Racer Tech Thread
Old 07-16-14, 07:25 AM
  #76
carpediemracing
Bikes: Tsunami road bikes, Dolan DF4 track
Quoted: 385 Post(s)
Liked 180 Times in 102 Posts
Originally Posted by ips0803
Do you use loctite when pressing the bearings? It will potentially solve your issues as long as you have a good enough press to keep everything square.
Yes, and I've tried grease also. I've used different tools, depending on the situation. I have the BB30 tools from Cannondale and the current install was done by a shop using a proper BB bearing press thing.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
carpediemracing is offline
Old 07-16-14, 07:49 AM
  #77
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
The only Loctite product that should be used for BB30 installation is retaining compound. Do not use traditional Loctite thread locker products. With no threads, they are useless for this application. You need retaining compound, which is designed for exactly this application, retaining bearings and bushings in machined surfaces. I use Loctite 603, green, which is a medium strength compound, applied in four equally spaced dots inside the BB shell. No creaks, and the bearings pop right out after a couple of whacks with the Park tool. I don't understand why a BB30 shell would need to be faced as the outer edge is not involved like with a threaded BB shell.
shovelhd is offline
Old 07-16-14, 10:11 AM
  #78
carpediemracing
Quoted: 385 Post(s)
Thanks for the green Loctite explanation, helps. I used blue and red at different times, but those are thread related compounds.
Machining - the Tsunamis are aluminum frames and the BB shell was machined prior to welding, not after. This leaves the shell significantly distorted. I could see daylight outside of parts of the bearing and in other spots the bearing simply wouldn't go in. I filed the tight spots but without any precision. With the facing tools it's a bit better but the stretched parts are obviously not going to shrink.
I was even thinking of having a machine shop machine some thin steel cups to slip into the appropriately machined BB shell. This way I'd know the bearing seat surfaces were parallel/perpendicular. With the facing tool work it's been much better so I've left it for now.
WIth mass production frames the shell is machined after welding.
Old 07-16-14, 10:17 AM
  #79
ips0803
ips0803's Avatar
The steel/aluminum interface may corrode pretty quickly.
Loctite 641 works well for BB30 bearings
ips0803 is offline
Old 07-16-14, 10:19 AM
  #80
carpediemracing
Quoted: 385 Post(s)
Sorry, not faced. Reamed.
https://www.parktool.com/product/ream...ket-shells-752
Old 07-16-14, 01:13 PM
  #81
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
I haven't had any corrosion issues. 641 looks like it has more filler. Should work fine.
shovelhd is offline
Old 07-16-14, 05:55 PM
  #82
Cleave
Old & Getting Older Racer
Cleave's Avatar
Bikes: Bicycle Transportation: 2022 Hyundai Kona Electric, 2019 Kia Niro Plug-In Hybrid
Quoted: 41 Post(s)
Liked 8 Times in 5 Posts
Originally Posted by Hermes
Remove the the seat and seat post and stand the entire race.
Originally Posted by tetonrider
awesome. i generally do a ride per week where i remove my saddle, but that's just because i like the feeling. ;-)
i think i'm going to go with a unicycle instead.
Originally Posted by carpediemracing
There's a guy that used to do the Gimbels ride with no post/saddle. I think he was featured in some local paper article. I tried to stay away from him.
Real bike racers like Cindy Whitehead win 50 mile mountain bike races with 7,500 feet of climbing without a saddle.
Thanks.
Cleave
"Real men still wear pink."
Visit my blog at https://cleavesblant.wordpress.com/
Lightning Velo Cycling Club: https://www.lightningvelo.org/
Learn about our Green Dream Home at https://www.lawville.org/
Cleave is offline
Old 07-16-14, 07:05 PM
  #83
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
My English threaded square taper Campy BB is going strong year after year
Homebrew01 is offline
Old 07-16-14, 07:12 PM
  #84
Enthalpic
Killing Rabbits
Quoted: 278 Post(s)
Liked 217 Times in 102 Posts
I'm getting a slight tick like noise when I press down on the non-drive side crank arm. It's always at the same degree / position (9 to 10 o'clock).
I've checked my shoes, cleats, pedals and today got the shop to remove/clean/re-grease/repress the bb30 bearings. The mechanic said the bearings were fine but the junction was very dirty.
Tonight I test rode and the noise is exactly the same so I'm starting to wonder if the problem is bb30 creak after all. I would imagine the service would have made some difference if that was the problem. In the past when threaded bb's creaked I could create the noise on either side with sufficient force like stomping on the pedal when at bottom dead centre. In this case I can't make a noise with any amount of pressure to the drive side but can still make the non-drive side tick even with a single leg drill.
Ideas?
