Go Back  Bike Forums > The Racer's Forum > "The 33"-Road Bike Racing
Calculating Junior Gearing
Old 01-30-11, 11:59 PM
DRietz
Quoted: 5 Post(s)
Hey guys, I'm attempting to figure out how to do the calculations, or find a gear calculator online for figuring out junior gearing combinations and their respective rollouts.
For example, I'm quite curious if a 50x13 would bring me in under 26feet with 700x24c tires.
I'm getting a new crankset and will need to block gears out from my 11-25 cassette to start, but eventually when I am monetarily able, I'd like to switch to a cassette that'll put me right in the rollout gear without turning my bike into an 8speed.
Thanks.
DRietz is offline
Old 01-31-11, 12:02 AM
thirdgenbird
its in meters, but it should work:
http://www.sheldonbrown.com/gears/
thirdgenbird is offline
Old 01-31-11, 12:31 AM
DRietz
Quoted: 5 Post(s)
8.1 meters with 50x13. Yikes. What a bummer.
DRietz is offline
Old 01-31-11, 12:12 PM
Creakyknees
ride lots be safe
Creakyknees's Avatar
Quoted: 12 Post(s)
calculators are fine for guesstimating but always always always do a rollout check before you get to the race.
Pump up the tires, no rider on the bike, measure twice.
Creakyknees is offline
Old 02-02-11, 02:24 PM
headshock
headshock's Avatar
Bikes: bianchi 928 , avanti pista , fuji track pro, avanti supersprint, caad3
i find this most helpfull
http://home.earthlink.net/~mike.sherman/shift.html
in new zealand we are restricted to a rollout of 6.61 metres which is approximatly 21.6 ft
for under 17
i ride either 39/13
or 53/17
headshock is offline
Old 02-02-11, 02:55 PM
chado445510
Raising the bar
chado445510's Avatar
Bikes: 2007 Specialized Allez Double (sold), 2009 Kestrel RT 800
It does suck, I run a 50x14 now. In order to get the most (as you probably know) you can use 52x14
chado445510 is offline
Old 02-02-11, 02:59 PM
jsutkeepspining
for under 17
i ride either 39/13
or 53/17
wow and i thought being restricted to the 50x14 was lame. what do you spin out at like 25 mph. time trials must be interesting haha.
EDit: actually just checked it out, you would go a little over 27 mph in the 50/17 spinning at 120 rpms.
jsutkeepspining is offline
Old 02-02-11, 10:58 PM
DRietz
Quoted: 5 Post(s)
A 52x14 works but a 50x13 doesn't? That sucks so hard.
I figure I'll get a 13-26-ish cassette and block one for races. What a bummer.
DRietz is offline
Old 02-03-11, 09:26 AM
YMCA
starting pistol means war
YMCA's Avatar
Bikes: Cervelo R3
Why don't you just buy a 45t and run 12-??
It's what most other juniors do out there, instead of blocking gears.
YMCA is offline
Old 02-03-11, 10:18 AM
carpediemracing
Bikes: Tsunami Bikes
Quoted: 262 Post(s)
Liked 2 Times in 1 Post
The correct answer is Creakyknees's answer.
Or, if you want to know before you make changes, measure the circumference of your current tire (pumped up, no weight, on bike - mark where valve is on a floor with a line type pattern like a linoleum or tile floor, roll wheel along line until valve points down again, measure in mm if possible).
Now ChainringTeeth/CogTeeth*circumference = roll out. Chainring/Cog gives you the multiplication ratio the actual gear gives you (45x12 to use YMCA's example). A 45x12 is 3.75, i.e. the cog turns 3.75 times for every turn of the chainring (or crankarm).
Remember that usable ratio relies on tire circumference. One very good rider in CT, many years ago, got DQed in the state TT. He won by a couple minutes but he'd fitted an oversize tire on his rear wheel. He (wrongly) assumed that any wheel/tire would work with a 53x15 for the limit, but when he went to rollout his rear wheel consistently failed by probably half a centimeter (or some minor thing like that). He was duly DQed.
What was frustrating about his experience was that he didn't need that - he was so good that he started carrying a spare tire in the TT because he could have a flat, stop, change it (tubular), keep going, and still finish with a reasonable expectation of winning the TT by a minute or so. He flatted one year and didn't finish, and based on his prior multiple minute winning margin he should have been able to change the flat and still win.
Remember that the gear limit really has to do with your tire's circumference. The gear is simply an easy way to refer to a given gear in a language others understand.
"Dude, what's your biggest gear?"
"7.465 m"
"What?"
