Tout Terrain Panamericana?
Old 01-14-07, 01:18 PM
vik
cyclopath
vik's Avatar
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
Anyone own, ridden or seen any reviews on this bike?
http://www.peterwhitecycles.com/tout-terrain.asp
safe riding - Vik
VikApproved
vik is offline
Old 06-23-07, 09:42 PM
CHenry
Bikes: A bunch
No as of yet: German-made Tout-Terrain Panamericana bike frame, and with the exchange, very pricey. In the USA, Peter White Cycles is the importer. You might email them for reviews info. If anyone could give you direction it would be Peter. Just guessing, that setup pictured would run well over USD 6,000. Lots of top-end complete tourers could be had for much less, included fully suspended with Rohloff and disc brakes, so this bike will never be common.
CHenry is offline
Old 06-23-07, 10:50 PM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 235 Post(s)
Liked 9 Times in 8 Posts
43cm chainstays
seeker333 is offline
Old 06-24-07, 01:24 AM
NoReg
The only really noteworthy feature is rear suspension being integrated to allow a rear rack. It does look as though the rear rack will move around a lot for all that thought provoking engineering. I suppose it doesn't move so much as to disturb the attachment. Overall I would probably bet on a front suspension bike with the fanciest seat post suspension before this idea, or a very serious cantilever system with a rear suspension, I have that on a recumbent, and it works fine. I'd like to test drive one, they are cool.
Sakkit was working on a suspension bike, not sure whether he worked anything out though. He would for sure sweat the rack and panier details though.
NoReg is offline
Old 06-24-07, 09:04 AM
CHenry
Bikes: A bunch
Makes it more of an XC MTB. For that price, you are in Nicolai territory.
CHenry is offline
Old 06-24-07, 05:39 PM
pmseattle
pmseattle's Avatar
Interesting but perhaps over-engineered. The other bike from the same manufacturer, the Silk Road, looks a little more practical, but still very pricey.
pmseattle is offline
Old 06-25-07, 01:26 AM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 235 Post(s)
yeh its a mtb - with the long top tube length almost no one could comfortably fit a drop bar and reasonable length (90 mm min) stem
the chainstays are nearly standard length for a mtb too - you'd think a bike with integral rack would have chainstays long enough to avoid pannier heel strike. its not well designed for this reason alone.
Old 04-16-08, 02:05 AM
oli.roemer
Hi everybody, I know this thread is kind of old, but there is a review available in UK magazine of the Panamericana.
http://www.tout-terrain.de/cms/front....php?idcat=135
There are quite a few concern adressed mentioned in this thread.
Cheers, Oli
oli.roemer is offline
Old 04-16-08, 10:06 AM
vik
cyclopath
vik's Avatar
Cheers, Oli
I'd be interested in reading the review, but I think you posted the wrong link????...
safe riding - Vik
VikApproved
vik is offline
Old 04-16-08, 10:17 AM
GeorgeBaby
GeorgeBaby's Avatar
Bikes: 2005 Bike Friday NWT, 2008 Robert Beckman, Thorn Nomad MK2, Bacchetta Giro 26
The first time I clicked on the link, I went to the main tout terrain page, but after that, I got the PDF, so I suspect some sort of cookie is involved. Try accessing it again.
GeorgeBaby is offline
Old 04-16-08, 10:43 AM
stevage
Bikes: Specialized Tricross Sport 2009
Like the idea of integrated rear rack. But you miss out on stuff like the Topeak MTX click-in system.
Anyone ever tried touring on dual suspension?
Steve
stevage is offline
Old 04-16-08, 10:47 AM
vik
cyclopath
vik's Avatar
Got it...thanks for the tip....
Well after reading that review I'm left thinking the reviewer missed the boat on a few of his observations/comments:
- on most suspension systems you cannot run them fully loaded without air or replace a suspension shock with a solid member. The design of the frame/fork assumes the impact forces from the wheels are absorbed partially by the spring. Without the spring in place [in this case air pressure] you would be transmitting much higher peak loads to the bike/fork and I would be surprised if you didn't permanently damage it riding fully loaded on a rough track.
- if your hydraulic disc brakes fail replacing them with V-brakes is a poor solution. It assumes you have rim brake surfaces on your wheels and you are carrying two spare v-brakes, cables and suitable levers. You really have to ask yourself why not mount the v-brakes to start with and carry a couple spare cables and pads????
- 12 pivot points???...yikes...no matter how well sealed they are going to need attention on a long off-road/dirt road tour.
I'm a technology geek, but this bike and Africa are not two words I'd use together. The failure of suspension components on the Great Divide Trail Race highlights how tough even non-technical long distance riding can be off pavement and the GDR guys are not carrying heavy loads.
I think the Thorn EXP with wide tires is a much more reliable and proven solution.
safe riding - Vik
VikApproved
vik is offline
Old 04-17-08, 02:09 AM
oli.roemer
We have toured with the Panamericana, also in Africa.
some commets from my side:
There is no comparison between a wide tire and real suspension. The comfort of a wide tire with little air is really nice if you do gravelled roads, but it rolls not too good. The suspended bike can run at full tire pressure with low resistance and still be really comfortable. In really off-road terrain, especially with full cargo load, you dont want to go back if you have experienced the full suspended touring.
for the hydraulic disc brakes: the disc brakes are so much more reliable than cantilever. the key question is really, why do you want to brake on a rim, that is at least as crucial as a brake. you weaken the part that you ride on, which also carries extreme loads and gets (at least on an unsuspendend bike) all the bumps. the question is, how often did you break a hydraulic hose? in mountain biking disc brakes are the standard now, just because they have so many advantages (e.g. brake power, espcecially in wet conditions; no rim wear)
Of course new advanced technology always bears a certain risk, but the rohloff hubs shows, where this can lead to - 5 years ago also everybody was afraid of failure and now a lot of people just love it.