Enthalpic is offline
Old 07-16-14, 09:49 PM
  #85
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
Liked 4 Times in 4 Posts
skewers and pedals.
Ygduf is offline
Old 07-16-14, 10:22 PM
  #86
jmikami
Bikes: Veloforma for my primary.
Ideas?
Every time that happens to me it is the same drill. Take off pedals, crank and BB, greese and reapply. Could be any one of the three, and it is just as fast to do them all versus test out and try to figure what went wrong. I don't always take the BB all the way apart depending on the type. Seems to come back once or twice a year for me.
jmikami is offline
Old 07-17-14, 06:01 AM
  #87
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
Chainring bolts.
shovelhd is offline
Old 07-17-14, 06:11 AM
  #88
Wylde06
Wylde06's Avatar
Bikes: Cannondale Six13
Quoted: 140 Post(s)
Liked 58 Times in 21 Posts
Originally Posted by Ygduf
skewers
95% of the creaks on my bike come from this.
Wylde06 is offline
Old 07-17-14, 07:32 AM
  #89
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 678 Times in 429 Posts
I have a set of Reynolds DV46 wheels, and I am starting to upgrade my wheels to 11-speed. (I am not switching to 11-speed yet, but I figure I might as well start slowly upgrading wheels to spread out the cost.)
Does anyone know if I can use a DT 240 freehub body or do I need to get the Reynolds specific one?
Reynolds claims it's a DT 240 freehub built specifically for Reynolds, but it looks just like a regular 240 freehub body. And it wouldnt' be the first time a manufacturer claimed such a thing.
topflightpro is offline
Old 07-17-14, 09:44 AM
  #90
ips0803
ips0803's Avatar
I meant if CDR pressed a steel sleeve into the aluminum bore. I guess in theory with the aluminum material being much more mass it shouldn't be severely galvanic.
I actually replaced my bearings last night. They didn't click but were getting rough. Actually didn't realize how bad they were until the new ones were in.
Took out enduro steels and put in Phil Wood steels so we will see.
ips0803 is offline
Old 07-17-14, 10:14 AM
  #91
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
Then he would have to ream it oversize and use a non standard bearing.
BB's take a lot of abuse for such a simple device. I've only has this frame for two years and replaced the bearings twice.
shovelhd is offline
Old 07-17-14, 11:19 AM
  #92
ips0803
ips0803's Avatar
Depending on material he could ream oversize, then press in back to standard bearing OD.
Not advocating this, he just mentioned it above.
ips0803 is offline
Old 07-17-14, 11:30 AM
  #93
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Quoted: 967 Post(s)
I installed the Hylix saddle today. Only saved me 20g, but I kind of prefer it. So smooth, no seams. Time will tell.
Ygduf is offline
Old 07-17-14, 11:42 AM
  #94
save10
Arrogant Roadie Punk
save10's Avatar
i have this exact same saddle. the smoothness takes some getting used to. i felt like i was sliding off my bike on a descent. but the the comfort part is no issue at all
save10 is offline
Old 07-17-14, 11:56 AM
  #95
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Quoted: 967 Post(s)
I had the toupe pro or whatever the $300 one is. for <1/4 the cost, I figured it was worth trying out. now I can move the pro to my backup ride and take about 2 ounces off that one.
Ygduf is offline
Old 07-17-14, 03:23 PM
  #96
furiousferret
furiousferret's Avatar
Quoted: 842 Post(s)
Liked 469 Times in 250 Posts
I'm in the market for a new bike. Since I have a $300 rebate towards a Madone and a 20% club discount, I'm leaning towards them (though I really like the C'Dale geometry) however right now no one has a 50-51 frame in stock. I'm not sure if they order them or I'm sol until the 2015's arrive. Regardless, I really don't want to special order a bike I haven't ridden.
I'm also stuck on whether or not to go Ultegra Electric or SRAM Red.
furiousferret is offline
Old 07-17-14, 09:39 PM
  #97
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Quoted: 967 Post(s)
Shaved my arms. 14g of hair, wet (but so is sweat, right?)
Ygduf is offline
Old 07-17-14, 11:54 PM
  #98
hack
hack's Avatar
Quoted: 417 Post(s)
Liked 3 Times in 3 Posts
I use an SMP Forma and see that Hylix has a similar shape saddle that is like 1/4 the price of an SMP carbon. May check it out.
hack is offline
Old 07-18-14, 05:15 AM
  #99
Creatre
These Guys Eat Oreos
Creatre's Avatar
Bikes: Yes
Quoted: 13 Post(s)
I want a new bike. I think I'm going to wait until team deals for the next season though. Go SRAM.
Creatre is offline
Old 07-18-14, 06:40 AM
  #100
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
Go tron. You'll never go back.
shovelhd is offline
