Mud Flap?
Mud Flap?
Old 09-15-14, 04:06 PM
Tandem Tom
Quoted: 223 Post(s)
Liked 4 Times in 3 Posts
Mud Flap?
So I am considering adding mud flaps to our bike fenders. But I would like to make them myself and would like a NICE looking one and a nice installation.
Any suggestions?
Thanks!
Tandem Tom is offline
Old 09-15-14, 04:13 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6833 Post(s)
Liked 215 Times in 179 Posts
LDPE from plastic jugs are fine.. & flat sheet stock is sold... but for prestige there is Berthoud's leather mudflaps Berthoud parts from Peter White Cycles
fietsbob is offline
Old 09-15-14, 05:22 PM
Rowan
Quoted: 1427 Post(s)
Liked 21 Times in 14 Posts
I like black ones. The reasonably heavy duty plastic of 10-litre oil containers you will find in department stores work quite well. You can create your own shapes, it curves quite well to conform with the shape of the fenders and you can make them reasonably long.
However, don't go too stiff. Based on my experience, a good flexible mudflap means you won't break anything should you get it caught on another external object, and it won't break your fender should it get caught up between the fender and the wheel. It also enables you to rest the fork dropouts on the ground when removing the front wheel.
YMMV a little.
Rowan is offline
Old 09-16-14, 12:43 AM
ironwood
Bikes: 1984 Bridgestone 400 1985Univega nouevo sport 650b conversion 1993b'stone RBT 1985 Schwinn Tempo
Quoted: 392 Post(s)
I used stair tread. Rubber is good. some prefer gasket rubber, however I can't find black gasket rubber. Rivendell sells Longboard flaps separately that will fit some SKS fenders. Truck tire inner tubes might also be a source of rubber.
ironwood is offline
Old 09-16-14, 07:37 AM
alan s
alan s's Avatar
Quoted: 1320 Post(s)
Liked 45 Times in 29 Posts
Not sure which fenders you have, but Planet Bike sells mudflaps separately if you want them to look really nice. Other brands may, as well. Zip tie them on.
alan s is offline
Old 09-16-14, 07:53 AM
DCwom
DCwom's Avatar
Bikes: Burley Tandem
Quoted: 17 Post(s)
Any suggestions?
Thanks!
I made a front mud flap from a piece of black vinyl base molding, its flexible & cheap, I was able to buy a single piece at Home Depot, I use wire ties to secure it. Since we only do short tours I don't install my mud flap unless I expect rain otherwise its rides in the panier.
DCwom is offline
Old 09-16-14, 08:37 AM
Tourist in MSN
Quoted: 1235 Post(s)
Liked 11 Times in 10 Posts
I used the black plastic lid from the largest size plastic Folgers container. Two stainless bolts to attach to fender. I have done this on both 45mm and 60mm wide fenders. Looks much better than it sounds. A good scissors can cut the plastic.
Tourist in MSN is offline
Old 09-16-14, 09:41 AM
vik
cyclopath
vik's Avatar
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
Any suggestions?
Thanks!
I like full length mudflaps that reach the ground. I've made them out of milk jugs and rubber stair tread material. Both work fine, but don't look awesome.
I also got a few pairs of Buddy Flaps and for $12 - $14 they are well worth the cost. Very durable and you get some extra reflective material on your bike if you go custom/fancy.
safe riding - Vik
VikApproved
vik is offline
Old 09-16-14, 06:27 PM
wahoonc
Membership Not Required
wahoonc's Avatar
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 66 Post(s)
I have made them out of a variety of materials. I typically like leather on my vintage bikes and some form of plastic or vinyl on my more modern bikes.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"
_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"
_krazygluon
wahoonc is offline
Old 09-16-14, 10:03 PM
Doug64
Doug64's Avatar
Quoted: 767 Post(s)
Liked 22 Times in 14 Posts
+1
Planet Bike mud flap on SKS fender. They cost $6.00 for a pair including shipping. A couple of pop rivets hold them on very securely.
Doug64 is offline
Old 09-17-14, 05:53 AM
Tandem Tom
Quoted: 223 Post(s)
Thanks for the replies! Stopped by the local hardware store, not the big orange box!, and bought a black stair tread. Made up a pattern and cut them out. I used aluminum pop rivets with a backing washer to install them. I just made them from the front. Have enough material so maybe I should make rear ones also.
We just came back from a cross country tour and we are heading out on a short ride on the GAP with relatives who have never toured. Thought this would be a good chance to see how the flaps perform. Also the relatives!
Old 09-17-14, 10:14 AM
robert schlatte
robert schlatte's Avatar
Bikes: Soma Saga, 1980 Schwinn Voyageur 11.8, New Albion Privateer
Quoted: 76 Post(s)
Liked 5 Times in 3 Posts
Please post some photos so we can see take a look at what you did.
robert schlatte is offline
Bill
Road Cycling
9
06-16-18 05:10 AM
Taz4o4
Bicycle Mechanics
3
04-11-15 03:10 PM
scottrich411
8
10-28-14 12:30 AM
Bikerlady05
Road Cycling
6
01-30-09 11:35 AM
tankman10024
Road Cycling
16
05-15-06 08:41 AM
