straggler for touring?
Old 08-15-14, 05:40 PM
lurch0038
Quoted: 7 Post(s)
Does anyone use a Surly Straggler for light touring?
lurch0038 is offline
Old 08-15-14, 05:57 PM
NormanF
Quoted: 140 Post(s)
Its ok for credit card and light sports touring. If you want to do full on touring, the Surly LHT Disc would be more suitable.
NormanF is offline
Old 08-15-14, 06:10 PM
bikemig
bikemig's Avatar
Quoted: 3607 Post(s)
Liked 62 Times in 55 Posts
The question is why not? If you use a trailer, absolutely.
If you want to mount panniers, the main problem is that the chain stays are not as long as a conventional touring bike. That's not a problem if you do light touring camping with bags mounted on the frame. If you do full panniers and a rack, then I'd think about getting a little longer rack and rear bags that are not too wide so you don't have heel strike issues.
That's typically (but not always) the issue on touring on a bike that is not designed for touring. The advantage of a somewhat shorter wheelbase is that the bike is a bit more responsive when it is not loaded.
Certainly the clearance for generous tires is a plus on the Straggler.
The biggest problem you will have is that the stock gearing is less than ideal with a 46/36 crank. Not a problem if you build the bike from a frame. Or you could replace that crank with a double that goes really low like 46/30 crank from velo orange. The 30 inner is not ideal but it is better than the stock 36 tooth inner. Another possibility would be to go with a salsa vaya. It doesn't have the best triple for touring either. The shimano 130/74 triple Salsa uses plays nicely with shimano brifters but it is not, IMHO, low enough for fully loaded touring). But if you don't mind the expense of building a bike from a frame, this could work. Soma makes a monster cross; the Velo Orange Camargue is another possibility.
bikemig is offline
Old 08-15-14, 10:11 PM
nun
Bikes: Rivendell Quickbeam, Rivendell Rambouillet, Rivendell Atlantis, Circle A town bike, De Rosa Neo Primato, Cervelo RS
Quoted: 85 Post(s)
It looks like it would be a good touring bike. You can tweak the gearing if you think it's a bit too high, although 30" isn't terrible depending on the weight of your gear and fitness level. I'm not particularly fit and I've toured in New England with a 36" lowest gear and a light load.
nun is offline
Old 08-16-14, 08:18 AM
chriskmurray
chriskmurray's Avatar
Bikes: Borealis Echo, Ground Up Designs Ti Cross bike, Xtracycle, GT mod trials bike, pixie race machine
Quoted: 8 Post(s)
Just remember for the most part it is simply a disc brake Cross Check and lots of people have toured on a CC. I would not want to do a very long and heavily loaded tour on one but would absolutely do shorter or paved tours on one!
chriskmurray is offline
Old 08-16-14, 09:06 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6833 Post(s)
Liked 211 Times in 176 Posts
Touring is what you do, not the bike you have to own,
fietsbob is offline
Old 08-16-14, 09:50 AM
headloss
Lost at sea...
headloss's Avatar
Bikes: Schwinn Paramount (match), Trek 520, random bits and pieces...
It will work fine.*
What makes a touring bike? What are your needs? The frame is solid and dependable, has rack mounts, has good brakes, is reasonably longish with sufficient chain-stay clearance for panniers (depending on foot size and how you angle the panniers as well as the rack choice), tallish head-tube... what could you gain from a dedicated tourer like the LHT? You might get more rake in the fork for better toe clearance which may or may not be an issue, or for better handling with a front pannier which may or may not be an issue. You might get stronger wheels, but I'm sure the straggler's wheels would hold up under most conditions. The gearing, of course, but the gearing is fine if you are just riding on the C&O and GAP... would be a problem riding across the country? Or maybe not, that depends on your weight, physical condition, and how much weight you are carrying in gear as much as anything. It's not an easy question to answer without knowing more specifics. Where are you riding, how much weight, rider size and proportions, etc.
headloss is offline
Old 08-16-14, 11:55 AM
Brennan
Brennan's Avatar
Bikes: Surly X√, Trek Earl
Quoted: 17 Post(s)
I use a Cross Check for short to mid-range touring with moderate loads. It's been great for me. I'm now using 4 small panniers to spread the load out, and because they are small, I don't have heel strike issues. I've completed a couple tours with a double crankset by installing the smallest inner ring that would fit (34 tooth) coupled with an 11-34 cassette. However, I recently converted to a triple to make climbs that much easier. The best part is the Cross Check provides a livelier ride than the Trucker for general purpose use, which is how it gets used most often.
