamSpade1941
SamSpade1941's Avatar
Quoted: 362 Post(s)
Liked 15 Times in 13 Posts
Caged bearings are superior to loose and there is no point unless you just want to be really really old school . Lots of conjecture about being able to install more loose balls versus a cage , but that is all that it is. Those cages arent there for a cost savings, they maintain properly spacing
SamSpade1941 is online now
Old 06-12-19, 08:14 AM
Trevtassie
Quoted: 317 Post(s)
Liked 35 Times in 17 Posts
Uncaged bearings can carry more load, unless the cages are designed to minimise bearing spacings ala Campagnolo. For example good quality MTB suspension pivot bearings are full complement with no cage. Caged bearings are cheaper (usually less balls) and easier to assemble than loose balls so manufacturers are always going to use them, they aren't going to pay somebody to place balls one by one with the chance of getting the numbers wrong.
Cartridge type roller bearings (except for full complement) have cages because of the way they are assembled. The balls are placed together in the outer race, the inner race inserted then the balls evenly distributed and the cage fitted to maintain spacing so the bearing doesn't fall apart. This is a different situation to a bottom bracket. Full complement bearings have indents in the side of the races so the balls can be inserted one by one with the indents lined up.
Trevtassie is offline
Old 06-12-19, 08:25 AM
bikemig
bikemig's Avatar
Quoted: 3627 Post(s)
Liked 79 Times in 71 Posts
Suntour also made caged bearings that could take 11 to a side. I'd run them loose 11 to a side rather than use a cage that only takes 9.
bikemig is offline
Old 06-12-19, 08:55 AM
SamSpade1941
Quoted: 362 Post(s)
@Trevtassie
I am going to assume you are aware that many engineering studies have been performed concerning this very topic. Yes there is definitely manufacturing efficiency and cost savings in using caged balls , however they are also better at what they do.
There is a lot of information available out there concerning this very topic. As I said earlier if you want to use them because it makes you feel better being a traditionalist fine, there is no performance benefit to be realized however .
Old 06-12-19, 11:10 AM
madpogue
Quoted: 654 Post(s)
Liked 52 Times in 43 Posts
...nice, sticky grease...
+1; keyword sticky. For those who like to use waterproof marine grease, I found (by chance) that Liquid Wrench brand marine grease (reddish [almost Shimano] color) is definitely stickier than the other brands you typically find at a FLAPS or home store.
madpogue is offline
Old 06-12-19, 11:17 AM
smontanaro
Bikes: many
Quoted: 442 Post(s)
Thanks for all the responses. The spacing argument seemed like it would be worth investigating, so I hunted around a bit to see what Jobst Brandt had to say about the topic. In this rec.bicycles.tech thread, he wrote:
Full complement ball bearings, as I mentioned, can also have cages,
whose purpose is ease and reliability of assembly rather than to alter
friction or wear characteristics.... The reason for ball or roller cages in
bearings is for assembly rather than a load related one except in ones
where the cage allows using fewer balls for economic effect.
Hmmm. Sir Sheldon disagrees:
Most newer bicycles come with "caged" bearing balls-the balls are held in a metal or plastic retainer. This makes it easier to install the balls, but usually at a cost in performance. A standard three-piece type bottom bracket takes 11 loose 1/4-inch balls per side. Most retainers hold fewer balls, so each ball and its contact points with the cup and cone are more heavily stressed. This causes higher friction and more rapid wear.
Unfortunately, we can't ask either Jobst or Sheldon.
I do have some Campy caged bearings, not in front of me, though what I've read suggests they probably hold 11 bearings. The reason for buying the Sugino was that I lacked a suitable Campy spindle. This bb was cheap enough that even if I didn't use the cups and bearings, I'd have a spindle I could use. I think I will try 11 loose bearings and see how it goes. Unless the ride is so magical that I sell every other bike I own and start riding 20k miles per year, based on what I've read I rather suspect there will be little effective lifetime wear difference between 9 caged, 11 caged or 11 loose bearings.
Old 06-12-19, 12:13 PM
madpogue
Quoted: 654 Post(s)
And in all likelihood, they're probably still arguing about it .... up there .....
madpogue is offline
Old 06-12-19, 12:23 PM
Bandera
Probably, but they can look around to see how many angels are currently dancing on the heads of pins.....
