What tires do you all run?
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4423 Post(s)
Liked 4,527 Times
I’m in the market for a fresh set of tires but can’t decide. Too many choices with pros and cons. So I would love to hear what all of you gravel grinders are running and you’re opinions on the tires. The terrain I ride is pavement to hard packed gravel and trails such as the Katy. Any input will be greatly appreciated.
Quoted: 1217 Post(s)
Liked 186 Times
What's your max size for frame fork? Are you tubeless?
IMO/E for mixed terrain I always prefer slicks. Knobbies end up costing so much more energy (weight, rolling resistance) on the pavement you never get it back on the gravel/dirt sections.
I'm running with the Bontrager GR1 Team Issue 120tpi, aramid bead, 700x40c that came with my Trek. I have them set up tubeless. I ride chip seal and gravel roads. I have been quite impressed with them.
https://www.trekbikes.com/us/en_US/e...-tire/p/24706/
Life Feeds On Life
Liked 4,527 Times
My bike can take up to 45s according to specs. I have had 40s on the bike. I’m running Schwalbe Marathons I like the puncture protection but they are heavy and slow. Looking for a faster true gravel tire. I had WTB Nanoraptors but they are worn out. I have the touring tires on to avoid flats but I’m recovered now from foot and hand repairs so fixing a flat is no problem. I’m running tubes I am still old school and don’t want to mess with tubeless.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
I have a Giant hybrid that I run Victoria Terreno Dry in a 700x40. They measure out to 42mm on a 19mm internal rim. Smooth rolling center tread with shoulder knobbys. Good all around type, not really great at any one thing but are a very well rounded tire. Rear tire worn out after 400 miles of even mix road/gravel terrain, front still holding strong at 700 miles. Run them tubeless at 35-40 psi.
Also running Schwalbe G-One 700x38 on my Diverge, they measure out to *edit 40mm* on a 21mm internal rim. I really like these tires. Great dry traction, spin easily when in mud, but very fast on the road. Treadwear is said to be poor, but only have around 300 miles on them and they're holding strong. 30 psi, tubeless, seems pretty good for a heavy rider and relatively smooth surfaces.
Quoted: 6963 Post(s)
Liked 10,963 Times
If I got only 400 miles (2-3 weeks) out of a tire, I would never ever buy that tire again.
Maxxis Ramblers 700x40 EXO TR (came with the bike). Running tubed, but will convert to tubeless soon.
I confess that they're brand spanking new, and I only have 150 miles on them, and of that only about 30miles of riding on gravel/dirt (the rest on asphalt) but they've done really, really, well on both.
Quoted: 1002 Post(s)
Liked 237 Times
Do you do the bulk of your riding on pavement with a little gravel/dirt/limestone? Or do you do a lot of grave/dirt/limestone?
I asked abotu tires the other day and people kept saying "Get slicks!" and I was like "That's nuts!...." but I've never actually ran slicks on rail trail type surfaces so I don't actually know that's nuts. It just sounds like it is. I'm open to thoughts from your real world experience.
Liked 186 Times
Yes, but it's not really an issue if I'm riding by myself or with a non-racing group. I just go a little slower in low-traction corners and pedal seated more on the looser stuff. Otherwise there's not much difference. The lower weight and lower rolling resistance (and perception thereof) are why I prefer slicks for mixed terrain riding. They're good enough on gravel or dirt and much better than knobbies on pavement. Especially once you get slicks in 40mm and above, they're better than one would expect compared to narrower slicks.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
It took about 3 months to wear it out, miles tracked by Strava. The tire when new doesn't have a lot of tread, maybe 2 - 3mm. The center of the tire was worn smooth and was replaced, I still have one new tire ready to go on when needed. The current tire seems to be doing better with wear. I have other bikes that I ride too so longevity isn't a huge deal. That being said when these tires wear out I'll try something different.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Also running Schwalbe G-One 700x38 on my Diverge, they measure out to 42mm on a 21mm internal rim. I really like these tires. Great dry traction, spin easily when in mud, but very fast on the road. Treadwear is said to be poor, but only have around 300 miles on them and they're holding strong. 30 psi, tubeless, seems pretty good for a heavy rider and relatively smooth surfaces.
