Sail bike?
I am not sure the question of 2 wheels vs. 3 was answered. Most of the links don't work on this resurrected thread from 05! I think that 2 wheels would work, sailboards have no keel to speak of, so the riders steers the board to make the thrust vectors aligning to go the path they choose.
I do not think the side thrusts would be too great, bike would lean strongly into a wind, but the wind would be pushing, so the main thrust vector is close to aligned with the wheel.
Each time I've done long distance (Canada to Mx) rides, I've thought about this "sail" idea. I'm not an engineer, but my concept is to use the wind only when its coming from the rearward direction. The mechanism I have in mind would resemble half of an umbrella when open. Some configuration of strong light fabric attached to lightweight "stays". It would require an easily accessible lever(?) located on the top post or seat post to instantly open to take advantage of the wind, or close the sail, so as not to fight a headwind. I'm not sold on a sail attached to the front set of the bike, and rising like on a sail boat. My gut sez visibility issues, sideways tipping forces, etc While these issues may not be a problem for three wheelers on ice or sand with plenty of maneuvering room, traveling on the side of the road is hazardous enough without adding to it... (but then again, I'm not an engineer) Just a thought.
Trikes are the thing with a mast sail, or a Kite Tow..
we have 3 wheelers and para sails here.., Oregon's beaches thanks to foresight by Past Governments are Public.
Quoted: 5779 Post(s)
Liked 2,576 Times
speeds of 30 mph? Maybe I'm misunderstanding sailing, but in my mind, it would be much harder to go 30mph unless the wind was going that fast as well.
Sailing isn't like an electric motor. It doesn't help you go faster, it just helps you more closely match the speed of the wind.
The reason you go faster upwind than down is that when sailing upwind, as you pick up speed you add to the wind speed, and get more power whereas when going downwind, you lose tailwind and power as you go faster.
BTW- Iceboats can hit speeds of well over 100mph in 20-25mph winds, with records of roughly 7x the wind speed. Some years back people built sail trikes based on the design of iceboats. Sail bikes can really fly, buy they need large open spaces to operate in.
The problem with sail bikes is that they're limited to following roads which might turn directly into the wind putting the sailbike "in irons".
FB
Chain-L site
FB
Chain-L site
Uber Goober
Holy zombie thread. This thread was started before they had internal combustion engines, I think. Wow.
Liked 2,576 Times
2004-2013, could this be a new record?, and not that many posts.
FB
Chain-L site
FB
Chain-L site
The only way to sail a bike faster than the wind is to have a wide vehicle that can resist a serious tipping power.
A run, when the wind is at your back, allows you to approach the speed of the wind and applies little to no tipping force to the craft.
When the sail is hauled in and the craft turned to cross the wind, then the speed picks up. I think the optimum angle (for a boat) is about 30 degrees off of the wind on either side. The elusive component that allows a sailboar to move forwards and not just blow sideways is the keel or board. The boat has what is literally a wing flying through the water underneath it. The propulsion (other than on a run, when you have a floating parachute) is caused by the fighting of the wing under the water against the wing in the air (the sail).
If you had a wide trike, you could probably sail crosswind. The keel's job would be provided by the wheels (preventing the sideways motion of the craft) and as long as the rig was wide enough to be stable, you could probably get some speed up.
The biggest problem is that you are heavily limited by the direction of the wind, so you would probably only be able to sail in a large open area, like the salt flats or a big sports field. I don't think that a sail would be able to provide any advantages or even be very feasable in town or on trails, unfortunately.
That said, I'll put in a six pack to the first person to create a sailbike capable of traveling crosswind at speeds greater than the measured wind (without pedal/motor assistance, naturally). Gentlemen (and ladies); start your welders!
outrigger(s).
the digitalmouse
to add to the zombie revival:
I've tried the Whike at a past SPEZI special bikes show in Germany. Was actually impressed when it got underway with a crosswind on the test track.
Not quite there yet
Bikes: A bunch of old steel bikes + an ICE trike
When I was 11 or 12, I put a sail made out of a piece of plastic on my bike. It didn't go well, but I did appreciate the immediate feedback.
Bikes: Fuji S-12-S
The whole idea is so cool!
Not real handy for the el cheapo rider to get into, though.
At least if the wind will not blow, you still have your pedals.
Sail bike has a standard 1.6 m[SUP]2[/SUP] sail and can reach speeds up to 50 km/h ( 31 mph ) with wind speeds of 4-5 bft (13-24 mph ). It can be legally used on both bike lanes and streets in the Netherlands and UK. Activating the front brake releases the sail's spinlock, assuring there will be no more wind-propulsion.The Whike features a three piece aluminium mast that can be stowed away on board when not needed. It is also equipped with 18 gears and the front sprockets are custom made for the Whike. To maintain safe and responsive stopping the trike is fitted with disk brakes on all wheels. The cycle also has a handbrake function to prevent it sailing away while without rider. The frame is available in black or white chromium molybdenum alloy steel, other colours are possible for an additional €100. The Whike weighs 23 kgs including the sail and can carry a maximum weight of 115 kgs including luggage. The sail also has the advantage of aiding visibility of the cycle on the roads.
