I've got to ask... mounting tubeless
Old 11-10-23, 09:17 AM
TakingMyTime
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 927 Times in 541 Posts
I recently purchased a new Canyon that came with some very nice tubeless tires (Continental 5000). They came mounted with tubes. Well, on my 2nd ride I got a pinhole flat on my rear tire. After replacing the tube I had a heck of a time getting the tire to mount correctly. For the life of me (2 attempts) I could not get the tire to seat evenly. Fortunately I only had about 4 miles until home so I babied it all the way. Once I got home and was in a more comfortable situation I took the tire off and attempted to mount it evenly. After 2 more attempts of pushing/pulling I gave up. I threw on a new pair of clinchers and they mounted perfectly.
Is there some trick to this, especially when out in the field (using tubes)? They are great tires but if I can't mount them whether at home or in the field I feel like I have $140 worth of good rubber just sitting there. Just for the record I will not be riding tubeless, if I use them it will be with tubes.
TakingMyTime is offline
Old 11-10-23, 09:44 AM
choddo
Quoted: 682 Post(s)
Liked 453 Times in 338 Posts
The trick is to use sealant and plugs rather than tubes. I would not want to attempt even getting 5000 tubeless on and off outside of my garage.
In terms of seating the bead correctly, not had a problem but usually sprayed a bit of soap around the edge of the tyre to get it on so it slides into position quite happily once at about 60-70psi
choddo is offline
Old 11-10-23, 12:35 PM
Barry2
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times in 694 Posts
There are many versions of the Conti GP5000... which do you have ?
Barry
Barry2 is offline
Old 11-10-23, 02:33 PM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1562 Post(s)
Liked 1,734 Times in 974 Posts
What @choddo said. Soapy water around the tire bead helps it seat.
And why you are not running tubeless anyways?
icemilkcoffee is offline
Old 11-10-23, 03:00 PM
grumpus
grumpus's Avatar
Quoted: 501 Post(s)
Liked 436 Times in 335 Posts
If you were already running them tubeless you wouldn't even know you'd had a puncture. Probably.
grumpus is offline
Likes For grumpus:
Old 11-10-23, 03:56 PM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times in 1,020 Posts
Probably because they came setup with tubes from Canyon and TakingMyTime wanted to just try the bike out as-is.
Regarding the difficulty of mounting these tires perfectly evenly at home, does OP have a compressor?
SoSmellyAir is online now
Old 11-10-23, 05:37 PM
frdfandc
frdfandc's Avatar
Bikes: 2013 Jamis Dragon Race
Quoted: 58 Post(s)
Liked 37 Times in 30 Posts
They key to mounting tough tubeless tires is soapy water and either a compressor or a pump that can give a big burst of air at one shot, like the Bontrager TLR Flash Charger.
I have a Flash Charger and it makes tubeless install a breeze.
frdfandc is offline
Old 11-10-23, 06:30 PM
TakingMyTime
I appreciate the input. I really have no urge to go tubeless. I would have been content using these tires (5000 S TR) with tubes but dealing with them in the field was a pain. The reason I asked my question is due to the fact that I have a perfectly good set that is not being used due to my difficulty mounting them properly I was hoping there might be a solution that would work for me.
Thanks.
Old 11-10-23, 06:34 PM
choddo
Quoted: 682 Post(s)
Thanks.
Big fan of standing by the roadside?
Think it’s just a case of them sticking to the rim a bit.
maybe having tubes in there makes it harder for the tyre to seat but I can’t think why. How the pressure affects the tyre is different or something maybe?
choddo is offline
Old 11-10-23, 07:37 PM
Steve B.
Quoted: 3242 Post(s)
Liked 2,087 Times in 1,182 Posts
Thanks.
One thing about tubeless ready rims is they have an upper “shelf” against the inside of the sidewall that is what holds a tubeless tire tight to the rim. You need to install so the beads are on the inner channel initially, else it’s near impossible to get the tire onto the rim. Once you get both beads on, you can push the bead up into the shelf. Then inflate. I too use tubes on my gravel road wheels as It’s just easier for me to deal with tubes. I feel your pain though.
