This Puch Bergmeister followed me home last night.
Old 08-27-16, 12:20 PM
juvela
juvela's Avatar
Quoted: 3801 Post(s)
Liked 3,324 Times in 2,170 Posts
Originally Posted by noobinsf
The bottom bracket cups are engraved with "34.8," which Mr. Interwebs tells me is English threading expressed in metric terms. I was going to use the old cottered crank for value's sake, but I'm tempted to get a cheapo cartridge bb and a used JIS crank just to lighten this beast.
You are doing just fine; we all look forward to following the progress!
juvela is offline
Old 08-27-16, 01:44 PM
noobinsf
noobinsf's Avatar
Quoted: 1088 Post(s)
Liked 1,204 Times in 700 Posts
Various small bits following the Evaporust bath...
noobinsf is offline
Old 08-27-16, 01:54 PM
Velocivixen
Velocivixen's Avatar
Quoted: 400 Post(s)
Liked 37 Times in 26 Posts
Wow, what a nice job on the cleanup and polish. I adore that shade of green also. P,ease keep us posted.
Velocivixen is offline
Old 08-27-16, 02:04 PM
Rollfast
What happened?
Rollfast's Avatar
Quoted: 1835 Post(s)
Liked 292 Times in 255 Posts
That sounds like a great adoption, make sure it gets all it's shots and care and exercise it often
Rollfast is offline
Old 08-28-16, 04:00 AM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Quoted: 2192 Post(s)
Liked 4,571 Times in 1,758 Posts
Looking good!
BTW, I think 'Bergmeister' is one of the coolest model names ever for a bicycle. (And for motorbikes and cars too; it shows the right kind of ambition and confidence.)
Are we having fun, or what ...
non-fixie is offline
Old 12-05-16, 04:28 PM
noobinsf
noobinsf's Avatar
Well, after a lengthy hiatus, I am back at it and working on the rust issues in earnest. The pitting is pretty bad on the top tube, less severe on the down tube and stays. I started working with 120-grit paper, and the pic below is a view of the top tube leading into the seat lug -- you can see the smoother area on the right after some work, while the lug retains some pitting texture. I also have a light coat of oil on it after sanding to keep things stable.
Not having worked on this level of rust before, does this look like a bad sign, or is it safe to assume the tube is thick enough to handle this level of sanding?
Also, does anyone know if the interior of the tubes was copper-plated like the outside? The interior of the tubes also has an orange tinge, but it does not have the uneven coloring that indicates rust, so I think it is just plating. (I will try and get a pic of that tonight, but so far, I haven't been able to get a useful picture with the available lighting.)
This is going to be quite a bit of work, and I'm curious if it will be worth it in the end... I could live with a rough finish under a clear coat, since this will be a beater commuter, but I don't want to ride an unsafe frame if it's compromised by rust.
noobinsf is offline
Old 12-05-16, 04:37 PM
juvela
juvela's Avatar
Thanks very much for this update.
Good to see things moving forward on the project.
Readers might be able to give more/better feedback with aid of additional imagery...
juvela is offline
Old 12-05-16, 05:29 PM
chewybrian
"Florida Man"
chewybrian's Avatar
Quoted: 1571 Post(s)
Liked 1,705 Times in 854 Posts
Originally Posted by juvela
-----Readers might be able to give more/better feedback with aid of additional imagery...-----
Helpful?
chewybrian is offline
Old 12-05-16, 09:51 PM
Dougbloch
Quoted: 135 Post(s)
Liked 8 Times in 6 Posts
A worthy project indeed!
And I love the Burgermeister Meisterburger reference.
Dougbloch is offline
Old 12-08-16, 02:09 AM
noobinsf
noobinsf's Avatar
Okay, more images here. Also, yes, 'tis the season for more stop motion Burl Ives.
I was concerned, but after sanding down the knobby bits and checking out the interior of the tubes more extensively, I think this thing is actually remarkably free from major issues (knock wood). Unless I'm woefully mistaken, the interiors of the tubes have an orange tinge due to copper plating. I scrubbed a few sections with synthetic steel wool and light oil, and the test spots came out shiny.
Now I'm thinking the ratty finish under clear varnish could be really attractive, and I'm tempted to build up a set of 650b wheels, since the clearances are good, and it's something I've wanted to try. I have a set of Weinamnn 750s waiting for an application.
Here it is in its current state with a borrowed set of 27" wheels:
Inside of bottom bracket shell after cleaning:
Inside of steerer tube after cleaning:
noobinsf is offline
Old 12-08-16, 01:39 PM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
I like the look of that. The fork shape is especially attractive.
