Opinions on radial NDS lacing?
Old 06-12-19, 08:23 PM
smashndash
Quoted: 258 Post(s)
Liked 10 Times in 8 Posts
Iím having a new wheelset built and I have the option of going radial NDS or 2 cross NDS on the 24 spoke rear wheel. Itís rim brake.
My OEM rear wheel was also 24 spoke and radial NDS but the wheel was torsionally so flexy that the spokes would rub the rear derailleur and the only solution the shop could come up with was sticking an unnecessary spacer behind the cassette. Iím only about 135lbs/62kg but I was still able to flex that wheel without really trying too hard.
My new wheel is 24 spoke 2 cross NDS and is solid - but it also has a stiffer rim and uses cx ray spokes.
Does anyone run a radial NDS here, preferably on deep (56mm for me) carbon rims? Has anyone else had this experience with radial NDS spokes, or was that OEM wheel just garbage?
smashndash is offline
Old 06-12-19, 08:33 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1736 Post(s)
Liked 48 Times in 35 Posts
I suspect the OEM wheel was laterally flexible, not so much torsionally so. Perhaps one of the draw backs to a minimally spokes wheel that has a lot of dish. Add in the reduction of clearances to fit more cogs and cage rub is more likely. As to the "unnecessary spacer", seems to me that it is necessary after all
I think you'll find that playing with lacing patterns has less to do with performance then spoke count, amount of dish and spoke tensions. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 06-12-19, 09:02 PM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2029 Post(s)
Liked 99 Times in 82 Posts
Have you read this yet? https://www.slowtwitch.com/Tech/Debu...ness_3449.html
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 06-12-19, 09:40 PM
smashndash
Quoted: 258 Post(s)
I mean... I did say that I have a very similar wheel - 24 spokes - that doesnít have this issue. And I ride with a team of some very strong, large dudes (who have 40lbs on me and can destroy me on climbs) who all run 24 spokes. Though I donít believe any of them run radial NDS.
I have read it, and itís why I believe I was lacking torsional stiffness. I never had any brake rub despite throwing the bike around like crazy. The contact only happened when I was in the easiest cog. I could get the spokes to reach out to the derailleur even under a little power when seated, as long as I put down enough torque.
So does everyone here run 2 cross NDS? Anyone stronger and heavier than me (neither are high bars to clear) who have CX-Ray or similar spokes with radial NDS?
I wonder why Light Bicycle defaults to radial NDS then.
Old 06-12-19, 09:59 PM
Bill Kapaun
Bill Kapaun's Avatar
Bikes: 86 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 661 Post(s)
Liked 26 Times in 22 Posts
Maybe the big guys spin a lower gear at a higher cadence instead of mashing like you?
With a low enough gear and a "jerky style", most anyone can torture a spoke.
Bill Kapaun is offline
Old 06-12-19, 10:01 PM
smashndash
Quoted: 258 Post(s)
Doubt it. I climb between 90-120rpm when Iím going fast. And youíre right that jerkiness made it worse. But I want to be able to pedal how I please, especially since, again, I weigh 62kg and probably FTP around 220W.
Old 06-12-19, 10:07 PM
Bill Kapaun
Quoted: 661 Post(s)
I smell someone that has their mind made up and is just looking for someone to agree to radial lacing.
It's not me.
Old 06-12-19, 10:39 PM
smashndash
Quoted: 258 Post(s)
It's not me.
No... Iím actually against it as I know 2 cross will work. But Iím curious to see if anyone runs radial with no issues. Itís a racing wheelset so I want to build it up as ďracyĒ as possible. Light Bicycle said they go radial by default (I didnít state a preference one way or another). I wouldnít have asked if they hadnít said that.
Old 06-12-19, 10:53 PM
ThermionicScott
hungry
No... I’m actually against it as I know 2 cross will work. But I’m curious to see if anyone runs radial with no issues. It’s a racing wheelset so I want to build it up as “racy” as possible. Light Bicycle said they go radial by default (I didn’t state a preference one way or another). I wouldn’t have asked if they hadn’t said that.
Obviously enough people use radial NDS without issue, that wheels of this kind stay in production. Wheelbuilders here on BikeForums tend to be a little conservative. You might get more experience and support for what you're trying to do, on a forum like Weight Weenies.
RUSA #7498
Old 06-12-19, 10:54 PM
Litespud
Bikes: 2000 Litespeed Vortex Chorus 10, 1995 DeBernardi Cromor fixie
Quoted: 139 Post(s)
Liked 31 Times in 22 Posts
Long time ago I had a wheel set comprising 32-spoke Mavic Open Pro rims on Chorus hubs, front laced radial with DT Revolutions (14g/17g, IIRC), and the rear laced 2x DS, radial NDS. One side had Revolutions, and the other 14g/15g butted spokes, but I can’t remember which was which. I had them built by Colorado Cyclist. Good solid wheels that lasted me years without needing anything (I was ~170lb at the time). I sold them when I bought my current Rolf wheelset - probably should have kept them as a climbing wheel set, as they were significantly lighted than the Rolfs.
Litespud is offline
Old 06-13-19, 01:58 AM
smashndash
Quoted: 258 Post(s)
Originally Posted by Litespud View Post
Long time ago I had a wheel set comprising 32-spoke Mavic Open Pro rims on Chorus hubs, front laced radial with DT Revolutions (14g/17g, IIRC), and the rear laced 2x DS, radial NDS. One side had Revolutions, and the other 14g/15g butted spokes, but I canít remember which was which. I had them built by Colorado Cyclist. Good solid wheels that lasted me years without needing anything (I was ~170lb at the time). I sold them when I bought my current Rolf wheelset - probably should have kept them as a climbing wheel set, as they were significantly lighted than the Rolfs.
