Waterford Test Ride, She Don't Seem to Track Right
Old 04-15-19, 08:35 PM
Steelman54
Bikes: Allegro Model 77, Gitane Team Pro SLX, Waterford R2200
Quoted: 68 Post(s)
Liked 57 Times in 38 Posts
OK, Got this Waterford R2200 (yep. it is pre-owned), been building it up and did a test spin in the neighborhood a week or so back. In just a few feet of rolling the stem seemed off, no big deal, stop pull out 6 mm wrench, loosen and adjust. A few more feet OK, too much back the other way. Couldn't get it right. Bike seemed fine otherwise, but I started thinking something is out of alignment or not centered (including myself!).
So, measuring and checking, I convinced myself the fork was out of alignment. I had verified frame at rear seemed good with the string wrapped around the headtube from each rear dropout.
Anyhow, finally got myself some threaded rod, nuts and washers from Home Depot and lo and behold, the dropouts at both end seem pretty much dead nuts (threaded rod at both ends are within 0.015" or .5 mm). This seems good enough to me, but need some experts thoughts.
Wheelset is newly built and dish/centering seems good, yeah, my dishing took is a piece of junk, but with care, dish and centering in each wheel certainly seems within a millimeter.
Am I missing anything here with this? Maybe reassemble and carefully check wheel centering and dish again? Get better dishing tool?
Thanks, Mike
Steelman54 is offline
Old 04-15-19, 08:43 PM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 526 Times in 349 Posts
So specifically what symptoms made you think it wasn’t tracking correctly?
jadocs is offline
Old 04-15-19, 08:47 PM
Kalec
Kalec's Avatar
I have a bike with a similar issue and I've just been pretending everything is fine because I don't want to admit something is wrong. But you have motivated me to finally get to the bottom of my issue. Sorry I don't have any advice, best of luck and thanks for pushing me to sort my frame out.
Kalec is offline
Old 04-15-19, 09:27 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,392 Times in 1,927 Posts
You need a tool like the Park FT-4 to determine if the blades are co-planar with the frame:
JohnDThompson is offline
Old 04-15-19, 09:48 PM
bargainguy
bargainguy's Avatar
Quoted: 516 Post(s)
Liked 303 Times in 187 Posts
Do you have a known good fork you can swap in? That would narrow the problem down to the fork or the frame, hopefully. I'd hate to be messing with the original fork if that's not the problem.
bargainguy is offline
Old 04-15-19, 11:12 PM
79pmooney
79pmooney's Avatar
Quoted: 4782 Post(s)
Liked 3,900 Times in 2,537 Posts
My first thought - the headset. Is it new or in good shape? (I'd be looking for slight indents, esp on the bottom races.) Proper number of balls (especially - not too many. You should be able to fit in one more. If not, remove one.) as the frame been faced so the races sit parallel? (Being a Waterford, it should be but the previous owner could have done something.) Does the fork swing completely smoothly? Or does it want to self-center? Is the headset adjusted right and not too tight?
Minor headset issues can completely thwart the most perfect frame.
Ben
79pmooney is offline
Old 04-16-19, 06:13 AM
Steelman54
Quoted: 68 Post(s)
Jadocs: Specific issue seem to be that stem (threaded) does not seem centered, not necessarily that bike drifts to right or left, if i recall correctly. I probably need to reassemble and do some more testing after convincing myself all is well
Kalec: good luck!
JohnD: what does coplanar with the frame mean? If blades are not out of position (foreward & aft) aren't they in sync with the frame?
bargainguy: yeah, i have 2 other forks which as you might guess are assembled on 2 other bikes. After checks shown in photos, i'm not convinced fork (or frame) is an issue.
79pmooney: frameset came with a beat up headset that did not rotate smoothly, i installed a brandy new Chorus headset, seems good, though this makes me think i should double check to make sure the steerer tube race is fully home. Cups pressed in with threaded rod and washers.
Good input. I know this will get figured out, but its April and I'm not riding new ride yet...... Thanks.
Old 04-16-19, 07:03 AM
2manybikes
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times in 169 Posts
From reading your post, it sounds like the stem is not inline with the front tire. If true it as nothing to do with the fork being bent. Also riding a few feet is not good enough to see how the bike handles. Ride around the block going at least cruising speed.
Starting from a dead stop will usually make the bike wobble, until you get some speed up. Did I miss something?
2manybikes is offline
Old 04-16-19, 07:57 AM
JohnDThompson
Old fart
If the blades are such that the centerline between the dropouts does not align with the centerline of the steer tube, the front wheel will not be in the same plane as the rest of the frame, and the bike will pull to one side or the other while riding. Is that the problem you're experiencing?
Old 04-16-19, 08:11 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,834 Times in 2,293 Posts
Can you ride a bike no handed? If so this will eliminate the stem's alignment from the picture.
There's a lot more to frame alignment then having the drop outs (front and rear both) centered WRT the main triangle. Uneven blade length, seat tube/head tube twist, uneven chain or seat stay lengths being the biggies. There's a lot of posts about frame/fork alignment here, over the years. Some by me. here's a link to one I kept that is a very base level of how to consider alignment in general. It's the one I could easily find right now.
https://www.bikeforums.net/framebuil...iscussion.html
Frame alignment is one of the topics best explained with both words and hands on. Here we only have words. I note there's no location provided in the OP's info. If we knew of an experienced guy near the OP we might be able to list them and suggest the OP seek their advice with bike in hand. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 04-16-19, 08:48 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
That's why I asked what the symptoms were, because if it is pulling to one side or the other but everything is aligned according to measurement, then it cold be the cables that are causing the front end to favor one side over the other. Sounds like it is visual though?
jadocs is offline
Old 04-16-19, 08:52 AM
Steelman54
Quoted: 68 Post(s)
JohnD: good point, i could probably check with a plumb bob or maybe lay it out with perpendicular lines on table or floor to at least get a feel for it.
