Am I S.O.L.?
Am I S.O.L.?
Old 08-08-05, 04:18 PM
Toefuzz
Am I S.O.L.?
I went for a ride last last week and fell after getting sucked into a soft shoulder... I took the bike out for the first time since the fall and noticed it was shifting funny so I brought it home, opened up Zinn's, and began working on my bike for the first time. After playing with the front derailur for a few minutes I noticed the frame was bent... remembering some posts I've browsed earlier I realized what a problem this could be. I'm riding a Trek 1000c and have attached a few pictures. Could ya'll take a look and tell me if I have reason to be concerned It is an aluminum frame and as best I can tell, the front derailur got twisted in the fall and somehow bent the frame... seems like it would take a lot of force to do that, but I couldn't have been going more than 9 or 10 mph. I've only had the bike for a month or two... is this something Trek will cover?
Toefuzz is offline
Old 08-08-05, 04:28 PM
Nightsky565
Nightsky565's Avatar
I would say that it is safe to ride it... Phone trek, see what they can do. I ride a bike that has a dimple in the frame much like that, works fine.... Phone trek for sure though if you just bought it 2 months ago, trek is known for being nice to deal with.
Nightsky565 is offline
Old 08-08-05, 04:32 PM
Toefuzz
That's what I was hoping to hear... My primary concern is that I am a 'full figured' guy and am putting quite a bit of weight on the bike... not sure if that matters or not.
Another question, should the derailur rotate around into the frame that easy?
Toefuzz is offline
Old 08-08-05, 04:35 PM
The Carpenter
I agree with the part about calling Trek. I have had great experence with their customer service. If you have/want to replace the frame, I think they have a frame replacement deal that is really good. When you call Trek, don't be surprised when they tell you to take it to your dealer for evaluation.
The Carpenter is offline
Old 08-08-05, 04:36 PM
Toefuzz
I bought the bike at an out of town dealer (near my in-laws)... My wife is heading down there Wednesday, should I have her take the bike or just head to a local Trek dealer?
Toefuzz is offline
Old 08-08-05, 04:39 PM
sorebutt
Über member!
sorebutt's Avatar
Bikes: 2004 Albert Eisentraut
From what the pictures show, the frame is probably safe to ride, assuming the frame is still straight and true.
The only problem I could see if that the new front derailleur may not clamp on the the tube as well because it is not a prefect round... give it a try and see...
sorebutt is offline
Old 08-09-05, 05:08 PM
Milice
Milice's Avatar
Quoted: 13 Post(s)
Toefuuzz, I dont think you are SOL. I ride a 2004 trek 1000 and the is a indent put there by trek. It is to give clearence for the tripple frt derailur. I noticed this on my bike a while back and thought somehow I managed to get a dent there. No chipping of the paint or scratching I figured why worry if its going to fail ill ride it till it does. And tehn I put it out of mind. After reading your post i looked at it again. No different. Had to go by the LBS on my ride today was out of gu. While there I pulled 2 different trek 1000's out of the rack and looked at them.ump in in the same place. Asked shop owner about it and he said a couple of different companys do that to use larger diameter tubing and still have clearence for frt derailur. Hope the helps.
Milice is offline
ljonny18
4
08-09-14 02:03 PM
DVC45
6
06-17-09 12:43 PM
Xrisnothing
Road Cycling
7
03-29-07 09:29 PM
wxlidar
Road Cycling
13
03-02-07 08:50 AM
musicqueen74
General Cycling Discussion
15
04-28-05 03:22 PM