Liked 2,576 Times
Not quite. knots are nautical miles per hour. A nautical mile is 1.15 (land) miles, so a knot = 1.15mph. The issue isn't the power source (sail, wind) but whether you're in a boat at sea.
FB
Chain-L site
FB
Chain-L site
genec
Quoted: 13658 Post(s)
Liked 4,532 Times
The nautical mile remains in use by sea and air navigators worldwide because of its convenience when working with charts.
Quoted: 22 Post(s)
I invented a 43 panel Tyvek inner-frame sail for my 2 wheel bike. all explained here -https://www.roadrecumbent.com/
Still learning
PRE GOPRO
GOPRO
If you lived in a European mobile home community, you can buy multiple gopro cameras and this wind chaser!
GOPRO
I guess I'm reviving the thread.
Can we just ignore for a second, the sideways force and pretend that tipping over on a 2-wheel bicycle is a non issue.
Is it at all possible, then, to have a sail on your basic 2-wheel bicycle that can go against the wind? That's the most practical reason - to go against the wind with ease.
If you have your basic mountain bike with a milk crate at the back (mine). Is it possible to steer your handlebars with 1 hand and have a sail attached at the back with a handle of sorts to steer the sail with the other hand? Any time that wind is annoying for me, it's a constant wind. Wind gusts from 0-30 MPH don't really happen... it's usually a constant amount that I'd like to go against.
- What would the sail look like/weigh if at the back of a bike?
- Is it even possible to go completely straight? I thought I read that sailboats that go against the wind have to go on an angle and then shift their sails to go on an angle the opposite way. If a 2-wheel bike can't go straight then this whole idea is moot.
Liked 2,576 Times
Ice boats use the same principle, and are so efficient that they can move at as much as 7 times the wind speed, and point upwards at much smaller angles to the wind than sailboats because their blades bite the ice and don't slide sideways (leeway). Iceboat speeds well in excess of 100mph are very common.
So, in principle, nothing stops you from doing something similar with a bike, though as a practical matter, you'd need a trike to keep from blowing over. Wind land cruisers already exist, but maneuvering space requirements pretty much limit them to things like salt flats, airport runways, or huge parking lots.
If shopping malls weren't open 7 days per week, they'd make great venues for land cruiser races, where the goal would be to go all the way around the structure on the surrounding parking lot.
FB
Chain-L site
FB
Chain-L site
Quoted: 1324 Post(s)
Liked 927 Times
You also need to be able to see all around you in order to avoid obstacles. I'd use a clear material for any sail.
Cheers
probably the most practical option would be a vertical wind turbine with a chain drive, mounted behind the rear wheel. it's low to the ground so it won't tip you over as easily, you can adjust the speed/torque and it works no matter which direction you or the wind is going.
Bikes: 2006 Falcon Explorer Hybrid, 2008 Landrover Visalia Crossover, 2010 Cargo Cycles Senton, 2010 Cargo Cycles Capability, and a 2001 AVD quad pedi-van, 1980 Peugeot Carbolite 10sp racer
Quoted: 21 Post(s)
Liked 24 Times
I am currently building my 4th tadpole sail trike. The first started out as a sail quad, but soon was adapted to a trike.
2015/16 I pedalled and sailed from Norwich down to Harwich, caught the ferry and crossed Holland on mine from Europort Rotterdam to Nejmegan and back again. I do maybe 750km on each trike before selling them on, with any left over proceeds after intial build costs going to a local charity
My 2017 Tadpole sail trike will feature a Sturmey Archer 8 speed IGH C/w with 70mm drum brake to match the front SA hubs with 70mm drum brakes I have used for the previous 3 years.
This time I am actually going to get around to photo blogging this trike build, and it may be followed here:
2017 Tadpole Sail Trike Build
" data-width="500" data-show-text="true" data-lazy="true">
2017 Tadpole Sail Trike Build " class="fb-xfbml-parse-ignore">Facebook Post
Liked 2,576 Times
OTOH a sail works best in cross winds, and will work at any angle including upwind up to about 35-45° of dead ahead.
FB
Chain-L site
FB
Chain-L site
Quoted: 18373 Post(s)
Liked 4,508 Times
An old topic?
No mention of the faster than the wind propeller driven wind vehicles?
https://en.wikipedia.org/wiki/Blackb...8land_yacht%29
This Greenbird is interesting. Apparently reaching 126 MPH in 40 MPH crosswinds.
BBC NEWS | Technology | Wind-powered car breaks record
Greenbird Measurement Report