Old 04-17-08, 07:25 AM
vik
cyclopath
vik's Avatar
Nice - you wouldn't have any pictures online would you? How long was your tour?
I've never broken a hydraulic hose because I don't use hydraulic brakes. I also haven't had any issues with rim brakes. They work well and any problems are easily repairable most places in the world since they are ubiquitous. I agree disc brakes do have some advantages in muddy or winter conditions. I guess you have to decide how often that will be part of your tour. I do use and like disc brakes for some of my bikes, but I think that people give them more credit than they deserve and underrate rim brakes.
Well your Rohloff issue is exactly my point. There was a tourist recently who had his Rohloff hub flange crack in Tibet. Where he had to wait for a spare to be shipped to him. There were donor MTBs with dérailleurs available, but if you are using a very specialized bike with an IGH and no dérailleur hanger you can't make any field repairs. You can only get to a spot that accepts FEDEX and wait.
Having owned several full suspension mountain bikes my experience with them is they are indeed wonderful and tame a rough trail in a way no fat tire/rigid bike can, BUT it isn't a question of if they'll need to be fixed and parts replaced - just when.
Perhaps with FEDEX reaching more and more parts of the globe these days this isn't an issue any longer????
safe riding - Vik
VikApproved
vik is offline
Old 04-17-08, 10:13 AM
skookum
cyclotourist
Quoted: 151 Post(s)
I held off on a rohloff for several years because of this issue, I finally bit the bullet and bought a thorn last year. Of course, since then I have become aware of not one but several failures of the hub flange on rohloff hubs.
I agree with your points on disk brakes and full suspension on touring bikes.
skookum is offline
Old 04-17-08, 05:07 PM
vik
cyclopath
vik's Avatar
I actually just bought a Rohloff myself. I've been quite critical of them for expedition touring bikes based on their highly specialized nature and a lack of spare parts except from a handful of specialty shops. But, they sound quite cool and I can't deny their utility for other applications where you aren't so far from help. I'll be using mine on a Surly Big Dummy cargo bike that will see lots of heavy use so I'll be able form my own opinion. Congrats on the Thorn....
safe riding - Vik
VikApproved
vik is offline
Old 04-18-08, 05:55 PM
skookum
cyclotourist
Quoted: 151 Post(s)
Well thats at least two Rohloffs in Calgary, that I know about.
Do you know anybody else that has one?
skookum is offline
Old 04-18-08, 09:11 PM
vik
cyclopath
vik's Avatar
Nope - I haven't heard of anyone else with one although I'm sure they are here. A city of 1 million has to support more than 2 Rohloff hubs.
safe riding - Vik
VikApproved
vik is offline
Old 04-18-08, 10:30 PM
skookum
cyclotourist
Quoted: 151 Post(s)
Exactly what I was thinking.
skookum is offline
Old 04-18-08, 10:35 PM
vik
cyclopath
vik's Avatar
Since you can't really spot a Rohloff biker from more than 10' away - especially with a chain tensioner - I'm not sure we'll find any of our Rohloff Brethren ...
safe riding - Vik
VikApproved
vik is offline
Old 06-08-12, 01:55 PM
john_isles
Cathy and I just completed a six-month trip on these bikes in South America:
http://www.crazyguyonabike.com/doc/southamericaminitour
In summary, no problems at all with the bikes, tons of heel clearance, super comfy over really rough terrain carrying heavy loads (15 litres of water and full camping gear for a six month trip).
We got lots of envious comments from cyclists on rigid bikes bouncing their way along hundreds of kilometers of washboard corrugated roads.
John I
john_isles is offline
Old 06-08-12, 07:01 PM
positron
I cant speak to the panamericana, but I have a TT silkroad and the bike is amazingly well-constructed and thought out. I would recommend it to anyone. I have used drop bars and flat bars on it and they both work flawlessly. Its a great bike, and Im not surprised to hear that the panamericana was well executed... sounds like a dream trip, congrats!
edit: I swap stems between drop and flat bars... about 30mm (IIRC) difference between the two.
positron is offline
Old 06-09-12, 01:47 PM
Capt_Sensible
Capt Sensible
Bikes: Kona Sutra, Cramerroti 650C
TT have some pretty unique designs. Haven't seen any posts on this one yet; it's a variant of the slik road with a BB mounted transmission.
http://www.en.tout-terrain.de/bicycles/silkroad-xplore/
Capt_Sensible is offline
Old 06-09-12, 10:28 PM
escii_35
Bikes: 2007 C-dale 63cm T series. My 1994 was a better design 1994 Bianchi 61cm El/OS Sachs 2004 Rodreguiz 26' UTB touring thing
Quoted: 37 Post(s)
oops i missed johns post.
I still want to drool all over that mavrick fork w' dyno goodness.
escii_35 is offline
Old 06-12-12, 07:59 PM
myamark
Steve
Hey Steve .I started a tour with a santa cruz nomad with old man mountain racks for disc and suspension.pumped up the rear shock fairly tight and was having a great ride ,mountain bike gearing was great for loaded climbs .comfort was awsome .I was very happy for 9 days then hit the brakes too hard and those hydrolic discs locked up fast and over I went ,landed with a separated shoulder .I still think it was the too strong brakes and sitting way up high that made the situation worse than it should have been
myamark is offline
