Mountain vs Road hub?
Old 06-14-19, 07:40 AM
ChinookTx
Bikes: Kona Rove Ti., Motobecane Whipshot Ti
Quoted: 86 Post(s)
Liked 39 Times in 31 Posts
Anyone knows the difference between hubs labeled as Mountain vs Road hubs?
I'm looking at buying a DT Swiss 350 hub, and there are 2 options.
  • 28H 142x12mm Road,
  • 28H 142x12mm Mountain.
What would be the difference (if any)?
ChinookTx is offline
Old 06-14-19, 07:50 AM
Kapusta
Cyclochondriac
Quoted: 899 Post(s)
Liked 46 Times in 36 Posts
Are they both disc?
Otherwise, it beats me if the axle types and hub widths are the same.
Are they different part numbers, or just the same part listed under different categories?
Kapusta is offline
Old 06-14-19, 07:51 AM
ChinookTx
Quoted: 86 Post(s)
Originally Posted by Kapusta View Post
Are they both disc?
Yes, both centerlock, both 11sp. Beats me!
I wonder if it's a weight thing, i.e. mountain uses heavier/sturdier bearings or something like that.
Old 06-14-19, 08:07 AM
Kapusta
Cyclochondriac
Quoted: 899 Post(s)
Different part numbers?
Kapusta is offline
Old 06-14-19, 08:08 AM
ChinookTx
Quoted: 86 Post(s)
Awaiting for part numbers from the seller.
Old 06-14-19, 08:29 AM
Kapusta
Cyclochondriac
Quoted: 899 Post(s)
Take a look at the DT Swiss page for the 350 hubs: https://www.dtswiss.com/en/products/...s/350-classic/
Look at the rear hubs. There are three variants of the 12x142 rear hub with centerlock. The difference between the three is in the free-hub body. One is the SRAM XD driver hub, one is 11 sp Shimano "Road", the other the Shimano-style non-road 11 speed. I think the different between the latter two is that Shimano road cassettes are a tad wider then the MTB 11 speed, so the freehub body needs to also be a tad wider.
However, I do not see DT Swiss calling the hubs themselves "Road" or "MTB". that is likely the sellers description. You just need to know which freehub these have.
Kapusta is offline
Likes For Kapusta:
Old 06-14-19, 08:41 AM
ChinookTx
Quoted: 86 Post(s)
Yeah, I believe you are right.
Seller replied that "mountain" is for Shimano HG MTB 9/10/11-speed SRAM 9/10-speed and "Road" is Shimano/SRAM 11-speed (road).
Old 06-14-19, 08:57 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6832 Post(s)
Liked 211 Times in 176 Posts
You got your DT swiss feedback..
older shimano... road was less sealed, so lower friction from seal drag, than MTB..
fietsbob is offline
Old 06-15-19, 09:27 PM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 3880 Post(s)
Liked 49 Times in 41 Posts
Yep, road 11sp has a wider freehub body. MTB 11sp cogs are set inboard a bit -- this is easy to do with a 42t big cog, even with the slight angle of drive side spokes.
LesterOfPuppets is offline
Old 06-16-19, 05:26 AM
ChinookTx
Quoted: 86 Post(s)
Thanks everyone for their replies. I now have the proper hub on the way!
Old 06-16-19, 06:26 AM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 620
Quoted: 217 Post(s)
Liked 15 Times in 13 Posts
Back in the old days of seven speed freewheels, the only difference was black vs. silver.
andrewclaus is offline
