Curious about this frame
Bikes: Muddyfox Evolve 200, Bicycles4u Paris Explorer, Raleigh Twenty Stowaway, Bickerton California, Saracen Xile, Kona Hoss Deluxe, Vertigo Carnaby, Exodus Havoc, Kona Lanai, Revolution Cuillin Sport, Dawes Kingpin, Bickerton, NSU & Elswick Cosmopolitan
Quoted: 297 Post(s)
Liked 33 Times
On the image below where the downtube connects to the bottom bracket what is the connection there, is it some sort of simplistic lug and the downtube is brazed inside? Not seen a bike frame that looks quite like that before. It's an old Raleigh Gritstone from about 1994/5. Just curious about the braze/weld. It's a step up quality bike for Raleigh at the time utilising a Altus drivetrain with 7 speed freehub so neither bottom or top of the range of bikes. The frame is a basic high tensile steel frame with what they call 'energiser' stays presumably because they don't flex and quite thick or even solid. While the bike is definitely assembled in England I'm unsure if the frame was manufactured in the UK or imported.
Quoted: 4199 Post(s)
Liked 3,851 Times
This frame has the look of MiG welding, but I'm no welder so... can't be sure. MiG is not a common joining process for steel bike frames. This frame's shell doesn't seem to have any sockets/lugs but the tubes are directly contacting the shell and then "butt" welded to the shell. Not so well it seems
More views from different angles might confirm if the shell has cracked (looks like it IMO) and whether the weld bead got any penetration on/in the seat tube and shell.
This is not at all what most here would call "a step up quality bike" at all. Rather a very entry level low price focused bike. Andy
AndrewRStewart
AndrewRStewart
Quoted: 297 Post(s)
Liked 33 Times
Another image from a different angle that also shows the thickness of the join of the chainstay.
Quoted: 18372 Post(s)
Liked 4,507 Times
It looks like a very odd derailleur hanger sitting on top of the shell, also what looks like an integrated chain catcher.
It may be removable.
I see some writing on the top of bracket. Perhaps clean off the writing and give more info.
Liked 3,851 Times
On third viewing I think you are correct. The shadow in photo 1 looked like a real nasty crack. My comments about the joining method and bike grade stand. Andy
AndrewRStewart
AndrewRStewart
Quoted: 297 Post(s)
Liked 33 Times
https://veterancycleclublibrary.org.u...20Library).pdf
Randomhead
Liked 3,694 Times
I am not fully up on all forms of welding in manufacturing, but I think the technique used on that frame involved just getting everything very hot and smashing the parts together. That's why the weld beads are so large, they are really part of the tube. I'm sure it's quite strong and that frame is probably very heavy.
rydabent
General Cycling Discussion
27
03-10-17 02:28 PM
radeln
Classic & Vintage
1
04-03-15 08:40 PM
EnsitMike
21
02-20-14 04:33 PM
