Swimming in Bike Shorts
Does anyone swim in the ocean with their bike shorts and then keep riding in the wet shorts? I ride out to the beach a lot and always change into swim shorts and then back into bike shorts but would be much easier if I just went in with my bike shorts.
I know I should man up and just try it but I’ve tried riding in a somewhat wet bathing suit and it’s not pleasant and suspect the bike shorts may be be worse.
Bikes: Giant Cypress
Quoted: 20 Post(s)
Liked 10 Times
Hi. I haven't tried it, myself, but I found an old thread about this topic (where others who've swimmed in bike shorts responded), in case it might help you.
https://www.bikeforums.net/general-c...swim-suit.html
Quoted: 174 Post(s)
Liked 177 Times
Likes For Ross520:
Quoted: 3242 Post(s)
Liked 2,089 Times
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Triathletes do it all the time.
Likes For GlennR:
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
Likes For datlas:
Quoted: 318 Post(s)
Liked 149 Times
What's the difference between salt from the ocean and salt from your own body?
The concentration, maybe, not sure.
What's the difference between wet from the ocean and wet from your own body sweat? Nothing, if you're a gusher like me.
Quoted: 18378 Post(s)
Liked 4,512 Times
For our local "Blackberry Century", cyclists are invited to cool off in the pool afterwards, cycling shorts OK. However, I'm also a bike commuter, so I've chosen not to take them up on the offer.
When I wear "bike shorts", they are B&G touring shorts.
plus I frequently wear them as "regular shorts",
plus in swimming.
have been cycling and swimming (or waist deep wading) with them a number
of times, so far - no problems
plus in swimming.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
Super lightweight swim suit tossed into a baggie and then stuffed into rear jersey pocket, was my system.
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
Each summer I will do a slip-n-slide or two on ragbrai and the shorts get soaked.
I choose hot/windy days and the shorts fully dry within an hour.
Quoted: 2952 Post(s)
Liked 3,106 Times
You want tri shorts, not bike shorts.
Sr Member on Sr bikes
As a veteran of many triathlons over several decades, most of which are in salt water, I never hesitate to ride in the same shorts that I swim in. Actually, I fabricate my own tri suits using a nylon/spandex jammer swimsuit. I don't want/need the 'panty liner' holding the extra water. I've never had an issue with chaffing.
Likes For trailangel:
Quoted: 800 Post(s)
Liked 512 Times
As someone who has spend A LOT of time swimming and in pools (not the ocean I'm afraid) I'm fully of the mind to change. Swimming in a sweat shammy just sounds like it would be extremely uncomfortable. And just because the tri-geeks do it doesn't make it right.
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
I went riding with my buddy's brother a while back and we went for a swim in the middle of the ride. We didn't think about it at the time, but my buddy's brother got back on the brooks leather saddle with the wet shorts and the saddle got waterlogged and was all saggy by the end of the ride. I don't know if the saddle ever recovered.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Someday I might try biking in bike shorts.
I have not been tempted to swim in cargo pants.
Bikes: how big is this cell anyway?
The first best solution as mentioned above is a pair of tri-shorts, they don't absorb water and dry quickly. There are seat pads out there that will let you bike in swim shorts (an older tri solution) I do occasionally swim at the end of ride in a local river but it is a one mile hop home. Another thing worth mentioning is swimming in cold water after a long hot ride does effect leg function for a bit, at least for myself, I've climbed out of a
59 degree F river only to have to sit down and let my leg function return to more normal.
