Bicycle headset crown race impossible to get on
I bought this frame.
https://www.bicyclebluebook.com/value-guide/product/92897/
I've been trying to install this headset:
https://www.worldwidecyclery.com/products/ritchey-logic-1-1-8-quot-threadless-headset-black
It is just enough that it does not fit. I think that if I use more force I'm at risk of cracking the carbon legs. The crown race is already rubbing paint off where it is in contact.
I am wondering if maybe there is some incompatible standard that I missed. JIS vs ISO?
I see threaded headsets that say 30.2. 30.2 vs 30.0 seems to me like that would be enough margin to fit it on.
I am potato.
Quoted: 1793 Post(s)
Liked 1,632 Times
Interference fit.
Your local bike shop has a tool similar to a slide hammer for just such a purpose.
It'll cost around $10-$15. for a race...around $30 for a whole headset.
Car dependency is a tax.
Quoted: 7662 Post(s)
Liked 3,506 Times
https://www.bicyclebluebook.com/valu...product/92897/ 2005 Kona Kona Deluxe Stock Headset 1 1/8 inch threadless Aheadset STS
https://www.worldwidecyclery.com/pro...-headset-black Ritchey Logic Comp 1-1/8" Threadless Headset: EC34/28.6 EC34/30, Black
https://problemsolversbike.com/files/tech/s.h.i.s.pdf Cane Creek headset sizes cheat sheet
Cane Creeks recommended dimensions : S.H.I.S. 34 (Legacy name: 1 /18) Inside diameter 34 --- actually 33.90 - 33.95 mm (I believe the 28.6 is the steerer tube diameter and 30 is the inner headset diameter.)
Did you measure your tubes and headset crown race with a micrometer? Are you sure the dimensions are as you posted? Just asking, given the info above.
Also you say
Yes .... well, you need a Threadless headset. And apparently you bought the wrong size, based on what I see here, and on the fact that you could not make it fit.
I applaud you for not using the "bigger hammer" solution. Pounding on a CF fork with all the force reacting through the dropouts seems like a bad idea, I agree.
I made a DIY headset press out of PVC tubing when I was assembling a couple of carbon frames.
For the top I used a piece which supported the race with a piece inside it which acted as a guide. Flip the frame upside down, pop the cup into place, and whack the PVC vertically on the floor. Alternatively, use a support piece which is long enough to reach the floor in place of the fork, slide in a smaller guide piece, drop the headset cup down the guide piece, drop a larger piece over that, and hammer the PVC from the top.
For the fork race I used a PVC tube big enough to support the headset and longer than the steerer and slid the fork Down over that so that the PVC tube rested on the floor, holding the bearing race in place. I then picked up the fork by the legs near the crown on slammed it down. The force all reacts through the PVC to the floor---the steerer doesn't hit the floor, and the legs are pointing up, so no forces hit the fork anywhere except on the race and where it should seat.
The whole idea is never to pound the frame or fork against the ground.
I am sure there is something on YouTube about DIY headset presses. Pretty sure I found the ideas there.
However, if the headset is really a few millimeters too big, you might be heading for disaster. ..... If it is really just two-tenths of a millimeter too big, I would assume you could set the bearing race with a judicious use of force.
Also you say
Quoted: 714 Post(s)
Liked 801 Times
There is only one size crown race for 1 1/8" forks. Never pound on a crown race with the fork legs on a hard surface(learned that lesson the hard way). I hold the fork in my hand and use a section of pipe to hammer the race on, or use a section of PVC pipe in a vise and hold the fork upside down by both legs and drive it down onto the PVC pipe. Edit- also lube the interface between the crown race and the fork.
Quoted: 645 Post(s)
Liked 797 Times
Also you say
Also you say
Likes For Litespud:
Measuring Allergy continues ?
OP sees listed info, but did not make the effort to actually measure the crown race seat and the crown race to know for themselves..
30,2 seat & 30.0 race ? consider taking the difference down to 0.5 mm..
Randomhead
Liked 3,705 Times
If there is paint on the mating surfaces, it should be faced. Kona is pretty good, but my LBS faces and chases the headset and bb on every bike, including Kona.
As others have said, it's an interference fit.
Likes For unterhausen:
Bikes: Moots Routt
Quoted: 94 Post(s)
Liked 22 Times
1. Post photos
2. There shouldn't be paint where the crown race sits
3. Get the right tools to set the crown race, it should be a non moving super tight fit (interference like others said)
4. Dont mount a crown race with the fork legs touching a hard surface (other said this)
james
www.buckyrides.com
james
www.buckyrides.com
Likes For jbucky1:
1. Post photos
james
www.buckyrides.com
james
www.buckyrides.com
Because it is an older fork, maybe the material expanded or something? The only thing I can think of is to use paint remover or a rotating sander to trim some paint from the inside of the crown race. Also see the wear marks on it.
