700c question
700c question
Old 06-14-19, 06:00 PM
markwesti
markwesti's Avatar
Bikes: 84' Centurion Comp TA , 86' Centurion Ironman , 84' Centurion "track bike" , 84' Bianchi Alloro
Quoted: 413 Post(s)
Liked 18 Times in 16 Posts
700c question
I have come by a pair of Continental Podiums (tubulars) 27 " , the seller told me they are the same as 700c . Even though they are marked 27" I'm sure they are 26" - 650c something like that , I'm not at all familiar with 650's , I thought if anything they would be to big , I have a 700c tubular and I laid it on top of the Conti ,and the difference was clear . . There is a lot of info on Sheldon's site , the first thing they say is there is a lot of confusion out there about 27"s but most of it is about older tires . My tires aren't that old . So question , what have I got ? Thanks , Mark .
markwesti is offline
Old 06-14-19, 06:26 PM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1141 Post(s)
Liked 20 Times in 19 Posts
What does the lettering on the tire itself say?
HillRider is offline
Old 06-14-19, 07:04 PM
markwesti
markwesti's Avatar
Quoted: 413 Post(s)
Hi @ HillRider , the lettering on the tire says Continental Podium 27" 19mm . Thanks .
Old 06-14-19, 07:46 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 649 Post(s)
Liked 44 Times in 41 Posts
Are you sure that there isn't a number like 622 x 19 or similar? 622 is the ERTRO size for 700c. 630 x 19 would be 27"
https://www.sheldonbrown.com/tire-sizing.html#iso
dsbrantjr is offline
Likes For dsbrantjr:
Old 06-14-19, 08:03 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1728 Post(s)
Liked 45 Times in 32 Posts
Sew ups are well known for not being of any final "size" until mounted. The casing has a large amount of stretch and can often seem smaller in what might be the final size then what is the reality.
Years ago we were clearing out the adjacent to the bike shop house (had been used as satellite storage and work space for years prior) for it's becoming a residential rental again. I came across a couple of orange Clement sew up tires. They were smaller than a 590 ISO tire's bead diameter when lightly inflated. I questioned their size and the boss said they were the usual "700" size. Sure enough I dry mounted them on a pair of rims and they fit (although tight) and inflated to the usual shape. BTW I was also told to not ride them in the rain. I glued them up and had a few weeks of heaven, the nicest tires I can remember riding.
I suggest test mounting. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 06-14-19, 08:50 PM
markwesti
markwesti's Avatar
Quoted: 413 Post(s)
OK Andy, I will try mounting them , but like I said they are clearly smaller than 700c . @dsbrantjr thanks for the thought but the only thing that states size is what I have already posted .
Old 06-14-19, 09:47 PM
Bill Kapaun
Bill Kapaun's Avatar
Bikes: 86 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 661 Post(s)
Liked 25 Times in 22 Posts
This should help-
https://www.probikekit.co.uk/blog/ar...ubular-sizing/
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 06-15-19, 10:38 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6832 Post(s)
Liked 210 Times in 175 Posts
as you pump them up, mounted on the rim, they get smaller and press the wet glue out..
700C/622 bead seat, wheels is a made to be usable on bikes with glued to the rim race sew up tires on them..
some are marked 28" ....
fietsbob is offline
Old 06-15-19, 08:40 PM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 2195 Post(s)
Liked 30 Times in 17 Posts
Tubular tires don't have a bead, so they don't generally (ever?) have a bead seat diameter listed... although places that sell them will sometimes give it as an equivalence guide.
Continental does make 650c size tubulars, and they label them 26".
This kind of questions pops up in here every few months with the OP sure they have something other than regular 700c equivalent size, but they don't.
700c tubulars fit just fine on 700c clincher rims, so if you have a spare wheel around you can prove it to yourself.
DiabloScott is offline