They are as close to slick as a tire can get without actually being slick.
I may try another pair now that I have new wheels. Gravelking SK just don't roll as nice on pavement. The G-One Allaround feel like a high-end road tire. It wears out as fast as one too.
My only concern is wet Georgia clay. We rode through some mud pits last Saturday and I skirted the edges where the tire was rolling on the side knobbies and I could have easily slid down into the water. Gravelking SK were really impressive in this situation. .
-Tim-
I pedal in my sleep...
Panaracer Comet HardPack 700x38 and only about 50 miles so far. First and only gravel tire experience so take that for what it is. Mostly rail trails, some loose gravel, a little pavement. They were cheap.
Likes For str8jakett:
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I use ByWays on my 650B bike and love them--they're of course pretty highly regarded by now. On my 700c bike I have Surly Knard 41's. I'm surprised that outside of the Surly crowd more people don't consider them. I find them to be excellent all-around tires, and very good on all manner of gravel and dirt roads.
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
Clement/Donnelly MSO 120tpi 40mm.
Fast, light, comfortable, long lasting. Tight packed tread
Likes For mstateglfr:
Liked 186 Times
For regular tubed riding knobby I like the Kenda Happy Medium, it has small diamond tread in the center so it rolls very well but also has aggressive side lugs so it corners great. The tubeless version appears to be much stiffer and poorly riding but the tubed versions are great.
Quoted: 101 Post(s)
Liked 41 Times
curious about these...any thoughts about how they perform? I could probably fit the 700x48 version, but have never tried a tire this slick (well, besides wholly inadequate 23mm road tires). I’m thinking at low pressure they’d be great for 90% of what I’d ride, but not sure how they’d do when I need traction, like looser gravel and steeper hills.
Non omnino gravis
Hutchinson Overide TR. They roll remarkably well on pavement, they can handle just about any condition other than deep sand or thick mud, and they last. I got 2,800 out of the last rear, 3,000 out of the one before that, and a mind-bending 5,800 miles out of a front.
Current set have only been mounted for 6 weeks, already past 1,000 miles. I ride 'em absolutely everywhere.
Life Feeds On Life
Liked 4,527 Times
Thanks everyone for their input on gravel tires too many options to choose from but everyone’s opinion will be considered when I press the buy button.
Life Feeds On Life
Liked 4,527 Times
Bikes: 1988 Specialized Stumpjumper Monstercross Touring Rig, and a couple of others
Quoted: 46 Post(s)
I can tell you what I"m NOT riding anymore:
Maxxis Ramblers 700x38. Nope. No mas.
Quoted: 910 Post(s)
Liked 288 Times
Another vote for the Hutchinson Override, especially suitable on the rear. It offers plenty of traction on any surface except wet earth. However, it's less than ideal on fast descents on very loose gravel when installed on the front, so I use a Vittoria Terreno Dry on the front unless the route is flat. Both of these tires are fast rolling and smooth riding. The Override works well on the front 99% of the time but requires extra caution on loose conditions at higher speeds. The Terreno dry provides a surplus of traction on loose gravel and would allow a more aggressive descent than the Override.
Maybe I was overly optimistic, but I just purchased my first pair of tubeless tires, ended up going with 32c Hutchinson Sectors. Riding a mix of packed dirt roads and paved, but I'll be sure to test them on some of the Class IV jeep tracks around here. I've ridden Conti Gatorskins in 28 on mixed terrain before (mostly thinking of the Ronde de Rosey, mix of paved roads and dirt paths, sometimes pretty rooty) without any issue, but we'll see. Supposed to be doing a ride at the beginning of June, hopefully it won't be wet. Will report back.