Thanks for your anecdote. 32 spokes is significantly more than 24 though, so I think Iíd rather err towards 2 cross just to avoid the potential headache. Unless someone can testify to radial NDS being feasible with 24 spokes.
Old 06-13-19, 01:59 AM
smashndash
Quoted: 258 Post(s)
I might make a weight weenies account to see if anyone there has experience with radial NDS. Thanks
Old 06-13-19, 08:02 AM
ThermionicScott
hungry
They have an "Everything Wheels" subforum featuring "The Wheelbuilding Thread" that has gone on to 400+ pages. Lots of good stuff to absorb. I just lurk on WW, since I already chat on too many online forums.
RUSA #7498
Old 06-13-19, 08:25 AM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1143 Post(s)
Liked 25 Times in 22 Posts
Feasibility notwithstanding, what is the advantage of radial NDS lacing and why bother with it? The weight saving has to be insignificant. All I can think of is cool appearance.
HillRider is offline
Old 06-13-19, 08:46 AM
Andrew R Stewart
+10! Andy
AndrewRStewart
Old 06-13-19, 11:18 PM
surak
surak's Avatar
Bikes: Specialized Roubaix, Giant Contend SL Disc 2, Priority Continuum Onyx, Santana Vision, Kent Dual-Drive Tandem, Priority Classic
Quoted: 250 Post(s)
Liked 21 Times in 9 Posts
Did you ask Light Bicycle why they do radial NDS? Will they do 2X instead? I have pretty similar physical specs and have been thinking about the LB 56mm wheelset for a while now, still haven't decided though, but interested in your LB experience.
surak is offline
Old 06-14-19, 09:04 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6839 Post(s)
Liked 218 Times in 181 Posts
My only 24 spoke is on a 16" 349 rim rear laced 2 cross, both sides ..
but I don't follow the trendy builds that are now fashionable ..
seen: wheels built , spoked in groups of 3, 2 drive side to one to the left side ..
hub and rim made specific to that lacing pattern ..
fietsbob is offline
Old 06-14-19, 09:37 AM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 542 Post(s)
Liked 20 Times in 17 Posts
I build a lot of 24 spoke rear wheels, and the only conditions under which I build radial on either side is if the hub takes straight pull spokes, in which case the spoke orientation is not optional, or the customer demands it for a J bend build.
I have also seen rims with farings that dictate spoke direction, so no choice there either.
Dan Burkhart is offline
Old 06-14-19, 09:41 AM
ThermionicScott
hungry
Since I can't see the wheel in question, are the drive-side spokes interlaced or not? Are we sure the derailleur and derailleur hanger are straight?
RUSA #7498
Old 06-14-19, 01:31 PM
Jon T
Bikes: '84 Peugeot PH10LE
Quoted: 356 Post(s)
Liked 18 Times in 13 Posts
With radial "lacing", the spokes are pulling on the weakest spot on the hub--straight out, where there is the least amount of parent material between the spoke hole and the edge of the flange. 2 or 3 cross puts the stress at an oblique to the flange hole and has lots more support and not as likely to rip out. Think about it for a minute and I think you'll see what I'm getting at. It's simple physics.
Jon
Jon T is offline
Old 06-14-19, 01:55 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Not rear and not quite radial but does use straight pull spokes..
for Bromptons and other 16" folding bikes with a dynamo hub..
20 spoke... a 28, using a regularly drilled rim is also available..
fietsbob is offline
Old 06-14-19, 02:31 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 662 Post(s)
Liked 31 Times in 25 Posts
One site offers a condensation that lists some of the same things Andrew has. They condense a lot of sources and say
"Our goal is to maximize lateral stiffness, so how do you this? Well, in order of importance the contributing factors to lateral stiffness are*:
  1. The rim stiffness
  2. The number of spokes
  3. The spoke bracing angle
  4. The gauge of the spokes
  5. The lacing pattern"
The say that that lateral stiffness is their key goal. I suspect that radial stiffness is gonna be somewhat related to lateral stiffness. Also, given your two stated options (radial and 2 cross), I don't think you have to worry about radial stiffness like you would if you laced 4 cross (tangential). Following the list above, you've got the stiffer rim in the new wheel. 24 spokes should be enough, especially given your weight. Spoke bracing angle is kind of fixed by the hubs and rims. CX-ray spokes are light - their cross-sectional area is about that of a 1.5mm diameter round section. And NOX composites suggests that lacing pattern doesn't affect lateral stiffness that much.
This leaves you to be concerned about tangential stiffness which is what you were complaining about I think. If you have a normal rear hub (that is not one that has a large, torsionally stiff center section) Jobst Brandt suggested that most of the driving torque will be absorbed by the DS of the hub. This would allow you to lace the NDS radially. The NOX folks use 2 cross and have done some research to prove it, but 3 cross gives you better tangential stiffness. I use 3 cross (and am rebuilding two vintage bikes using 4 cross), but I weigh 240 and the extra tangential stiffness is useful to me.
But all of this is the cart before the horse. What is it that you are attempting to achieve? If the big bugaboo is tangential flex, why not just use 3 (or perhaps 2) cross on both DS and NDS? What is it that you are looking for that the radial lacing offers that (for example) 2 cross doesn't? If more tangential stiffness is desired, why are you investigating lacing with LESS tangential stiffness? That is:
WizardOfBoz is offline
