Tubeless truth for road tires = big risk on bumps
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,831 Times
https://www.cyclingnews.com/news/kris...paris-roubaix/
Alexander Kristoff, "I took a big risk on the tubeless wheels that I've been using the last weeks".
3 punctures before switching wheels.
In any case, you cannot draw meaningful information from this, because none of us ride 54 km of cobbles on a weekly basis.
Just as interesting to me were the mechanical difficulties of Sep Vanmarcke, who was stuck in his smallest sprocket in the rear for the last 40k of the race, costing him a lot of energy. This just after Peter Sagan had a similar mechanical issue with the rear derailleur at E3 Harelbeke. I am starting to see a trend with the reliability of electronic groupsets for the pros here, at least on the cobbled classics. Are electronic groupsets perhaps not designed to be vibrated around so much? Although, again, perhaps not a meaningful issue for the recreational cyclist.
Quoted: 942 Post(s)
Liked 526 Times
Little unclear as to what tubeless had to do with getting punctures. Is the article stating that he would not have punctured if riding a different tire/wheel combo?
Kristoff chose to stick with Vittoria Corsa Graphene 2.0 25mm tubeless tyres in conjunction with Campagnolo Bora WTO tubeless-ready wheels that he had raced on throughout the spring. However, on the brutal cobbles of Paris-Roubaix the Norwegian felt that the combination had let him down and that he had made a mistake in selecting them.
The Gent-Wevelgem winner suffered three punctures before finally switching to normal tyres but by then his race was done. He would eventually come home in 56th position, over 14 minutes down on winner Philippe Gilbert.
"I took a big risk on the tubeless wheels that I’ve been using the last weeks," Kristoff told Cyclingnews.
"In Belgium it was working fine, and in recon, but in this race here you’re in the pack and you don’t really see where there are holes. I punctured twice before the Arenberg Forest and from there I never came back. I had three flats all together and then I changed to a bike with normal tyres.
"I knew that it was a big risk but these wheels are really good. I had success the last few weeks on them and I felt good today, until I punctured. We’d just not try it again next year."
Quoted: 942 Post(s)
Liked 526 Times
So I'll ask, what does a tubeless specific puncture look like? because I see no mention of anything to indicate that he would not have punctured running a different combo....
Edit: I see you and I are seeing things the same way.
Quoted: 20810 Post(s)
Liked 9,456 Times
Homeboy rode 25s on cobbles. I think that pretty much ends the conversation.
Quoted: 479 Post(s)
Liked 277 Times
I wonder if he's using the term "puncture" as a catch-all for "flat" - because, yeah... anything that would puncture a tubeless tire enough to cause it to lose noticeable PSI or totally flat, would absolutely flat a "regular" tire.
Perhaps the hard hits were burping the tire - losing big chunks of pressure with each burp. A tube obviously won't burp... it'll pinch flat.
Quoted: 18372 Post(s)
Liked 4,507 Times
My experience with riding in Rome was that in some cases, cobbles are good at hiding glass. But, that was long before tubeless bicycle tires were dreamt up. And, unfortunately, my sewups at the time weren't very puncture resistant.
Otherwise, cobbles weren't especially bad on my sewups.
Many years later, last fall, my tubeless experiment (Schwalbe Pro One) tubeless was cut short by hitting a rock (may have bottomed out), and tearing a hole in the Schwalbe Pro One.
The tire carcass was rideable with a tube (put in a dollar boot, but don't know if that was necessary). Can't say if it would have pinch flatted. I probably was slightly low on pressure. The hole was such that there was too much flex, and it would seal with the sealant down, but would leak again as soon as I started riding, and everything started flexing and opening the hole up again. But, it was fine with a tube + boot.
Hard to say about Alexander Kristoff. 3 flats in 100 miles? Obviously a failure in one form or another. Tubeless? His riding? Bad luck? Or, something with his tire choice?
TIRE PRESSURE? TIRE SIZE?
My flaw may well have been using too narrow of tubeless tires at too low of a pressure.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
So, the tubs don't really "pinch flat" either like a clincher does. You don't have an inner tube to pinch/snakebite. It's integral.
Realistically, tubs and tubeless have the best racing failure modes for pros. I give the edge to tubs because you can't burp a tub.
Quoted: 43 Post(s)
Quoted: 18883 Post(s)
Liked 10,646 Times
Quoted: 344 Post(s)
Liked 20 Times
I read the same article. Strange, since I thought most of the benefit of tubeless was supposed to be self-sealing of small punctures?
Tubulars can either use inner tubes in the same way that tubed clinchers do, or use sealed tubeless casing in the same way that tubeless clinchers do. In either case, pinch flats can happen in the same way as with clinchers: the tube can be pinched, or in extreme hits, the tire can be pinched. Pinch flats happen much less with tubulars because the tire is resting on a smoother rim profile, the force isn't concentrated as badly as it is on clincher rims.
Quoted: 4802 Post(s)
Liked 3,923 Times
I've pinch-flatted tubulars including a high-end silk in a race (on RR tracks). I also dented both rims in another race also on RR tracks at full speed a mile from the finish and didn't damage either tire. Had to pull out both rims with a puller. Twice I bottomed out on bottomless snow country potholes in deep puddles with loaded LowRiders and rode those wheels home with 1" deep dents, no flat. So, like HTupolev says, it can happen, but it happens far less frequently than clinchers.
Ben
Ben
Here's a great article on what it took to get carbon wheels working for riding the cobbles. Two big things - tires of proper width and proper inflation made a big difference. I would guess this was a big part of it maybe most of it presuming the "engine" was up to speed.
https://blog.silca.cc/road-to-roubai...lete-story-1-0
Non omnino gravis
Not just 25s, but Corsa Speeds, no less. 225g, and 1.7mm at the center of the tread, the thinnest tire the Rolling Resistance guy has ever tested. But sure, yeah, blame the fact that the tires were tubeless. Did he really think he needed the lowest rolling resistance tire on the market to ride over a bunch of loosely glued-together rocks?
I can say with confidence that there is nothing that will PUNCTURE a tubeless tire that won't puncture a tubed tire as well.
Liked 3,923 Times
"Puncture" here means only that this racer lost air in his tire and needed a wheel change. (To a racer, tire issues are "punctures". The rest of the bike issues are "mechanicals". He never did the research as to the exact cause nor did he care. (And I am guessing this came from a post-race interview. He just rode the most brutal 7 hour race on the planet.) I highly suspect he "burbed" his tires. Given how bad the cobbled road surface was in the (3) 5 star sections and that he was riding those cobbles in a field and may well not have had a good view of the them (and that he was riding over those cobbles at 25 mph), is anyone surprised? Given the course, my thought was "what were they thinking when they chose to go tubeless?" I could see putting some of his teammates on tubeless for the advertising, then giving Kristoff good tubulars with the logos blacked out. That's been done for decades.
Ben
Ben
Pretty sure that the reason for all of the problems in question where bad tire choice in terms of size and construction and I'd also put a fair bit on it that the inflation was wrong , or at least off, too.
Liked 9,456 Times
I don't think that I've ever seen that claimed; if it has been claimed, it's by a very small, and very dumb, group of people - certainly not "countless" members.
Liked 9,456 Times