Old 12-08-16, 02:28 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,862 Times in 1,439 Posts
Some semi-translucent paint over that could be really cool, sort of a spottled effect.
My Bikes
Andy_K is offline
Old 12-08-16, 03:24 PM
noobinsf
noobinsf's Avatar
I'd like to eventually do a rattle can job over the whole frame, but for now, I think it will be an interesting beater commuter with the finish as is under Humbrol Clear, as demonstrated by member @realsteel. I have renewed energy for this one.
My mind keeps going back to this image of @jyl's Bianchi as inspiration:
noobinsf is offline
Old 01-20-17, 01:06 AM
noobinsf
noobinsf's Avatar
A bit more progress...
Polished crankset, cleaned and Boeshielded steel seat post, cleaned Mertens Coureur saddle
Brake caliper before and after
noobinsf is offline
Old 01-20-17, 01:11 AM
noobinsf
noobinsf's Avatar
And here is first-hand proof of the fabled Ava Death Stem.
Doesn't look too bad here
But here is a close crop of the same photo. The crack goes about 1/4 of the entire circumference. Thank goodness I never tried it, and I've replaced it with an Origin8 Classique stem (which fits into the French-sized steerer without modification.)
noobinsf is offline
Old 01-20-17, 01:33 AM
Piff
Piff's Avatar
Quoted: 791 Post(s)
Liked 741 Times in 406 Posts
Great progress, I can't wait to see the end result.
Piff is offline
Old 01-20-17, 02:10 AM
juvela
juvela's Avatar
Fine work, a most fortunate Bergie to have fallen to your hand!
This photo with the wheels in and no fittings certainly accentuates the limousine wheelbase. Expect it must be something in the vicinity of 41 1/2" to 42".
juvela is offline
Old 01-20-17, 08:14 AM
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1954 Post(s)
Liked 3,656 Times in 1,677 Posts
Awesome bike and great work your doing. Very inspiring!
52telecaster is offline
Old 01-20-17, 10:25 AM
noobinsf
noobinsf's Avatar
Thanks for the encouragement, everyone!
Juvela, good eye there -- the wheelbase measures 42.5 inches.
noobinsf is offline
Old 01-20-17, 10:35 AM
juvela
juvela's Avatar
Hey folks, it's those dimpled blades that really get him going!
juvela is offline
Old 01-20-17, 01:09 PM
rsandoval75002
rsandoval75002's Avatar
Bikes: 1978 Motobecane Grand Touring, 2015 Trek Speed Concept, 2010 Trek Madone, 2009 Kuota Kebel and a few more
I recently got a hold of a 1960s Bergie also, and I'm looking to restore it as you can see it was painted over the -and hopefully- original paint. Did some research and apparently is copper color under.
rsandoval75002 is offline
Old 01-20-17, 01:37 PM
juvela
juvela's Avatar
Congratulations.
Lots of Bergie threads here at the forum you can pull up with search function and/or begin a new thread for your latest arrival.
As you likely already know, Bergies were also private labelled as Sears/J.C. Higgins.
juvela is offline
Old 01-20-17, 02:14 PM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 526 Post(s)
Liked 256 Times in 165 Posts
Wow, that is a seriously high bottom bracket shell! Bergmeister Boulder Bouncer?
Hudson308 is offline
Old 01-24-17, 03:41 PM
noobinsf
noobinsf's Avatar
Hmm, well, I checked it against my modern Felt, and they match at 27cm from center of the BB to the floor. Is that high? Isn't that pretty much standard? Maybe just the angle of the photo...
noobinsf is offline
Old 01-24-17, 03:55 PM
noobinsf
noobinsf's Avatar
Closing in on completion. Here is a pic after fitting some of the cleaned parts -
  • overhauled Suntour GT rear der (my addition - had a Huret Allvit)
  • overhauled generic Shimano front der (prev owner's addition)
  • Huret shifters and downtube cable guide
  • overhauled headset
  • overhauled bottom bracket
  • original post and saddle
  • new stem
  • new Nitto 115 bars, 45cm
  • placeholder brake levers -- cleaning the originals
  • Boeshield treatment inside tubes
And here are the original hoods after toothbrush + mild dish soap + Bon Ami mild abrasive cleaner. They were yellowing and dry, but the Bon Ami appears to have taken a light layer off, so they're brighter and supple.
I'm just finishing up truing the wheelset that this one will wear.
noobinsf is offline
