Carbon wrapped seatpost/aluminum frame
Does a carbon wrapped seat-post bond together in an aluminum from the outside elements like aluminum on aluminum?
Does it have te same problem of corroding and getting stuck in the frame as aluminum on aluminum. Will a carbon wrapped post galvanically corrode in and aluminum frame?
Bikes: Trek Navigator, LeMond Buenos Aires, Madone 5.9, S-Works Roubaix
I've been using one for over a year and no problems yet
Bikes: 05 Madone SSLx, 07 Madone SL5.9, 08 Cramerotti Nero Corsa Record, 09 Trek Top Fuel 9.8, 11 Norco CCX2, 11 Ridley Phaeton T, 11 Rdley Excalibur Flandrien
I would say no but anything is possible. Clean it regularly if you're riding in elements and I can't see there being an issue.
Beer >> Sanity
Bikes: 2014 Evo DA2, 2010 Caad9-4, 2011 Synapse-4, 2013 CaadX-disc
My caad came with a carbon wrapped seatpost. It's a bit over a year old now and although I don't remove it often it's never been a problem. Not sure plastic would bond to much of anything without glue anyway (or enough heat to melt it).
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
Galvanic corrosion occurs between dissimilar metals. Alum seatpost and alum frame are not dissimilar. And carbon is an insulating barrier between.
jaltone
Road Cycling
16
01-27-13 05:34 PM
pstock
Road Cycling
81
11-06-10 03:19 PM
