What happened to the wear lines on Kool Stop brake pads?
Old 06-14-19, 02:10 PM
spinnaker
Every day a winding road
spinnaker's Avatar
Quoted: 3394 Post(s)
Liked 63 Times in 46 Posts
I have a set of kool stop pads for my touring bike and for the road bike. I am not seeing the wear warning line. When did kool stop eliminate those? So what is a good rule for replacement now?
spinnaker is offline
Old 06-14-19, 02:20 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
specifics? which pad?
Ask them yourself ... Kool Stop International - High Performance Bicycle Brake Pads Since 1977
fietsbob is offline
Old 06-14-19, 03:14 PM
pdlamb
Quoted: 2604 Post(s)
Liked 1,928 Times in 1,210 Posts
At a guess -- you wore it off?
pdlamb is offline
Old 06-14-19, 04:49 PM
spinnaker
spinnaker's Avatar
Originally Posted by fietsbob
Gee thanks
Old 06-14-19, 04:50 PM
spinnaker
spinnaker's Avatar
Nope brand new pads in stock.
Old 06-15-19, 08:55 AM
fietsbob
Bikes: 8
Again which one? they have many pads.. continental eagle claw dura 1 or 2
the pads they mold for magura or the ones they make and dont ship in bulk to germany?
I contacted company got longer bolts for my cross pads to use a thicker cupped washers..
fietsbob is offline
Old 06-15-19, 09:30 AM
Litespeedlouie
Bikes: Litespeed, O'Brien, Specialized, Fuji
Quoted: 18 Post(s)
Liked 15 Times in 9 Posts
I run mostly Dura 2 salmon pads and tend to replace them when the individual blocks wear down into one big one. I'm assuming the separate block design is there for a reason, such as water diversion.
Litespeedlouie is offline
Likes For Litespeedlouie:
Old 06-17-19, 07:14 AM
djb
Quoted: 2738 Post(s)
Liked 970 Times in 793 Posts
I always figured the same thing re water diversion.
when mine wear to the main body of pad, I go a bit more and then change them when I get around to it, or leave them on a bike that I dont brake much on and will "do it one day" when it really ends up really thin. (bike I ride in snow and on the flat, ie low speeds and barely any braking other than for stop lights, but from low speeds)
djb is offline
Old 06-17-19, 08:09 AM
Litespeedlouie
Quoted: 18 Post(s)
I have a feeling separate blocks on a pad might have better grip than one big pad, perhaps due to extra biting edges or something. But one big pad should work. I don't think I've ever looked for wear indicators on any pad. I would just change as discussed, and before wear would allow metal parts to contact.
Old 06-17-19, 08:45 AM
djb
think of how our car brake pads, or bike disc pads, are just one large surface area--the more pad to disc contact generally means more stopping action, so Im sure its for water/gunk diversion.
If what you think is true, our automotive disc pads would have separate blocks.
djb is offline
Old 06-17-19, 02:05 PM
Litespeedlouie
Quoted: 18 Post(s)
Some auto brake pads do have 2 or more sections, like these Bosch:
https://www.boschautoparts.com/en/au...isc-brake-pads
But I don't know why exactly - water/debris/brake dust diversion? vibration/noise control? better conformity/grabbing of the disc? marketing BS?
Old 06-17-19, 10:20 PM
djb
I have to plead innocence on car brake pad details past a limited amount.
djb is offline
Old 06-18-19, 06:15 AM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Automotive pads sometimes have grooves to prevent brake fade caused by outgassing...
The dominant mechanism causing brake fade is this thermal degradation of the phenolic resins and other materials in the friction lining, which create a film of gas at the pad-rotor interface and effectively causes the brake pad to skid off the disc. As these gasses build up at the pad-rotor interface, they produce an appreciable backpressure which creates an opposing force to the brake caliper that is trying to hold the pads against the rotor. If there is no way for the gasses to escape, the opposing force as a result of the outgassing can become large enough to prize the pads away from the rotor, reducing the area of pad in contact with the rotor and thus reducing braking power (i.e. brake fade).
Read More
-Tim-
TimothyH is offline
TiHabanero
Touring
6
03-27-19 10:05 PM
Biketouringhobo
Touring
30
05-12-16 08:29 AM
RubeRad
Bicycle Mechanics
13
12-28-15 03:33 AM
Cafe
Road Cycling
39
11-13-14 09:57 AM
Nick Bain
Road Cycling
5
07-15-10 07:31 AM