-Bandera
Bandera is offline
Old 06-12-19, 12:34 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1702 Post(s)
Liked 66 Times in 45 Posts
Campagnolo bottom bracket bearing retainers hold 11 balls each. Other companies also used 11-ball retainers, and replacements are available. These will work with pretty much any bottom bracket that uses 1/4" balls:
https://www.biketoolsetc.com/index.c...m_id=US-GR1411
JohnDThompson is online now
Old 06-12-19, 01:35 PM
gugie
Crapmaster Emeritus
gugie's Avatar
Bikes: JP Weigle'd Raleigh Competition reconstruct, 73 Raleigh Competition 650b'ed, 96 Bike Friday NWT, 83 Lotus Classique, 78 Centurion ProTour, 73 Raleigh Grand Sports
Quoted: 2219 Post(s)
Liked 47 Times in 35 Posts
Sealed.
gugie is offline
Old 06-12-19, 01:41 PM
bikemig
bikemig's Avatar
I have a few suginos that take 11. I use them on the fixed cup to make my life a bit easier and run loose on the adjustable.
bikemig is offline
Old 06-12-19, 01:55 PM
brian3069
brian3069's Avatar
Bikes: Raleigh Supercourse
Quoted: 109 Post(s)
Liked 5 Times in 4 Posts
Insert 'This is Spinal Tap' meme here:
brian3069 is online now
Old 06-12-19, 03:23 PM
stardognine
Turquoise gatherer.
stardognine's Avatar
Bikes: 1985 Cannondale ST400
Quoted: 330 Post(s)
Liked 17 Times in 17 Posts
You can't say that here. Can you? 🤔😉
stardognine is offline
Old 06-12-19, 04:35 PM
d_dutchison
Classic, Vintage Mechanic
Bikes: '65 Legnano Gran Primeo || '76 Holdsworth Mistral || '82 Specialized Stumpjumper
Quoted: 15 Post(s)
@Trevtassie
I am going to assume you are aware that many engineering studies have been performed concerning this very topic. Yes there is definitely manufacturing efficiency and cost savings in using caged balls , however they are also better at what they do...
I for one, am unaware of any engineering studies which demonstrate that caged bearings provide any advantage other than ease of assembly over loose ones. Could you link to a couple of them?
d_dutchison is offline
Old 06-12-19, 05:29 PM
Trevtassie
Quoted: 317 Post(s)
There are advantages in high speed bearings, especially to do with grease retention and friction between the balls when centripetal forces come into play . There aren't any high speed bearings on a bicycle, derailleur pulleys maybe get into the bottom end of medium speed bearings. There's probably not even that much point using ceramic bearings, they are actually designed for extremely high speeds, where the lightness of the rolling elements means less angular forces on the outside race.
Old 06-12-19, 05:55 PM
SurferRosa
SurferRosa's Avatar
Quoted: 372 Post(s)
I think 11 balls used without a retainer "maintain proper spacing," too.
Old 06-12-19, 08:49 PM
smontanaro
Bikes: many
Quoted: 442 Post(s)
OK, I installed the Sugino MW-68 with Campagnolo caged bearings. Thanks for the inputs. I suppose next time I need to replace the bottom bracket on this bike I can go "full @gugie" and source a Phil bottom bracket.
Old 06-12-19, 10:04 PM
SamSpade1941
Quoted: 362 Post(s)
Will the Vice President of engineering at a company which builds precision manufacturing equipment do?
Caged balls are widely deployed in motion systems throughout industry. Whether used in ball bearings, linear guides, or ball screw actuators, caged balls bring both performance and practicality. The addition of the cage minimizes wear, reduces noise, and extends maintenance intervals. The technology also significantly boosts the lifetime of the device compared to non-cage versions. These attributes have made caged balls the go-to technology for a variety of applications.
all cages provide a number of benefits, including:
  • Minimizing metal-to-metal contact
  • Ensuring orderly ball movement
  • Improving high-speed performance
  • Retaining grease for longer lifetime
The ability to retain lubricant reduces maintenance, decreases unscheduled downtime, and enhances performance. It is also useful from a business standpoint. OEMs typically specify lubrication intervals for their equipment, but end-users often donít comply. Designing in caged balls means that even if the asset owner doesnít follow proper maintenance procedures, the OEM can still have confidence that the equipment will operate as expected.
Caged balls are not always a perfect fit, of course. In a few cases, non-caged balls may be a better fit:
  • Applications with temperatures over 80įC
  • High-vacuum applications
  • Extreme-radiation environments
  • Applications with extremely light loads, for which the friction introduced by ball cages can present issues
The above comments were taken from a technical article titled " The Benefits of Caged Balls: Boosted Lifetime and Reduced Noise" By Wally Logan - Vice President of Engineering - Motion Solutions.
I have read countless articles and technical studies and have yet to find a single one that advocates loose bearings as being superior for most applications where caged bearings are used. I am not against you or anyone else using loose balls because it makes you feel better, but it does not outperform quality caged ball bearings .
Old 06-12-19, 10:05 PM
SamSpade1941
Quoted: 362 Post(s)
It might but it will not out perform a quality caged bearing assembly.