Steve B. is offline
Likes For Steve B.:
Old 11-10-23, 08:47 PM
icemilkcoffee
Thanks.
Umm yes there is a solution. Go tubeless and you won't have to deal with any flats out in the field.
I used to fix flats at least once a month on my 2 kids' bikes (they bike to school). Since I switched their bikes to tubeless they haven't had any flats in ~ two years.
Likes For icemilkcoffee:
Old 11-11-23, 01:55 AM
choddo
Quoted: 682 Post(s)
How do you push the tyre to move outwards on both sides onto that shelf, without pushing it back off?
choddo is offline
Old 11-11-23, 06:15 AM
50PlusCycling
50PlusCycling's Avatar
Quoted: 552 Post(s)
Liked 820 Times in 412 Posts
I’ve run tubes and tubeless, and find that tubes are easier for me to manage. I’ve gotten enough practice changing tubes that doing so is quick and painless. When mounting tires I don’t need soapy water, or a blast of air to spread the beads, or dealing with the mess of tire sealant.
50PlusCycling is offline
Likes For 50PlusCycling:
Old 11-11-23, 07:05 AM
Steve B.
Push and pull to get the beads up onto the ramps. Sometimes CO2 works as a blast to seat the beads.
Steve B. is offline
Old 11-11-23, 07:33 AM
choddo
Quoted: 682 Post(s)
Hmm. Can’t see how the first bit can get both sides on but…
Co2 mention reminded me that I forgot to say I use a pump with a reservoir. Thought that only prevented air leaking out while trying to inflate (thanks to the sudden 160psi burst it provides) but it probably also helps seat it correctly.
Don’t get a mess with sealant now I have my technique sorted but did the first couple of times. I don’t put it in via the valve any more.
choddo is offline
Old 11-11-23, 08:03 AM
TakingMyTime
First, let me say that I have nothing against TL setups, if that's what works for you. And... maybe there's a chance that I could get use to them after repeated attempts on mounting and removal. All I know is that I sat on the side of the road trying to get it to seat properly and was running out of Co2 cartridges and getting worried. When I got home I decided to put on the 'ol thinking cap and came to the conclusion that I just needed more experience. I repeated my process several times and still could not get them to seat properly (with tubes). Then and there I decided to call it quits. Asking myself... I can repair a normal tube/tire problem in minutes and be back on the road. I know some of you will say that with TL i wouldn't have even noticed the problem. That's fine, you've converted and it works for you. But... I get probably 1 flat per year (3k mi per year) and that is nothing more than a blip on the radar.
With that said, I've got 2 virtually new Conti 5000 S TR's (one with a pinhole) that are doing nothing but hanging in my garage.
Old 11-11-23, 08:32 AM
choddo
Quoted: 682 Post(s)
Yeah with that rate of punctures, it’s not like you have a problem to solve. I was getting one every 500-700 miles (3-4 weeks) on clinchers and sometimes/rarely 2-3 in one ride. Which is a massive pain in the arse on a commute in the rain. You know what it’s like if you don’t find that flint.
tubeless tyres make absolutely no sense with tubes imho. More expensive, heavier, harder to mount.
choddo is offline
Old 11-11-23, 09:31 AM
Trsnrtr
Super Modest
Trsnrtr's Avatar
Quoted: 10963 Post(s)
Liked 4,620 Times in 2,123 Posts
I’ve run tubeless since 2016 and have little trouble either installing or in usage. For the record, tires seem easier to deal with than in 2016.
Given that, I had a pretty worn Pirelli rear tire that flatted this week. I had two small 1/4l long gashes in line about a 1/4” apart. Tire would not seal and since I was with a group, I opted to put a tube in instead of trying to plug two cuts which may not have worked. It was messy since I had just topped off sealant the week before but it was an easy job to stick a tube in, even with no way to wipe the tire out except with my hands. I rode that setup 10 miles home and another 50 miles before I got around to installing a new tire.
I remember learning to repair flats 40 years ago when I started out and learning tubeless is just another technique to be learned. No harder.
Keep the chain tight!
Trsnrtr is offline
Likes For Trsnrtr:
