Ironman Information Thread
Old 10-19-15, 03:23 AM
RobbieTunes
Quoted: 378 Post(s)
Liked 1,409 Times in 909 Posts
Non-fluted seatpost and 27.0 on at least the '85, '86, '88, maybe all.
Learn something every day. I've used 27.2's in all of mine, go figure.
My first Ironman was an '88 Master and it came with a fluted seatpost.
Used, though, so no way of knowing how it hit the shores.
Had been upgraded to 8-sp 6400 STI w/rear hub upgrade and shifters.
Whopping $135 on eBay. Times have changed.
Thanks to folks for submitting information. Helps a lot.
Sooner or later, we'll have a pretty complete database of the OEM stuff.
I've never seen anything but narrow little tires on them, and I had an '86 all OEM.
It sure did not have 700x28's on it, had Panaracer Technova's. Another oddity.
RobbieTunes is offline
Old 10-19-15, 04:22 PM
lord_athlon
lord_athlon's Avatar
Liked 6 Times in 4 Posts
After looking at the spreadsheet on the other page, the BB on my ironman was a Sugino, not Shimano weirdly. It has a thick lockring, just like the Thick one on the Superbe Pro BB, and the cup is clearly marked Sugino.
lord_athlon is offline
Old 10-19-15, 04:58 PM
texaspandj
texaspandj's Avatar
Quoted: 1605 Post(s)
Liked 582 Times in 379 Posts
Seems everyone is wondering why didn't they just put matching shimano bottom bracket. According to a bicycle review it was simply to keep build cost down.
texaspandj is offline
Old 10-19-15, 07:29 PM
67tony
67tony's Avatar
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times in 92 Posts
My '87 master is, to the best of my knowledge, all original...except of course for the tape, tires, pedals, and housing. So, in case it helps filling out the spreadsheet, here are pics of the crank, derailleurs, seat post, and headset:
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
67tony is offline
Old 10-19-15, 08:39 PM
Brewsmith
Bikes: 1987 Centurion Ironman Master, 1989 Centurion Ironman Expert, 1972 Motobecane Grand Jubilee
Quoted: 119 Post(s)
Liked 171 Times in 66 Posts
Mostly original '89
As far as the supposed geometry changes, would it theoretically be possible to just measure two vintages of frames in the same size and compare? Especially since we have one of the spec sheets above. What does it take to measure frame angles other than a protractor?
Brewsmith is offline
Old 10-20-15, 07:12 AM
fleslider
fleslider's Avatar
Quoted: 477 Post(s)
Liked 179 Times in 91 Posts
Originally Posted by Brewsmith
Mostly original '89
I have a 1989 Expert and a 1987 Expert in the same size frames, and i measured them rather crudely one day and they are different geometries. IIRC, The 1989 had a less relaxed head tube angle as the 1987 had. i recall it was a couple degrees steeper. When i find the sheet that i noted these items i will post them here so others can get the idea.
fleslider is offline
Old 10-20-15, 08:57 AM
Vintage_Cyclist
Vintage_Cyclist's Avatar
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times in 176 Posts
Database update https://docs.google.com/spreadsheets...gid=1927924249
I added a general groupset note for each model to indicate group (600EX, 600 Ultegra, etc.) and miscellaneous stuff like anodizing.
If anyone who has bikes original (or known provenance) to them, with original parts, they can let me know specific part numbers (i.e., 6200 series vs 6208 specifically) for that year and model, which will enable me to put the specific parts in.
Geometry charts added for 84, 86, 87 and 89 models.
If anyone has any other ideas on what would be good to include, let me know.
Vintage_Cyclist is offline
Old 10-20-15, 07:06 PM
Vintage_Cyclist
Bikes: yes
Quoted: 512 Post(s)
Originally Posted by RobbieTunes
1984 Comp TA.
Stem: Nitto or SR CR?
1984 catalog says Model CR "invisible bolt" design. Aluminum"
Old 10-20-15, 07:10 PM
RobbieTunes
Quoted: 378 Post(s)
Picture bears it out, too. Post changed. Thanks.
Old 10-20-15, 07:11 PM
RobbieTunes
Quoted: 378 Post(s)
Mostly original '89
Thanks, Alex, added it to the post for '89's.
Old 10-20-15, 07:23 PM
Vintage_Cyclist
Bikes: yes
Quoted: 512 Post(s)
Bicycle Guide review specs from the 1989 Expert
Old 10-21-15, 08:13 AM
Vintage_Cyclist
Bikes: yes
Quoted: 512 Post(s)
Re: series 6200 parts for 1984 through 1987.
On the other Ironman thread, lord_athlon confirms his original 87 Master is all 6208. (although I'd like a recount; I suspect the crank, FD, pedals and headset are 6207, based on Shimano's products from that year).
Since 6208 was issued in 1986, I assume in 1984 and 1985 the Shimano components on the Comp TA and Ironman would have been all 6207.