"Well, it's 7.452 if I use that other wheel."
"Huh? What are you smoking?"
vs
"53x15"
"Oh. I'm running a 49x14"
"Oh."
cdr
carpediemracing is offline
Old 02-03-11, 12:26 PM
DRietz
Quoted: 5 Post(s)
Aki, that's exactly what I was seeking. Thank you very much!
DRietz is offline
Old 02-03-11, 06:41 PM
chado445510
Raising the bar
yes, i believe the rule of thumb is one tooth in the rear = 3 teeth in the front
Old 02-04-11, 07:29 AM
YMCA
YMCA's Avatar
Bikes: Cervelo R3
53x13 = 49x12 (4 teeth)
42x21 = 40x20 (2 teeth)
As you can see, your 3-tooth "rule" is just an avg.
I know on the hardest gears currently used it can be 5 teeth per cog.
YMCA is offline
Old 04-20-19, 09:37 AM
Mike_Sherman
Bikes: many
Re: Mike Sherman's gear calculator
Hello, I just wanted to spread the word that, because of ISP issues, I have moved the calculator to GitHub.
Because this account is new, I'm not allowed to post a link, but you can message me and I'll send the links.
I'm also working on a new version to try to make the program friendlier on small screens.
-Mike
Mike_Sherman is offline
Old 04-22-19, 08:01 PM
ToddTheBod
ToddTheBod's Avatar
Yes definitely be careful with this "rule". It's really only applicable for stuff in the 84-100" range, applied anywhere else and you're gonna have a bad time
ToddTheBod is offline
Old 04-25-19, 12:37 PM
Bikeracer123
Bikeracer123's Avatar
Bikes: 2016 Fuji Roubaix Ultegra 2014 Cannondale Supersix Black inc
Quoted: 130 Post(s)
52/14 is the closest you’ll get to 26ft and it’s what most of us juniors (or atleast that I race with) run.
Bikeracer123 is offline
Old 04-25-19, 05:41 PM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 599 Post(s)
Liked 21 Times in 17 Posts
It really does depend on the wheels/tires.
52/14 is what my son has run for years. It is what I have set every junior I can up with. Getting a junior cassette and getting the right chainring can really help a lot of things. My son has 10 full gears and 2 full chainrings.
Every year at the first few races I have officials sending dads over with that scared look on their face "they said you need to block few out." and everytime there's at least one junior who has a 50t crank and an 11-25 cassette. "Sorry - your limit screw won't let me block out the bottom 3". At least if I am in the shop I can find a longer screw.
Seriously though just put 26' on the ground and check before you get there. With the right pressure in the tires.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Old 04-25-19, 05:57 PM
caloso
Packfodding 3
caloso's Avatar
Quoted: 1811 Post(s)
Liked 129 Times in 78 Posts
I went the 45x12 route with my son. That allowed me to share wheels between his bike and mine. But it's super close to the limit. 25mm tires might put you over. So use a 44t front ring just to be safe.
caloso is offline
Old 04-26-19, 04:26 PM
ToddTheBod
ToddTheBod's Avatar
FWIW, Wickwerks makes 41-33 chainrings specifically for juniors. 41-11 is closer to 26 ft than 52-14, and then lets you use 11-N cassettes.
Old 04-27-19, 04:58 PM
Doge
Doge's Avatar
Bikes: 1979 Raleigh Team 753
Quoted: 2930 Post(s)
Liked 36 Times in 28 Posts
Originally Posted by Bikeracer123 View Post
52/14 is the closest youíll get to 26ft and itís what most of us juniors (or atleast that I race with) run.
My kid started with thin tires and a 53X14 would work. We later changed. I pushed RECON to create a junior (14T) cassette which he did and sells a lot of them. They are solid alloy. They do not shift as well as a Shimano, but are half the weight.
The Euro 15-16 kids race with 52X16.
Doge is offline
Old 04-27-19, 05:00 PM
Doge
Doge's Avatar
Many of the SoCal kids, and ones at nats are riding parent hand-me-downs or getting used stuff on eBay.
I don't, never have used an 11 as an adult and have a 12 on the tandem. They are sold because people buy them, I don't really see the use.
Doge is offline
identityrichie
Bicycle Mechanics
4
10-12-14 10:47 AM
electrik
Bicycle Mechanics
6
04-14-11 04:50 PM
bluevelo
Foo
3
05-02-10 10:18 PM
Rockstarex2
BMX
1
06-04-08 11:02 PM
Enzo Gucci
Southern California
5
11-03-07 07:14 PM