Brennan is offline
Old 08-16-14, 12:10 PM
vespoli
I just did a self-supported TransAm on a 56 cm CC. Four panniers (Ortlieb classics rollers in back) and a tent. 85-90#s bike and load. I put a nice triple and some 36-hole Dyads on and it performed flawlessly. No heel strike for me or flexing at 150#.
vespoli is offline
Old 08-16-14, 12:16 PM
J.C. Koto
apocryphal sobriquet
Bikes: 2008 Surly Long Haul Trucker "The Truckerino"
Quoted: 7 Post(s)
Very wise words indeed.
J.C. Koto is offline
Old 08-16-14, 12:25 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
a large variety of bikes are under people riding the Pacific Coast every Summer .
fietsbob is offline
Old 08-16-14, 10:26 PM
Nick The Beard
Nick The Beard's Avatar
Bikes: Surly Cross-Check, Torker U-District
I just took my Crosscheck out for its first real, even if it was short, trip and it worked great for me with just two small Ortliebs up front, a small frame pack, a handlebar bag, and the rest of the stuff strapped directly to the frame. We only did 5 days out but aside from adding some cool weather clothes and a sleeping bag (4+ lbs), and a couple more tools and a spare (2+ lbs) I'd say the rig is totally cross country capable.
Bike and all was about 70lbs fully loaded for an unsupported urban to back-country style trip with 3 days worth of food and over 2 1/2 L of water. I don't know how well it would do with a bigger load but I wouldn't want to carry more anyways. The bike did great on paved roads, graded limestone, fireroads, and a bit of overgrown muddy FL singletrtack. The steering was a little slow but the bike felt super stable and the the load was not very noticeable.
I might have bought a Straggler if it was available when I ordered my CC. The slightly more relaxed geo will be a plus, the disc brakes will be a wash, and the only downside I can see is that I've read that it can be tougher to mount fenders and racks on the bad beast but I bet that can be managed.
EDIT: The complete build CC is easier to convert to a triple than the Straggler. I'd also price out a piecemeal build with bar end shifters or Gevenalle/Retroshift levers.
Nick The Beard is offline
Old 08-18-14, 07:39 AM
vik
cyclopath
vik's Avatar
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
I just built up ^^^ this Straggler to replace my LHT as a commuter.
I mostly tour on a MTB these days, but my rear hub can be converted to a geared setup for an easy 1x for light touring.
Over the years I've been touring with a bike it's become abundantly clear to me that light is right for me and heavy does nothing for me so I don't see any problem loading this bike up for a week+ of touring should a road tour appeal to me.
Most definitely.
safe riding - Vik
VikApproved
vik is offline
Old 12-14-15, 04:21 PM
cxteck
Bikes: Surly Straggler (custom built), Salsa Blackborow 1
I reckon it will work just great as a touring bike! Loaded my new build down with ~40lbs this morning and rode in to work (I bring all my clothes in and shut them in my locker on Monday, plus I carry ~8lbs of chains and locks that I leave on the rack throughout the week, add my lunch and big coffee thermos).
The steel frame handled the load like a champ. Supple, stable, it was a dream compared to my X aluminum frame POS. I have the Racktime Addit rack on the back which keeps the load quite low. I have HUGE heel clearance, even though I'm using a decent size set of panniers. These are Swift Industries custom Mini Rolltop Panniers (~30L per pair). I think I could pretty easily fit a much larger bag.
The stated chain stay length is 425mm, but you can add 17mm to that with the horizontal drop outs, making it effectively 442mm, getting pretty close to rivaling the Disc Trucker's 460mm chain stays. An extra inch? Who cares when those truckers have such strange looking geo.
File Type: jpg
cxteck is offline
Old 12-14-15, 04:30 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Its a disc Cross Check .. people tour on those ..
People tour on all sorts of Bikes .. its the trip not the bike
fietsbob is offline
Old 12-14-15, 04:37 PM
Squeezebox
Quoted: 760 Post(s)
So what panniers and racks are you using?
Thanks!
Squeezebox is offline
Old 12-14-15, 04:43 PM
Squeezebox
Quoted: 760 Post(s)
I'ld like to see some gear lists of fully loaded folks, Really not trying to be pissy! Fully loaded reminds me of stumbling out of a pub in Hollyhead, and taking a hour in the cold to finally find my tent, only a mile away.
Old 12-14-15, 04:45 PM
mdilthey
mdilthey's Avatar
Bikes: Nature Boy 853 Disc, Pugsley SS
Quoted: 251 Post(s)
Most definitely.
Gorgeous. What chainring is that?
mdilthey is offline
Old 12-14-15, 05:22 PM
vik
cyclopath
vik's Avatar
Thanks
That's a random Blackspire chainring that I happened to have in my parts bin that fit the Race Face crank.
safe riding - Vik
VikApproved
vik is offline
SingingSabre
Foo
3
11-08-10 07:32 AM
RHOsbrink
Road Cycling
0
10-30-09 08:16 AM
N_C
Advocacy & Safety
0
09-18-06 03:22 PM
