Does endurance weight lifting help?
Location: Was born and raised in Philadelphia, PA. For the past 30 years we have been living in Fort Smith, AR
Bikes: Two road bikes, Zanes and Specialized.
Quoted: 31 Post(s)
So I’ve been doing strength building workouts at the gym since July. I focus on lower body, and do squats, using several different machines and free weights, so that I target all the muscles. Also do calf raises, and hamstring curls. I do 4 sets of 9-11 reps. I do calf raises until I can’t raise my heels high enough. I do this twice a week with a two day rest. At the beginning of October I started doing the same workouts but using an endurance plan where I use about half the weight and do 25 or so reps. I’ve read where this will help with endurance.
So while I think this sounds logical, that is, you buildup muscle strength, then do endurance lifting to help you on the long rides, I just can’t find any data to support this idea. Can you guys tell me if this makes sense, or what should I be doing.
Thanks
Neverquit
Thanks
Neverquit
Quoted: 4227 Post(s)
Liked 2,491 Times
The main purpose of lifting weights is to build and maintain muscle and strength, especially important as we age and get older. I highly doubt that lifting weights even for high reps will have any significant improvement on long distance endurance...A typical endurance ride is few hours long, a typical weight training session is only 45 - 60 minutes long....Doing 25 - 30 rep sets will build some muscle and strength and improve your overall health and fitness but it won't do much for bike endurance....To get get better at endurance you need to spend time in the saddle and ride regularly...
Bikes: Bicycles? Yup.
Quoted: 502 Post(s)
Liked 1,684 Times
I'm sure less weight and more reps are not going to reduce your endurance, but the proven way to build cycling endurance is long duration rides, about twice a week. Every 2 weeks add 20 minutes to your long rides. BTW, my idea of endurance is a century, nothing ultra.
climber has-been
Quoted: 3581 Post(s)
Liked 3,765 Times
In another study, strength training increased lactate threshold by 12%.
This study of college women found that a low resistance/high repetition exercise produced a larger gain in endurance than either high resistance/low repetition or medium resistance/medium repetition exercise.
Likes For terrymorse:
Quoted: 502 Post(s)
Liked 1,684 Times
Quoted: 31 Post(s)
Well, from doing more reading, I think you're right. It just made sense to me, that endurance lifting would help and improve your muscular endurance while riding, but it just doesn't work like that. So, it looks like when I hit the gym, and that'll be tomorrow, I'll go heavy, and just ride more.
Thanks for your input Woflchild, I appreciate it!
Quoted: 31 Post(s)
Thanks again.
Quoted: 31 Post(s)
Strength training has also been found to increase aerobic endurance. In one study, adding strength training to cross country skiers increased time to exhaustion by 20.5%.
Liked 2,491 Times
climber has-been
Liked 3,765 Times
Only endurance at performing the exercises which were used in the study was improved, no improvement in endurance on a bike was mentioned and no improvement in any other endurance activity was mentioned. The gains in endurance was limited to the exercises used in the study....Having said that, I am still a big fan of weight training but not for the purpose of improving bike endurance or any other endurance activity. I just lift weights to maintain overall fitness and strength.
"Despite no changes in treadmill VO2max or cycle peak VO2, a 33 +/- 5% increase (P less than 0.001) in cycling time to exhaustion at 75% of peak VO2 was observed following (strength) training."
Unfortunately, those studies didn't test if changing the resistance amount made a difference.
just another gosling
Quoted: 3919 Post(s)
Liked 1,982 Times
When I started doing resistance training, 25 years ago, I had the convenience of a wonderful gym with a big weight room, lots of equipment, but few patrons in the evening. I also had a copy of The Cyclist's Training Bible. Friel said that if you are starting out, a good idea would be to do circuit training with about 9 different lifts and starting with 3 sets of 20-30 reps. So that's what I did, because I could, and I did it twice a week, Tuesday and Thursday. Being a fan of conditioning, I chose the 30 rep option. Circuit training means you do one set at each station and then go around again for the second and third sets. I wore a heart rate monitor and I'd let my HR drop some, but not too much between stations. I stayed aerobic.
I chose to do all three sets using the same weight for the 3 sets at each station. Just to be clear, I used a different weight at each station. I chose a weight which made it impossible to do all 30 reps for the last set, 28 reps being just perfect. I'd increase the weight for that station if I hit 30 on that last set. I increased the weights a lot over that first winter. By the next year, I would work in with the big guys on the leg sled if it was busy, just doing the standard 10 or so reps. So yeah, it worked and I got strong and also got way faster on the 60-80 mile weekly hilly group rides. I could do a fast 400k with no training ride over 60 miles. And this was in my 50s and early 60s. So yeah, it worked.