1. Post photos
james
www.buckyrides.com
james
www.buckyrides.com
See #6 Use A Caliper, state numbers read,
Data, not a Camera..
crown race setting tool.. functionally it's like a ring hammer..
Bikes: Moots Routt
Quoted: 94 Post(s)
Liked 22 Times
The pictures look fine.
Sorry to go backwards, are you using a tool to mount it or just your hand? - coz you need a tool
james
www.buckyrides.com
james
www.buckyrides.com
Quoted: 321 Post(s)
Liked 263 Times
If it really doesn't want to go on try to figure out which component is the wrong size and just sand it down a little bit. So long as it's on there and square it's all good.
Quoted: 4560 Post(s)
Liked 2,803 Times
I used one of these to set the crown race on my bike. Works fine. It seems crude, just a shaped bit of steel pipe used to whang the crown race down flush with the fork crown. There are two pieces used to match the angle of the crown race. Then the larger pipe is used as a hammer, slipped around the steerer tube.
The only difference between this tool and similar designs is the smaller tubes beveled to match the crown race angle are separate from the hammer end. With some similar tools a grub screw is used to lock the two pieces together. The one I got seems less fussy.
As other folks suggested, with a carbon fiber fork and/or steerer tube, it's better to firmly handhold the fork with one hand and whang down the hammer and crown race with the other. It'll take more whacks to set it flush, but it's less likely to damage the fork ends.
If you search around, especially on YouTube, you'll find lots of suggestions to use PVC pipe to set a crown race. No way would that have worked with mine. The fit was much too tight, and plastic pipe would have shattered from the necessary impacts. User reviews on the metal setting tools say the same thing -- they tried the PVC pipe trick and it didn't work for them, while the metal pipe tools did.
From your pictures it looks like you've not greased where the race goes which will make it more difficult.
You'll need some pvc pipe that can sit on the race and long enough so it fits over the steer tube. Get a small bit of wood and put it on top and then use a rubber mallet to give it a few hard hits. It's not supposed to go on with hand pressure or a gentle push. You have to hit that thing in place.
If you search for the frame, then the use the steer tube specs you can find a compatible race.
Even if it is the right size it's not the easiest thing to get on.
Liked 3,506 Times
Wow I hope that is a joke.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Thread just got exciting.
Likes For Fahrenheit531:
Liked 3,506 Times
Yeah, be sure to keep a video log ....
I sanded the inside of the crown race and I got it to fit. Still pretty snug.
My theory is that the metal in the fork expanded over time. Maybe it was compressed and then when the crown race was removed it sprung back. Anyways, it fits now and I got the crown race on.
A lot of people split their crown race. Also, since it has sealed bearings, the crown race is kind of a formality anyways and doesn't matter.
I am potato.
Liked 1,632 Times
Dumbest esh I have seen in a long time.
Good luck with every bump & shock your bike experiences getting a running start as it slams into the assembly.
Be sure to let us know how the dental work goes.
Base2
(Who has broken 2 forks over loose crown race issues.)
Liked 3,506 Times
Wrong on so many levels & so many ways.
Base2
Base2
If he bought the wrong sized unit, and adapted it to fit without weakening it so much it does split .... then regardless of his "expansion with time" theory (which is shown as our vintage bike frames and parts no longer work with new parts of the same specification .... the old ones have expanded, right? Everyone knows metal grows ..... ) His bike might work well and last a long time. If he weakened the race too much, took a way too much material .... well, he will find out.
I sure wouldn't ever let him wrench on anything I would ever ride .... but h might have found a solid solution in this one instance.
Of course, he might find out otherwise when he hits a hard bump at 44 mph and a steep downhill .....
Quoted: 341 Post(s)
Liked 277 Times
Four years ago, I swapped a RST Crappa suspension fork into my Trek 830. That's a 1" threaded steerer. I was unable to cut the additional inch of thread needed on the steerer rube with my $39 die, so I converted it to a 1" threadless, thanks to input from this forum. I also have a problem installing the crown race. I probably measured it, but I didn't write it down. A typical FSA headset, I recall.
I made a press out of a pipe, and 3/4" threaded stock. I recall needing a 2 foot breaker bar to turn the nuts. I've since put crown races on two other forks, but they were 1 1/8", and they only needed a slight tap to seat.The threaded rods were later used to install cup bearings into frames.
Likes For Doc_Wui:
