Stem cap bolt
Stem cap bolt
Hi all. I've noticed my headset knocking a bit under hard front braking and have attempted to loosen the stem cap to check bearings and noticed that the cap bolt has been rounded out by the wrench monkey who put this thing together 15 years ago. What can I do with this to get the head apart?
Likes For jadocs:
Quoted: 6193 Post(s)
Liked 4,808 Times
Might could find a torx bit that doesn't quite fit and hammer it down in there. Might ruin your torx bit, but those are cheap now. Screw extractor is best bet.
I've gotten things like that out by making a small punch or chisel like tool with sharp edges from tool steel and tapping near the circumference in the loosening direction. Surprisingly worked better than I imagined for being so small.
Likes For Iride01:
LR÷P=HR
Quoted: 865 Post(s)
Liked 1,203 Times
+1 on Torx bit.
Bin there, got the t-shirt!
Barry
Barry
Likes For Barry2:
Quoted: 942 Post(s)
Liked 526 Times
That bolt looks like it's been really wrenched on. Loosen your stem first in case the cap has been wrenched on against the stem.
Thanks for the advice guys. I'll see what I can do with it. I've got a bunch of Torx bits about, otherwise I'll get an extractor.
Likes For fietsbob:
Quoted: 1074 Post(s)
Liked 295 Times
I’m wary of screw extractors. They’re quite brittle and if they snap before the screw comes out your trouble has immediately multiplied.
I’ve never snapped a Torx yet.
Case like this, I’d be about evenly tempted by trying a Torx or simply reaching for a drill.
Good thing about Allen screws is that they are by nature self-centering when you go to drill the head off. And the steel for a top cap bolt is relatively easy to drill. Run a 5mm drill down there and the head of the screw will come off. That should pop the top cap off, which should allow you to reach in there with a set of pliers and unscrew the rest.
Likes For dabac:
the drill out if say 5/16" the cap screw head would fall off, the stem cap coming off ,
Then, you remove the stem, and extract the rest of the bolt with vice grips..
Jedi Master
I'd drill it out with a left-hand bit.
Quoted: 1303 Post(s)
Liked 1,910 Times
How about using a Dremel cutting wheel to cut a slot in it? You are going to toss the bolt so who cares if you disfigure it a bit. Smiles, MH
Likes For Mad Honk:
Quoted: 802 Post(s)
Liked 2,976 Times
fix/
slot that sucker-save your time for riding.
Likes For '02 nrs:
