Smaller cassette= smaller chain?
Bikes: cannondale crit 3.0, specialized allez, old giant mtb/hybrid
Im thinking about switching out my 7 speed cassette from a 12-30 to an 11-23 as I never really use anything over 16 or 18. I have a semi compact crank 44-50.
Im just curious if i will have to shorten my chain. Im afraid the cassette might be too steep but I want to try it, and I dont want to buy a new chain if I switch back.
Thanks.
Thanks.
Mechanic/Tourist
Nice to be young and in shape! If you retain the same rear derailleur you do not have to shorten the chain. The derailleur pulley's long cage will take up the slack just as it did before, and won't know that you no longer have the larger cogs.
Quoted: 1438 Post(s)
Liked 1,092 Times
Don't forget to adjust your B-screw for the smaller cassette. If you decide to stick with that cassette, shortening your chain may result in smoother shifting. Make sure you can still shift into the big chainwheel/big cog combination without straining anything before you ride it.
Quoted: 7351 Post(s)
Liked 2,479 Times
What are you going to do with a 50/11?
Quoted: 5793 Post(s)
Liked 2,586 Times
There's no need and little (if any) benefit to shortening a chain. Since your chain is already short enough to work with the 12/44 combination, it should be short enough for the 11/44 which is just about the same.
Not shortening the chain has the added benefit of allowing you to change your mind and going back to the larger cassette.
FB
Chain-L site
FB
Chain-L site
I let the dogs out
Bikes: 2011 Fuji Roubaix 1.0, 2003 Ti Merlin Solis, & 1994 Raleigh MT200
The 50/11 combo on my roadie is fantastic for maintaining a relatively low cadence (less than 150rpm) on high speed downhills. I used it to get up to a top speed of 49.5mph on a hill that I could coast down at 44mph. Hugely different from the 48/13 on my hybrid.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
And to live in a place without hills.
Like Frank advised, I would leave the chain alone since you're only asking the RD for another half-link of takeup.
P.S. I'd check which cassette you have before deciding on the new one. Shimano made a 12-28 and a 13-30 7-speed cassette, but no 12-30's that I know of. I'm not aware of any 11-23 7-speed cassettes, either, but the 12-21 would probably be up your alley.
RUSA #7498
I found one made by origin 8
https://www.ebay.com/itm/290762556446...=p5197.c0.m619
Its cheap and looks like fun, But I live in a pretty hilly area, moved back to milwaukee. But like i said, I only the first 3 or 4 cogs anyways, 12- 20~ Its only big in the big cogs when I installed new RD. I spend most of my time in the 44 front ring..
Bikes: Nothing amazing... cheap old 21 speed mtb
Just that you are putting a new cassette and a worn chain together..
not really a good match.
Liked 2,479 Times
I'd rather have hills. I don't like headwinds. And I enjoy hills.
Mechanic/Tourist
To each his own, but I've always preferred to tuck and coast on that fast a downhill. More left for the flats and uphills, especially in "rollercoaster" hills where you can partially coast up and then power over the next hill. I can't imagine wanting to pedal at 140 revs when tucking in with pedals level would probably get to almost the same speed on a longer downhill. I've hit 55 mph coasting, according to speedometer of a car next to me on the El Cajon pass going into San Bernadino, CA (pre-computer days).
