Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Track Tire Questions
Old 12-06-18, 08:38 AM
  #376
Morelock
Morelock's Avatar
Quoted: 185 Post(s)
I've read the "cleans up with water" is greatly exaggerated. Some reviews seem to be of the very first batch of it and didn't sound great, but now it seems better(?) - but no info specific to track.
I was taught the old school glue procedure when I got into cycling (3 layers, day between, etc) and although I know people have success with the faster, less hassle ways... I'm kind of stuck in my ways now
Morelock is offline
Old 12-20-18, 08:28 AM
  #377
Kaben
Kaben's Avatar
Quoted: 57 Post(s)
Now that they have been out for a while, has anyone got any thoughts on the Vittoria Pista G+ Speed tubulars?
See some for a good price, just wondering what their durability is like. Im primarily riding indoors but will be doing the odd outdoor sprint on a tarmac velodrome and wondering if they will be able to do double duty. The more robust CS versions are a-lot more expensive at the moment.
Thanks in advance.
Kaben is offline
Old 12-20-18, 10:04 AM
  #378
Morelock
Morelock's Avatar
Quoted: 185 Post(s)
In general, the Speed G+ line (as a whole) is, in my experience, just a bit less durable than the old Corsa Evo Pistas. They should handle some outdoor rides, but you really need to check them after every ride if you do. It's easy to pick up small nicks in the tread. Carry the bike to/from the track. I've had Evo's last a season+ on outdoor tracks that are by no means "nice." I have some G+'s waiting to be glued up and expect similar, but make no mistake, they are 100% race day tyres.
Morelock is offline
Old 12-20-18, 10:52 AM
  #379
Kaben
Kaben's Avatar
Quoted: 57 Post(s)
Yeah - they definitely would be race day only. I just bought a FFWD rear disc and they will be going on that.
My current wheels ( and what will continue to be my front wheel in combination with the disc) are shod with Continental Tempo II tyres. These are pretty decent but i thought i would opt for something a bit nicer for the disc. I usually run the Tempos on the rollers before a session - they seem to be robust enough and not having to carry training wheels everywhere makes a big difference to travel convenience.
Ive always had matched tyres in the past - any issue with having mismatched front / rears if they have different max PSI or grip for example?
Kaben is offline
Old 12-20-18, 04:28 PM
  #380
taras0000
taras0000's Avatar
Quoted: 305 Post(s)
Liked 4 Times in 4 Posts
Not really, unless you are running tires that are very far apart in their inherent qualities. You also want to match tires to your preferred/most used track.
On a shallow, outdoor concrete track, you might want to run tires that trend closer to road tires in qualities. Something a little bigger, durable, and lower psi if it's bumpy and you're not pulling more G's in the turns. A steeper wood track would require a more supple casing, softer rubber, and a higher psi. Here you're looking to mitigate tire squirm to give you better feedback and more predictable handling.
I "mismatched" tires all the time to dial in what I needed/preferred from each tired based on being front or rear. The front tire on a track bike sees more forces placed upon it the steeper the track. I would put a softer, higher psi tire on the front for steep tracks for this reason. For shallow tracks I didn't really care what tire combos I was running because it's harder to get a tire to its limits on a big shallow track.
taras0000 is offline
Old 12-20-18, 05:04 PM
  #381
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 234 Post(s)
Interesting. I had the opposite impression, though of course it's a slight difference as both tires are very, very light. I have a Speed on the front and an old EVO Pista on the rear, and to my eye the tread seems a hair thicker on the Speed, and the Speeds seem to have some kind of minimal coating on the sidewall, while the EVO's are bare. Whether this translates into any practical difference in durability is, well, who knows.
Baby Puke is offline
Old 01-24-19, 02:23 PM
  #382
700wheel
Quoted: 118 Post(s)
World Cup VI from Hong Kong
World Cup VI has started with team pursuit qualification – results here (also program schedule):Tissot UCI Track Cycling World Cup VI | Tissot TimingThe USA team had the 2nd fastest time. The Olympic Channel looks like it will stream the event starting Friday at 18:30 Hong Kong time (which I calculate to be 03:30 MST)https://www.olympicchannel.com/en/sports/cycling-track/
700wheel is offline
Old 03-20-19, 04:54 PM
  #383
joe19582001
great
excellent tips on tires
joe19582001 is offline
Old 06-18-19, 07:16 AM
  #384
bartek.
