BB flange not cover shell completely
Old 06-14-19, 09:26 AM
mtb_addict
Quoted: 3015 Post(s)
Liked 32 Times in 28 Posts
this is a Sunrace BB. Flange only cover half the width of shell thickness.
should i look for a BB with bigger flange?
or is it ok as is?
mtb_addict is offline
Old 06-14-19, 09:35 AM
AnkleWork
Bikes: old clunker
Quoted: 540 Post(s)
Liked 25 Times in 15 Posts
I would.
AnkleWork is offline
Old 06-14-19, 09:57 AM
mtb_addict
Originally Posted by AnkleWork View Post
I would.
btw the original VP has big flange.
Old 06-14-19, 10:01 AM
mtb_addict
btw, i hate cartridge bb. the spevial tool is so easy to slip off. i had my left hand putting pressure on the tool to keep it from slipping off, but it slipped anyway...and my left finger got pinch by the wrench...now it hurt like crap.
Old 06-14-19, 10:29 AM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2028 Post(s)
Liked 95 Times in 79 Posts
Another day, another weird thread. What's the actual, functional issue??
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 06-14-19, 11:06 AM
mtb_addict
i cannit predict the future...but it looks wrong to me.
at least this is a PSA. beware the different flange size when u order replacement BB.
Old 06-14-19, 11:10 AM
AnkleWork
Bikes: old clunker
Quoted: 540 Post(s)
i cannit predict the future...but it looks wrong to me. maybe it will never be a problem...but maybe it will back itself out...and cause a crash.
Looks like the shell needs to be faced before worrying about the flange.
Old 06-14-19, 11:13 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6836 Post(s)
Liked 215 Times in 179 Posts
It's because its Aluminum .. they used a thicker tube wall shell ..
the look bothers you? apply black touch up paint..
must be a folding bike , seat tube is passing behind the BB, for seat post to come through...
fietsbob is offline
Old 06-14-19, 11:39 AM
ThermionicScott
hungry
I'll answer your questions for you. The BB flange does not need to cover the BB shell. If you torqued it properly, it will not be any more likely to back out than if the BB shell metal were thinner. There's plenty of metal in contact. Think about it.
Cancel that PSA. There's no damn problem here.
RUSA #7498
Old 06-14-19, 11:41 AM
ThermionicScott
hungry
Even that is arguable. This is a cartridge square-taper BB, not an external BB of any type that would actually be sensitive to BB shell squareness. It'll torque down until it stops, and then do its job fine until it wears out.
RUSA #7498
Old 06-14-19, 12:28 PM
AnkleWork
Bikes: old clunker
Quoted: 540 Post(s)
Cartridge BBs have been known to bind due to poor facing; contemporary external BBs more so.
Old 06-14-19, 12:46 PM
mtb_addict
i miss the original cup-n-cone bb. a much more robust design.
Old 06-14-19, 01:53 PM
cannonride15
Bikes: Cannondales: '85 ST400, '86 SR800, '87 SM600
Quoted: 38 Post(s)
Missing BBs?
Nothing to miss...they're still available!
cannonride15 is offline
Old 06-14-19, 02:01 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Here you go .. https://www.rivbike.com/collections/...6klsej-lkangkn
get out that Benjamin $C
fietsbob is offline
Old 06-14-19, 02:10 PM
ThermionicScott
hungry
Maybe with some models. Not sure how it would be possible with a Shimano UN55 that has the whole assembly within a rigid shell that takes the pressure from installation. If the OP isn’t experiencing any bearing binding, it’s yet another “problem” that doesn’t need to be “fixed.”
Old 06-14-19, 06:59 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 666 Post(s)
Liked 47 Times in 40 Posts
That's because you're doing it wrong. Go to the hardware store and buy a bolt of the correct thread for your spindle, long enough to thread in the spindle and through the tool and a washer. Bolt the tool into the cup so it doesn't slip, and crank away. Keep the bolt with the tool in your tool box.
dedhed is offline
Old 06-14-19, 07:19 PM
AnkleWork
Bikes: old clunker
Quoted: 540 Post(s)
Black/white thinking. Nothing is perfectly rigid, not even a UN55. Everything is both rigid and deformable by degrees. Eg: a thickwall BB shell may be more rigid than a thin-wall light weight cartridge.
Old 06-14-19, 07:35 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 652 Post(s)
Liked 46 Times in 42 Posts
I put a bar clamp across the BB, torque wrench, tool, and all; no need to hold the tool against the BB with your hand, which keeps it out of the line of fire and available to help hold the frame or push the wrench..
dsbrantjr is online now
Old 06-14-19, 07:45 PM
ThermionicScott
hungry
Yep, either there's a problem or there's not. It could all be simple, but the OP is a worry-wort and some would rather feed this tendency than to help. Oh well.
RUSA #7498
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1733 Post(s)
Liked 45 Times in 32 Posts
+1. Even if black and white thinking is in vouge these days the world has an infinite shades of gray. Andy
AndrewRStewart
Andrew R Stewart is online now
Old 06-14-19, 08:10 PM
mtb_addict
i admit i was not being very smart. i was turning the bb the wrong direction. kept tightening it insyead of loosening. those left hand threads always throw me off.
and it was like 100 in the garage, which affected my judgement.
