Having trouble in inserting new brake pad into brake shoe.vintage campagnolo
Quoted: 41 Post(s)
Anyone would like to share some technique of inserting new brake pad into Campagnolo nuovo record brake shoe? Thanks.
I have bought new brake pad,which is measured slightly wider than the slot of brake shoe,with about 2.5mm difference, making it seem like impossible to insert into the shoe easily.
Any advice to accomplish this? Thanks in advance.
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
use soapy water and a c-clamp to press it into the holder from one end.
/markp
/markp
52psi
Quoted: 790 Post(s)
Liked 802 Times
Windex or soapy water to reduce friction.
Also www.bikeforums.net/classic-vintage/1216271-advice-changing-brake-pads-vintage-bike.html for previously supplied wisdom.
Quoted: 4513 Post(s)
Liked 6,392 Times
Brute force and hold your mouth just right, easy peasy.
Likes For merziac:
Quoted: 3464 Post(s)
Liked 2,831 Times
Is that a Campagnolo branded pad?
back side does not appear as typical.
I would derust the holder completely, exrust or similar product. Avoid excess friction.
‘On some alternate brand pads, a bit of a chamfer to ease the start helps.
I use a bench vise and once in a while soapy water.
Likes For repechage:
Quoted: 331 Post(s)
Liked 332 Times
Scribe
Get a small triangle file and scribe the pad to fit. I put a bit of resin in there if you over do it but just go slow until it squeezes in snug. Bending old pad holders can easily end in tears whereas pads are cheap and plentiful.