However, once I'd done this year 'round for 3 years, the time it took became an issue and I changed over to the standard method of 3 sets of 10-12 reps at each station, which did well for strength maintenance.
My circuit was:
1-Hip extension (barbell squat)
2-Seated row
3-Back extension
4-Hip extension (leg sled)
5-Bench press
6-Heel raise (one-legged, no weight, full range of motion)
7-Stiff-legged dead lift
9-Lat pull
When I became interested in serious road riding it was the year that Bicycling sponsored a team of four over-50 y.o. riders on RAAM. I can't remember which rider, but one of them could sled 450 lbs. 50 reps. Yeah!
My circuit was:
2-Seated row
3-Back extension
5-Bench press
9-Lat pull
Results matter
Results matter
Liked 1,982 Times
Thanks
Neverquit
Thanks
Neverquit
Results matter
Results matter
Quoted: 31 Post(s)
My circuit was:
2-Seated row
3-Back extension
5-Bench press
9-Lat pull
My circuit was:
2-Seated row
3-Back extension
5-Bench press
9-Lat pull
Liked 1,982 Times
Thanks Carbonfiberboy! Your workout seems to be what I'm trying to do. And you're correct, you just can't quit! At 77 it would be a major uphill to get started again, so no manner how tired or whatever I am, I go to the gym or ride. And 99% of the time I feel better afterwards.
Results matter
Results matter
Quoted: 31 Post(s)
Ah! you're so right! I'm always the last guy in, or they're all waiting on me at the top of the hill. That's why i've decided to do leg strengthening during this off season. And thank you for the encourgement.
Here are some thoughts from the top of my head.
Low weight high reps are for hypertrophy. They bulk up your muscles. But endurance athletes like swimmers, marathon runners and cyclists aren't looking for bulk.
To endure, you need strong cardio. The weight bearing exercises that really put stress on cardio are squats, DL and the leg press machine at high rep (go deep so you use your glutes instead of just your quads).
But having said all that, do a lot of hamstring and leg press exercises for cycling. DL training helps you maintain form when climbing (you use your arms to pull on the handlebars). And I do believe high reps help contrary to what I first stated.
Quoted: 31 Post(s)
Quoted: 4605 Post(s)
Liked 5,145 Times
Likes For PeteHski:
Version 7.0
Bikes: Too Many
Quoted: 1363 Post(s)
Liked 2,526 Times
Here are a couple of ideas for you.
Weight training on the bike - The pedal stroke is round and slightly non linear. And there is a speed of muscle contraction that is generally greater than done in the gym. And one uses one leg at a time versus pushing with both at the same time. Strength coaches for sprint teams know that and adjust weight workouts in the gym even going to the trouble of taking videos of pedaling and attempting to match the setup of the leg press to match individual style. One leg box jumps are also in their repertoire.
So when one is on the bike. one can do seated starts and standing starts that will mimic one leg dead lifts and the muscle action and speed are perfect for cycling. One can put the bike in a big gear and do flying 100 meters to improve strength on the bike. This is right out of the playbook from Team USA sprint team.
Will any strength work that increases muscle strength as well as muscle size and weight improve endurance? The answer is yes, stronger muscles fatigue less assuming that they are then trained for endurance. If all one does is strength work then one will have little endurance. Every sprinter knows that endurance is a speed killer. So track sprinters have just enough endurance to get through a sprint competition. That does not mean that they could not have endurance it means that they choose not to.
One way to make sure that strength gains in the gym are locked in and the proper neurology is developed for that increased strength is to ride the bike directly after the weight workout and do lower cadence higher power short intervals. Of course, this trashes ones legs but it will build strength, power and endurance and maximize the time in the gym with a focus on endurance improvement. Also, keep the muscle movement in the gym faster being careful not to use too much weight and go for more sets and reps with focus on one leg movements. One leg dead lift. Not so easy to do.
Likes For Hermes:
Liked 1,982 Times
Liked 5,145 Times
Or just ride faster, which is usually more enjoyable.
Liked 5,145 Times
Likes For PeteHski:
Liked 1,982 Times
I think the new feminine perspective has something to do with today's vanishing tandem teams and tandem sales. We used to see more tandems out on the road than we see today. Now everyone wants to control their own destiny. Imagine that! Still, I encourage couples to give it a try. It's a relationship accelerator and time is short.
Results matter
Results matter