In 1986 Shimano introduced 6208, but the 600EX group sold was a mix of 6207 and 6208:
1986 had SIS and aero brake levers, which would eliminate the italicized parts in the list. As already noted, brake levers would have been either Dia Compe or Shimano, both aero. This is assuming the 1986 Ironman did not come with leftover components from Shimano's 1985 lineup.
Old 10-21-15, 08:37 AM
daf1009
daf1009's Avatar
Bikes: LESS than I did a year ago!
Quoted: 70 Post(s)
Liked 6 Times in 5 Posts
Robbie...this is a great thread...and great idea on it being simply informational...We could probably use an entire encyclopedia of threads like this...
daf1009 is offline
Old 10-21-15, 01:25 PM
RobbieTunes
Quoted: 378 Post(s)
Keep the corrections coming. Looking for documentation of a 1988 Master in yellow/white "straight fade."
Old 10-21-15, 04:34 PM
RobbieTunes
Quoted: 378 Post(s)
Duh!, it was right there on the '88 post.
Old 10-21-15, 07:13 PM
uncle uncle
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times in 140 Posts
Could you identify which Ironman years use proprietary odd ball Shimano shifter braze-ons? Clear details about this still allude me.
https://www.bikeforums.net/bicycle-me...confusion.html
uncle uncle is offline
Old 10-21-15, 07:29 PM
Vintage_Cyclist
Bikes: yes
Quoted: 512 Post(s)
That would be only the 1985 Ironman. The 1984 Centurion Comp TA also used that proprietary shifter braze-on.
Shimano called it the Brazed-on A Type, the standard shifter mount in use today they called the Italian Type, and the aero shifter mount that screwed into the top of the downtube was called the Brazed-on B Type.
Shimano 6207 shifter sheet for 1984
Old 10-22-15, 08:14 AM
texaspandj
texaspandj's Avatar
Done
For the 88 purple haze I found that Pure Ice name brand nail polish 542cp "No Means No" is a perfect match for the dominant purple. The fading purple is either Sally Hansen brand hard as nails nail polish 370 "No Hard Feelings" . Or L.A. colors name brand color craze nail polish cnp507 "Wisteria".
I think adding freewheel cog numbers would be very helpful to those trying to return to stock.
Sidenote : Nobody needs to be concerned how I know what fingernail polish to use. Hah.
Old 10-24-15, 06:35 AM
RobbieTunes
Quoted: 378 Post(s)
OK, folks. Please do me a 5-minute favor.
Look over the "main" information posts (Predecessor, etc)
Find the typo's and anything incorrect, or what you think needs changing.
Copy and paste the thread into a PM, and either add correction at the bottom, or in underline.
I'll look at each PM, correct the post, and we'll see how close we can get.
The gist is the OEM information, and touch-up gouge.
I'd like to see any OEM numbers on gearing, as well. I know the GPX was 52/42. I know the "round" Shimano was 53/39. I've seen different versions of the BioPace, both in 600 and 105. It would be nice to somewhat clear that up. Also, rear cluster info would be welcome.
Old 10-24-15, 10:58 AM
texaspandj
texaspandj's Avatar
Hey R.T. just sent you a pm,however I get what you wanted now. Sorry. But will send you new pm per request soon.
Old 10-24-15, 11:26 AM
rms13
Quoted: 276 Post(s)
Liked 6 Times in 3 Posts
You've got me thinking about another Dave Scott now. There are two for sale locally that look to be in great condition. One is desirable (by me) Miami Vice paint in 54 and the other is Red/white in 56 Has anyone found a definitat ive geo chart for these? I assume 54 = 54cm top tube and 56 =56. My preference in modern bikes is around a 545 top tube and 110mm stem so I'm really trying to see if I can make the 54 work for me because that's probably the smaller end of my fit
Edit: just saw the link to the spreadsheet. Awesome work Robbie
rms13 is offline
Old 10-24-15, 01:24 PM
lord_athlon
My 87 was 13-14-15-17-19-21
Old 10-24-15, 01:39 PM
Vintage_Cyclist
Bikes: yes
Quoted: 512 Post(s)
The Bicycling review of the 87 says 13-15-17-19-21-24, but I'd be inclined to go with a verified original bike; the test bikes could be specced differently from what hit the stores.
Old 10-24-15, 05:23 PM
texaspandj
texaspandj's Avatar
And that's what mine came with. (13,15,17,19,21,24) model number mf z012.
Unless you're the original owner or aquired the expert 87 from the original owner and asked what original parts have you replaced (for my own records). It would be difficult to verify what parts are original.
Old 10-24-15, 06:23 PM
top506
Death fork? Naaaah!!
top506's Avatar
Bikes: Seriously downsizing.
Quoted: 559 Post(s)
Liked 627 Times in 280 Posts
The first '87 to pass through my hands (now in Jim Muller's barn) was 13-15-17-19-21-24. The second lacked wheels, but both were 52/42 Biopace.
Top
top506 is offline
