Truck mount help?
Old 06-15-19, 12:08 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Bikes: Specialized,Cannondale
Quoted: 536 Post(s)
Liked 63 Times in 50 Posts
Truck mount help?
So I have a couple of these mounted in my truck to haul bikes to riding locations.
https://www.amazon.com/Thule-Low-Rid.../dp/B07CGCQJDH
they work awesome just drop out the front wheel and lock down the bike and ready to roll. Works for road and mountain bikes and my wifes hybrid too.
When my son had his first bike it was smaller and I would put it in the back seat of the truck no issues. Now he got a new bike a Specialized Hotrock. Obviously no quick release and no through axles so anyone have a solution to haul the bike in the back of the truck without bringing tools to remove the front wheel? Is there an adapter of some sort that can be used for my current mounts? I couldn't find anything just wanted to put it out here to see if anyone has had a similar issue/solution.
Here is the specific bike:
https://www.specialized.com/us/en/hotrock-20/p/154370?color=225992-154370&gclid=EAIaIQobChMIjpat8ofs4gIVFbbICh2H6QfZEAQYAyABEgKNtPD_BwE
Thanks.
(New bike day pic!)
sdmc530 is offline
Old 06-15-19, 01:00 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6836 Post(s)
Liked 215 Times in 179 Posts
My Guess : its a solid axle fitted with nuts right ?
you have a through axle front hub?
get another mount for the truck bed with a QR ..
The QR stays in the mount,
you use a wrench and loosen the nuts holding the front wheel on,
and when you get there use the wrench again , to tighten the nuts securing the wheel in the fork.
fietsbob is offline
Old 06-15-19, 01:33 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 536 Post(s)
sorry, yeah its a solid axle with nuts. I was hoping to avoid un bolting and bolting the wheel every time. I didn't want to carry a wrench and torque tools with me if I didn't have to.
The QR stays in the mount all the time so you can just slip into the fork, lock and go. super handy bike hauling in the bed of a truck.
I figured this was going to be my only solution, just hoping for a miracle I guess
sdmc530 is offline
Old 06-15-19, 01:45 PM
jadocs
jadocs's Avatar
Bikes: Litespeed T2 Disc, Fondirest P4 Carbon, Fuji Cross 2.0, Specialized Fatboy
Quoted: 308 Post(s)
Liked 59 Times in 45 Posts
Get a moving blanket, put it over your tailgate. Put the bike in the bed with the front wheel over the tailgate.
jadocs is offline
Old 06-15-19, 05:52 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 536 Post(s)
I will try this...will this work with smaller size bikes?? I will give it a whirl tomorrow
sdmc530 is offline
Old 06-15-19, 11:14 PM
Jon T
Bikes: '84 Peugeot PH10LE
Quoted: 355 Post(s)
Liked 17 Times in 12 Posts
Get a TOPLINE model UG-2500. That's what I use and really like it a lot. No disassembly of any kind required.
Jon
Jon T is offline
Old 06-16-19, 05:39 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 346 Post(s)
Liked 44 Times in 29 Posts
I must be missing something. First, you would still have to remove the front wheel, right? Second, after you removed the front wheel, wouldn't the existing mount work?
Maybe you're thinking about a mounting system that does not require wheel removal, but that would not be an "adapter", it would be something to use instead of your existing mount. I made something like this out of pvc pipe. It works but you'll find that it takes more time to secure the bikes than it would to remove and reinstall a front wheel.
If I were you, I'd just carry the wrench. Wouldn't you want to carry one anyhow in case of a flat? I have a few bikes with solid axles and always pack a 15mm stubby wrench when I ride. I don't think you need to worry about torque measurements because wheel nuts need something like 25-30 ft-lbs, and that is heavy cranking with a short 15 mm wrench.
Good luck. I know that you and your son will enjoy your rides.
Moe Zhoost is online now
Old 06-16-19, 06:33 AM
Koyote
Quoted: 402 Post(s)
Liked 116 Times in 65 Posts
Get a ratcheting socket wrench, and it'll only take a minute or two to deal with it.
Koyote is offline
Old 06-16-19, 07:49 AM
_ForceD_
_ForceD_'s Avatar
Bikes: Several...from old junk to new all-carbon.
Quoted: 391 Post(s)
Liked 9 Times in 7 Posts
Try a set of these on the side rail of the truck bed. No wheel removal necessary.
https://www.amazon.com/Reese-Explore...9KTF25CF4F1RZE
Dan
_ForceD_ is offline
Likes For _ForceD_:
Old 06-16-19, 07:57 AM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 536 Post(s)
Yeah, just going to have to remove the front wheel every time. My goal was to just avoid this. I am going to try the blanket idea today when we go for our ride but short of that I will have to just suck it up and remove the wheel. I don't mind removing the wheel but was hoping for a cheat to not
thanks!
sdmc530 is offline
Old 06-16-19, 08:09 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Bike like Dad's
Change the boy's front wheel axle to a QR axle AND teach him how to make sure it's Always Tight !
fietsbob is offline
Old 06-16-19, 09:53 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 667 Post(s)
Liked 47 Times in 40 Posts
https://neloscycles.com/Other-Wing-Nuts/
dedhed is online now
Old 06-16-19, 03:28 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 536 Post(s)
if this was cheapish I would just do that!
I did a blanked over the tailgate today and it worked great for running across town but over the road travel that probably isn't great for so I did bike the bullet and order the TOPLINE mount. Will that a try.
thanks
sdmc530 is offline
Old 06-16-19, 05:31 PM
Geekage
Quoted: 16 Post(s)
Liked 5 Times in 4 Posts
Would something like a hitch platform mount in the bed work for you?
I'm sure there are other makes, I just know about this one since I've got their hitch platform rack. If you like Thule, they've got the Insta-Gater.
Etcetera, etc.
Geekage is offline
Likes For Geekage:
Old 06-16-19, 07:29 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 536 Post(s)
that is pretty cool. If my other option doesn't pan out I will check into those. I like that
sdmc530 is offline
Old 06-17-19, 08:27 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
A slab of plywood on the pickup bed bottom , allows DIY solutions, if money is an issue..
block of wood with another QR axle through it .. fixed to the plywood , etc..
fietsbob is offline
Old 06-17-19, 09:36 AM
Squeeze
High Plains Luddite
Bikes: '90s MTBs, '96 Allez
Quoted: 144 Post(s)
I am considering a small pickup as my next vehicle. I've seen those tailgate pads and have always wanted to ask this:
Do you just set the bike there and hope gravity keeps it in place, or do you also strap down the frame of the bike inside the bed with bungee cords or similar tie-downs?
Squeeze is offline
Old 06-17-19, 11:07 AM
jadocs
jadocs's Avatar
Quoted: 308 Post(s)
I have a Retrax roll top cover that I butt up against the rear tire so the bike isn't going anywhere....but to answer your question, it is always a good idea to secure the rear wheel in the bed. I have only used this method on my FatBike when I'm too lazy to put the bike rack into the hitch for a quick trip to ride. I would not use this method on my road bike.
jadocs is offline
Old 06-17-19, 12:35 PM
Squeeze
High Plains Luddite
Quoted: 144 Post(s)
Thanks, @jadocs.
Squeeze is offline
Likes For Squeeze:
