Swap my cassette?
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
Swap my cassette?
I am currently running a Shimano Sora, 11-32, 9-speed on my flat bar and would like to have a lower gear for hills. I am thinking a Shimano Sora, 11-34, 9-speed or 11-36 would be the logical and least expensive change to reach my objective? I am stating this as a question as I am not sure logic plays a part here so please feel free to correct my thinking. I am guessing I would also need a new/longer chain.
Thanks in advance, Frank.
Quoted: 336 Post(s)
Liked 309 Times
You most likely need a longer chain, and it may be possible that your rear derailleur may not accommodate the larger cog. If you have the model number, you can find shimano's specs on line.
By the book, the RD-R3000 mid cage only takes a 34t cog. You may have a short cage. https://www.universalcycles.com/shop...3&category=531
Quoted: 249 Post(s)
Liked 306 Times
Quoted: 249 Post(s)
Liked 306 Times
I'am guessing I have the long cage rear derailleur but I would definitely need a longer chain.
Frank.
Quoted: 1188 Post(s)
Liked 1,154 Times
Think about changing your smallest front ring too. With the bike in it's smallest gears, teeth wise, check how close to the bottom of the front derailleur cage the chain runs and use that to figure out how small you can go diameter wise. If you are willing to forgo being able to cross chain on the smallest front ring and the smallest rear sprocket you could probably go a fair bit smaller. The rubbing of the chain on the derailleur will soon train you not to cross chain!
Quoted: 249 Post(s)
Liked 306 Times
Frank.
Liked 1,154 Times
Quoted: 3375 Post(s)
Liked 5,513 Times
Here is a 9s with 12-36 cassette and an RD-M592 "Shadow" derailleur which works like a charm.
("Shadow" meaning the pivot point is aft of the mounting bolt, enabling larger cogs.)
I would have preferred an 11T top gear, but at the time I could not find a 9s 11-36 cassette.
Quoted: 249 Post(s)
Liked 306 Times
Thanks all. Very much appreciated.
Frank.
Frank.
Liked 1,154 Times
Quoted: 336 Post(s)
Liked 309 Times
Just to clarify for the OP, you mean the Deore long cage, not the Sora mid-cage, right?
i have the XT Shadow 9 speed RD and I am running it with 10 speed Ultegra shifters and an 11-36 cassette. Not a bad option for the OP if the Sora RD doesn’t cut it.
Liked 1,154 Times
Liked 5,513 Times
I recently tried an 11-42 cassette on one, but it didn't work.
Teeth on the cassette were nicking the RD arm (to which the inner cable attaches).
I even had an extra-long B-screw on hand, but I could not get it to work.
Perhaps I'll try an 11-40 next.
Quoted: 249 Post(s)
Liked 306 Times
I have a email into FSA as my bike has their Tempo Compact, 50/34 and I asked if there is a 30 or 32 I can swap out on the cranks and not have any of the issues with the rear DR but need to make sure that the new gear would not make the chain drag on the Sora FD I have. My rear DR is Sora as the photo shows and I believe it is a long cage. Either way do you think the crank gear, if available, would give me the lower range I am looking for or will it make the jump from the 30 or 32 up to the 50 too large? According to my Strava I have some hills here that are at 14-15% for what that is worth and with my 70 year old knees I am trying to keep the cadence workable and not put a lot of stress on an already weak link, me.
Any other ideas are certainly welcome as I am by no means any kind of expert on this subject.
Thanks again for all of your responses, Frank.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Frank, another option is installing a triple crank on the front. Perhaps a 26/36/48 or something. That'll give you great range and your long cage derailleur can easily handle it. You also won't lose anything you'd actually use on the top end. That's like the same same (or similar) as what your other Quick has -- do you like its gearing? If so, you may consider matching that drivetrain on your newer Quick.
Tony
squatchy
Bicycle Mechanics
4
07-13-14 07:37 PM
volosong
Bicycle Mechanics
7
09-06-11 07:47 PM