Andrew: good link, will need to digest. I can maybe ride my SLX frame Gitane no hands, a new set up, not so sure.
I thought i had it in my profile, but i'm in SW Ohio (Cincinnati area).
Seems like i need a better feel for what it is doing, would not take long to reassemble and repeat test spin in neighborhood
Thanks. Mike
Old 04-16-19, 10:55 AM
Crankycrank
Quoted: 836 Post(s)
Liked 1,058 Times in 742 Posts
Don't rule out the possibility that the stem may be damaged or manufactured out of alighnment.
Crankycrank is offline
Old 04-16-19, 10:59 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
And Don't Forget Roads are crowned in the center, for drainage, not flat ,
so you may be attributing pull to the bike, when it's the road surface..
fietsbob is offline
Old 04-16-19, 11:42 AM
rhenning
Quoted: 380 Post(s)
Liked 106 Times in 80 Posts
I hope you meant Roads not Toads. Roger
rhenning is offline
Old 04-16-19, 12:14 PM
Steelman54
Quoted: 68 Post(s)
Everyone, really appreciate the input here. I'll double check a couple of things, but think I'll get it on the road by the weekend to re-evaluate.
Parts being used are new here, except the pedals (still running Look deltas).
Old 04-16-19, 12:17 PM
fietsbob
Bikes: 8
I have several black keys worn without lettering on them
fietsbob is offline
Old 04-16-19, 12:18 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,102 Times in 1,366 Posts
Originally Posted by fietsbob
And Don't Forget Toads are crowned in the center...
Pucker up, princess!
Darth Lefty is offline
Old 04-17-19, 07:30 AM
easyupbug
Quoted: 565 Post(s)
Liked 557 Times in 402 Posts
I found Randy's MyTen Speed web site to have an interesting trouble shooting test you might want to try out, he hangs the bike upside down. I used it to find a headset culprit and on another bike a fork that needed help. The headset showed differing planes every time it settled, frame to fork, and the tweaked fork showed a consistent slant off to the DS every time it settled. Fork was pulled and after a few minutes on our local frame builders fork table re-hanging showed the frame and fork perfectly coplanar.
easyupbug is offline
Old 04-18-19, 10:14 AM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
For those who were looking for this, its here. FREE SITE 1
WizardOfBoz is offline
Old 04-18-19, 10:30 AM
Steelman54
Quoted: 68 Post(s)
I have decided to take fork to a shop that i think will have the jig as i'm somewhat convinced it is slightly shifted to one side or the dropout slot differs. Figure its cheap and easy before i reassemble.
Mike
Old 04-18-19, 07:41 PM
Andrew R Stewart
https://www.bikeforums.net/bicycle-m...ard-right.html
Here's another of my old posts specifically about how to test a fork's alignment with simple "tools". Andy
AndrewRStewart
Old 04-19-19, 09:02 AM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,779 Times in 3,297 Posts
With the exception of the stem and handlebars not being quite lined up with the fork and wheel, might it just be that the bike has less trail than what you are used to and the steering is a little sportier and making you think something is amiss?
Iride01 is offline
Old 04-19-19, 09:44 AM
Steelman54
Quoted: 68 Post(s)
Andrew, great info. Again everyone thanks for thinking on this one.
Last night I stared at it for a long time with the fork in my vise and am convinced the wheel is canted to one side a bit and not centered under the steerer tube. I swapped 2 other wheels in and observed the same thing.
Called a shop I know figuring they would have the alignment fig, and sure enough they do. They (or he actually) keeps somewhat weird hours and aren't particularly convenient, but if I get up there with fork, he will check with me there. No stoners will be touching it. Can't get there till next week though. I may be wrong, but suspect it may have been like this from beginning, I know, hard to say for sure, but no evidence of any issues such as crash, repaint, wrinkled paint, etc.
To me this kind of exonerates my crappy dishing tool as all 3 wheels seem to show the same thing (maybe crappy tool used with patience is OK). So, hopefully I'll be on may way soon. If this don't do it, I'll probably disassemble frame and drag it up there, but I plan to stare at the rear triangle and centering in next day or so to see if anything looks off. I can do this with 2 wheels.
I may owe a few beers on this one.....
Mike
Old 05-06-19, 07:27 AM
Steelman54
Quoted: 68 Post(s)
OK, it's been a while as other things got in my way. The good news is the issue is gone and bike tracks as ot should, so just need to finish it up.
The bad news is, not 100% sure what the issue was, but it may not matter at this point.
I took fork to shop with fork alignment jig, and it was perfect. I admit I was convinced it was out, the guy (real nice guy, here is plug for I-Pro in Bellbrook, OH) gave me some tips on checking the rear triangle. The frame, again, checked out fine to me, as best i could check.
Best guess is that the centering was a bit off on my front wheel. My dishing tool seems inconsistent. So I took my used Park TS 2 apart, cleaned it up and centered it following Parks instructions as it was way off. Had to clean threads and dried up lube out of it, works well now. So, between the dishing tool and the Park stand, I'm confident I got the wheel within a millimeter. The rear seemed fine. Si, i took a couple of test rides in the neighborhood and she rides, tracks like it should. Perhaps i did not have one of the wheel fully home in the dropouts, who knows, just a guess at this point. Either way, its good.
Some pics coming soon.
Thanks, Mike
