Albatross bars with 31.8 mm clamp?
Old 06-14-19, 06:12 AM
brianinc-ville
brianinc-ville's Avatar
Quoted: 57 Post(s)
Liked 5 Times in 4 Posts
Hi. I'm looking for Albatross-type handlebars (i.e, grips parallel to the frame, gip area long enough to accept a grip-shifter) to use with a 31.8-mm oversized clamp (yes, I could just get a new stem, but I'd rather not). The grip-area diameter shoud be 23.8. Does such a handlebar exist?
brianinc-ville is offline
Old 06-14-19, 08:48 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 217 Times in 180 Posts
Shim sleeves are made . machined, with a 31.8mm (1.25") outside
and what the bar clamp diameter actually is , on the inside..
As a mechanical solution, Then, you can use that specific Nitto made bars that Riv Bike sells as the 'Albastache'
which I assume is replacing the narrower mustache bar with a road bar like .. as you say '23.3' * mm ,
not 7/8".. 22.2mm.
those came in 1" & 26mm center sleeve..
https://www.rivbike.com/collections/...bar-26-0-16244
*they specify 23.8mm bar... (drop bar brake lever clamp). and 26mm center..
'Albatross' is a variant of the upright north road bend and uses 7/8" mtb brake and shifter levers and grips.. ....
a mere 1.6mm diameter difference..
fietsbob is offline
Old 06-14-19, 10:41 AM
blakcloud
blakcloud's Avatar
Bikes: Rivendell Sam Hillborne, Brompton S/M3L (modified), custom Winter Cycles
Quoted: 312 Post(s)
Liked 12 Times in 7 Posts
Not that I know of. I used Albatross with the shim that is described above. Velo Orange also sells the shims. Maybe someone else has an idea.
blakcloud is offline
Old 06-14-19, 11:08 AM
Leisesturm
Quoted: 1238 Post(s)
Liked 21 Times in 18 Posts
I personally think that Albatross bends are just as unnatural as a 'straight' bar and IMO the bend of the FSA Metropolis strikes the perfect balance. Have one on our flat-bar tandem. On one Mary bars have a similar bend but the Metropolis has a 31.8 center area. Try one, it might grow on you.
https://www.amazon.com/FSA-Metropoli.../dp/B0037N7S1G
Leisesturm is offline
Old 06-14-19, 11:19 AM
brianinc-ville
Quoted: 57 Post(s)
That's very similar to the bars I'm trying to replace (because they're making my hands hurt). I generally use moustache bars on most of my bikes, but this one (Douze cargo bike) has got a NuVinci hub, so it needs a longer grip area for the grip shifter. Albatross or porteur would seem to be the right thing.
Old 06-14-19, 11:32 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
grip shifters need 22.2 tube to slip over .. 23.8 will be a no go not fit..
fietsbob is offline
Old 06-14-19, 11:38 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
My R'off grip shifter, would not even fit over 22.5mm,
the added thickness .3mm of powder coat, had to come off..
fietsbob is offline
Old 06-17-19, 12:55 PM
brianinc-ville
Quoted: 57 Post(s)
You're right -- that was a typo.
Old 06-21-19, 09:48 PM
gorillimo
Bikes: Cannondale Super V carbon, RockHopper Comp. Klein Quantum
Quoted: 50 Post(s)
Liked 11 Times in 10 Posts
It is a personal thing. We’re all wired differently. Using these bars currently. Former bike had North Road bars. Basically albatross. Gonna change it to them. More hand positions.
gorillimo is offline
