Slipping Derailleur
Slipping Derailleur
Old 06-14-19, 01:24 PM
smikeybikey
smikeybikey's Avatar
Slipping Derailleur
I wondered if any of you knowlegeable folks could help me?My bike gears have recently started slipping .Its as if it's going to change gear by itself but it remains on the same cog.Its at the rear and mainly second smallest just after I have changed down.Thanks a lot
smikeybikey is offline
Old 06-14-19, 02:15 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6832 Post(s)
Liked 211 Times in 176 Posts
cable slipping perhaps ...
as usual :1st have bike shop check hanger alignment..
it's the foundation of indexed shifting..
fietsbob is offline
Old 06-14-19, 08:27 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1729 Post(s)
Liked 45 Times in 32 Posts
If the chain remains on the initial cog then either the cable is only slightly "loose/tight" and it's catching the adjacent cog, jumping up but not derailing to the next door cog. Or the chain/cog mesh is no longer sufficient to withstand pedaling forces and the chain is moving up the teeth faces and climbing over the teeth tops. Do check for bent teeth or links too. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 06-14-19, 08:57 PM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 70 Post(s)
Liked 5 Times in 4 Posts
I always thought that was a sign that the chain and/or cassette was worn out. But I had that happen when I was first learning how to adjust the rear hanger/derailleur. After watching a few YouTube vids I got it right and now it's become second nature-both determining wear and making fine adjustments.
Bigbus is offline
Old 06-14-19, 09:46 PM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 55 Post(s)
Liked 4 Times in 4 Posts
I have also seen frozen links on the chain causing the same feeling
JoeTBM (The Bike Man)
I'm a black & white type of guy, the only gray in my life is the hair on my head.
JoeTBM is offline
Old 06-15-19, 03:49 AM
Kars
Quoted: 24 Post(s)
My 2 cents: Check chain for wear and cassette for wear just in case. It could also be that you need new cables/housings or just adjustment of cable tension.
Kars is offline
Old 06-15-19, 09:23 AM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 70 Post(s)
Yes, a stiff or frozen link on a chain will definitely cause this to happen. But if you're cleaning and lubing your chain regularly, that shouldn't happen, Right? Pick a spot on the chain and work each link by hand rotating it until you've gone all the way around. It's always possible you got a piece of grit or something in there that's causing a link to bind. Good luck,
Bigbus is offline
Old 06-16-19, 01:45 PM
smikeybikey
thanks guys -chain and sprocket don't seem worn so might be cable needs very slight adjustment