Quoted: 55 Post(s)
Seems like there is a new top top in 2019, the Conti GP 5000 with a pretty nice rolling resistance. Has anyone already tried them?
Thinking to use them with Mavic Ellipse for trainings. Going to use them with a latex tube.
I'm just wondering what do you guys suggest as a rim tape? Shall I use the bundled nylon one or there are better options, especially in connection with latex tube?
I'm also really interested in comparison between the GP5000 and Veloflex Record in open tubular version. The Records are about 25% lighter and takes up to 145 psi but the GP seems to be really really fast one. I am curious which one would be faster for a summer league :-)
Speaking of pressures. A tubular version of the Record has also 145 psi max. It is not much for track tubulars. How much pressure do you give this tubular?
bartek. is offline
Old 06-21-19, 12:37 PM
  #385
jeffmendoza
Hi, noob here. I'm taking in intro-to-track class this weekend. Fortunately my neighbor gave me some of their left over tires: 2 pairs of Vittoria Open Corsa, and 1 pair of Veloflex Corsa. See the album link for pictures. From doing some reading, these look like very nice, but slightly old tires. Hopefully a significant upgrade. One of the Corsa SR's has a hole though. Anything else I should be concerned about? Thanks!
https://imgur.com/a/5GWaCF7
jeffmendoza is online now
Old 06-24-19, 12:34 PM
  #386
carleton
Elitist
carleton's Avatar
Quoted: 1205 Post(s)
It's difficult to diagnose tires from here. If they are hard and not sticky, then you will slip down a steep track. Period. Doesn't matter how nice or expensive they are new.
If your track is shallow, you could be fine.
Again, it's a judgement call.
To be safe, buy new.
carleton is offline
Old 06-25-19, 10:11 AM
  #387
jeffmendoza
Thanks for taking a look. The track here is concrete and shallow. I tried out the Veloflex's for the class, and they were great. I don't have much to compare to though. I'm looking forward to getting started with the beginner racing.
Old 07-07-19, 08:41 AM
  #388
topflightpro
topflightpro's Avatar
Quoted: 1223 Post(s)
Liked 20 Times in 14 Posts
Anyone have any insight on how long Pista Speeds hold up on a rough concrete track, like Rock Hill?
topflightpro is offline
Old 07-08-19, 09:18 AM
  #389
Morelock
Morelock's Avatar
Quoted: 185 Post(s)
At Rock Hill they'll last a little bit, might make it a season for you (mine lasted 2 1/2 ish, but you are there more than I am) but you'll just have to watch them. It's hard to say as there isn't really anything on the track itself that will chew through them too fast, but it really only takes one day nobody swept before you hit the track and you hit some debris that nicks it.
Fwiw I have used a Pista speed on the road before in a TT. (and even once at Dick Lane, which is probably worse than the avg road ) and been pretty lucky.
The rear will probably wear faster than the front just due to your weight distribution.
Morelock is offline
Old 07-08-19, 11:04 AM
  #390
jfiveeight
Quoted: 23 Post(s)
I have been on a Pista Speed Graphene 1.0 for 2018 and 2019 so far, about 10 races per year. I also have pulled it 3 or 4 times so it's seen some wear. Race on Northbrook (epoxy concrete) and Major Taylor (rough concrete). Seems to have held up pretty well so far. I think a full season of enduro life as a race only tire is possible.
jfiveeight is offline
spectastic
Bicycle Mechanics
4
07-05-19 06:39 PM
Aushiker
Recumbent
6
07-06-13 05:00 PM
James J
0
06-04-11 02:11 PM
phantomcow2
Foo
0
09-26-08 02:08 PM
alwaysbefirst
Road Cycling
1
07-25-05 03:26 PM
