Freewheel Hub Free Wheeling Forward and Backwards
Old 06-14-19, 09:07 AM
beach_cycle
Bikes: 2018 Meridian 26" Single Speed Trike; 2019 Monterey 26" Seven Speed Trike
Liked 4 Times in 4 Posts
Assembled my latest adult tricycle June 1; she rode smooth for 95 miles, but during yesterday’s ride, power to the drive axle quit. It slowly happened over a mile; the gears kept going lower (7th would be off the cassette, but 6th would pull the chain back on… now 2nd and beyond is off the cassette and 1st is lined up with 7th). Not sure if that is an axle issue or derailleur adjustment, but the hub between the cassette and axle is no longer engaging. I can peddle in either direction and the chain and sprockets spin, but the tires do not. Because it is new, it should be covered by warranty. Kent International says parts are covered for 6 months, but I have to pay labor and transportation. I can’t afford that, so I need to fix it myself. Any suggestions what to look for?
beach_cycle is offline
Old 06-14-19, 09:13 AM
Bill Kapaun
Bill Kapaun's Avatar
Bikes: 86 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 661 Post(s)
Liked 26 Times in 22 Posts
It might be as simple as the RDER cable slipping.
Chain still shouldn't go off the end cog if the High Limit Screw on the RDER is properly set.
Since it's a tricycle, a pic or 2 of the cassette (freewheel?) area may be helpful so one can see just how it's mounted.
Bill Kapaun is offline
Old 06-14-19, 10:33 AM
beach_cycle
Top view
Bottom view
side angle
bottom
Old 06-14-19, 10:44 AM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 537 Post(s)
Liked 19 Times in 16 Posts
The freewheel is threaded onto a hub that fits on the axle and drives the axle through a keyway. Sounds like the set screw may have come loose and let the key slip out so it no longer transmits torque to the axle.That's where I would start looking especially as it is new.
Dan Burkhart is offline
Old 06-14-19, 10:49 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6833 Post(s)
Liked 211 Times in 176 Posts
I'd guess its a multi speed freewheel , , the bike shop can take it off clean and re oil or replace..
Unless you have all the tools in your house to do it ... freewheel remover is specific to the freewheel brand,
though lots copied Shimano over the years , (but no guarantee yours is one)
you know how to pull the rear axle out?
fietsbob is offline
Old 06-15-19, 12:03 AM
beach_cycle
That was what happened. My Meridian has an intermediate axle with a freewheel hub and band brake that are adjacent. The Monterey units need to be on opposite sides of the drive axle. Lesson learned. I got her rolling smooth again; thanks for the suggestion.
Monterey proper positions for freewheel/cassette & band brake
Old 06-15-19, 10:33 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Key stock is available by the foot at an auto parts store.. to replace what fell out..
fietsbob is offline
