Good short vid on silver brazing
Quoted: 96 Post(s)
Liked 30 Times
Overall good short footage and info on the basics of silver brazing. Jody(welding tips and tricks) is not a frame builder but visits Mike at his shop.
regards, Brian
regards, Brian
Brian
Brian
Bikes: Lots of French, some British and a couple of Italian
Quoted: 247 Post(s)
Liked 130 Times
I read an article by an 'old' framebuilder saying silver braze gives better performance than bronze. If there's any truth to that, maybe it's that the initial clearance in the joint needs to be much tighter? Nice vid, thanks.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
I like silver because it's lower temperature (than brass) and flows really well (56% or ezflow 45% w/cad). Brass is fine but more heat is needed and thus greater skill is required to make sure you don't overheat the metal. Also, silver is easier to remove from the shore line than brass (for those instances where you get caught trying to over fill the joint.)
Quoted: 4205 Post(s)
Liked 3,865 Times
To play the devil's advocate- Brass is far more tolerant of poor prep. Both in gap as well as clean surfaces. It's much less expensive and offers far more joint geometry and styles. It has a greater temp range WRT it's viscosity, meaning it can flow quickly or glob up (lugs or fillet). That the temp is greater and thus the control of temp is more critical is only practice, just like flowing silver is practice and maintaining the temp for that takes a skill. Andy
AndrewRStewart
AndrewRStewart
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Brass is more tolerant of poor prep and looser clearances, but silver's lower temperature can mean a smaller heat-affected zone on the tubing. Silver also flows easier than brass, and done well requires less clean-up.
Randomhead
Liked 3,698 Times
I hate to file, so I'm sticking with silver for the time being
Liked 3,865 Times
And I'm sure you're a faster builder then I am too Andy
AndrewRStewart
AndrewRStewart
Great video and a as traditional silversmith I'd say he hit all the bases.
his web site is also a great for most welding tec.
Quoted: 96 Post(s)
Liked 30 Times
Looks like a small piece of crud in the orifice at 3:10 in (and seen throughout the brazing) causing slight separation of cone and feather. Doesn't effect the procedure but would you clean the tip before next use?
thanks, Brian
thanks, Brian
Brian
Brian
Liked 3,865 Times
Brian- yes, I would clean the tip. Both ID and face. But In try to go easy when using tip cleaning "reamers" as to not open up the orifice too much too. Andy
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,698 Times
I would clean it if I remember. Then I would get flux on it and it would happen all over again. It's mostly just an annoyance.
