Bearing Race Question
Quoted: 659 Post(s)
Liked 595 Times
Would an auto parts store (we have a local shop from vintage days) have a line on this bearing race? When I disassembled the rear coaster brake hub on this 1898 Glenwood I discovered why there was a binding-up feel to it. This was a casualty of riding without lube. Here is a pic:
Well, I'll offer an opinion for what it is worth. The piece in your hand looks like a bearing cage, not a race. What does the race look like? And, no way an auto shop has a bicycle bearing cage or race. if that is indeed the cage, why not clean up and put in new bearings of the correct size. If the race is shot, then life is probably more difficult. Good luck.
Quoted: 659 Post(s)
Liked 595 Times
Likes For OldsCOOL:
Quoted: 2337 Post(s)
Liked 2,818 Times
loose ball might be plus one ball based on the spacing of the cage.
check the bearing race (pick would help) if it is toast a machinist could recreate
Likes For squirtdad:
Quoted: 1088 Post(s)
Liked 1,205 Times
Since some of the retaining tabs are still intact for measurement, wouldn't something like this be a good candidate for 3D printing? Just spitballing, as I know very little about the process of actually engaging someone to have something like this manufactured.
Likes For noobinsf:
Quoted: 659 Post(s)
Liked 595 Times
Took a quick trip to the hardware store to grab a few extra bearings. Got home, greased it up with a total of 7+2, mocked it up and it spins like silky smooth. Feels like 1977. Thanks for the tip.
Quoted: 4510 Post(s)
Liked 6,377 Times
New balls, s-can the cage, set them up loose, run for awhile, recheck and adjust as necessary.
I know the drag is substantial in terms of perfect, but unless you're Eddy Merckx it won't matter very much.
Likes For merziac:
Location: Southport, North Carolina, USA & Pevensey, East Sussex, UK
Bikes: 1)1992 Trek 970, 2)2010 Trek 6500, 3)1973 Colnago Super, 4)1955 Freddie Grubb Meteor. 5)1993 Airborne Ti-Hag Titanium. 6)1936 BSA 602DX Roadster. 7)1957 Philips P2 Sports. 8)1955 Dayton Roadmaster. 9)1948 Humber Clubman. 10) 1949 Sunbeam WA3 Wayfarer
Quoted: 157 Post(s)
Liked 85 Times
Cuius summa inventa
Cuius summa inventa
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
FWIW (you already solved the issue) they are out there.
Generally order by # of balls X ball diameter.
Just one source
https://wheelsmfg.com/products/beari...retainers.html
Just one source
Absolutely no way that was an original bearing. Someone else's best guess/approximation. In the Anglo-American world in 1898 ball bearings were still turned on lathes. Accuracy at best was plus or minus 0.001" and surface finish about the same. You would not want original. Someone else figured it out and so can you.
Quoted: 659 Post(s)
Liked 595 Times
Going to chime in to say that I often use heavy automotive bearing grease to sustain a compromised bearing situation where spindle, cup, cone, etc are pitted and may not be practical to find or spend for new.
Likes For OldsCOOL:
Quoted: 659 Post(s)
Liked 595 Times
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,469 Times
It looks like something we would have gotten from Merry Sales Company in the early seventies (and probably for a couple decades before that.) They came in a wide range of sizes.
Brent
Brent
I wish I had a good answer. Have tried to best of ability and thrown some time at the question and not come up with good answers. I have found that as late as 1900 cycling companies were making capex investment in lathes for bearing manufacture. So I will say your bearing is 20th century and can't do better.
Bicycles were the killer app that made bearings a thing. Before bicycles arrived it was done with bushings or with journals run in Babbitt metal. Or you just didn't design it. When bearings were made it was an extremely special one-off. Then bicycles created a demand. Bikes wanted little bearings, not the specials for locomotives. Everyone was working on a way to supply bikes with bearings and no one had anything better than cutting them. Might be done on an automatic screw lathe but that was still basically one at a time, slow and expensive. And crude. Tech was changing practically daily in 1890s. Other factor in play was after the huge boom in 1892-3 bikes did not completely remain fashionable. They were expensive as all heck and the industry needed fashionable gentlemen to be spending cash. Those guys stop spending when it stops being cool. Then automobiles happened.
The real kicker is that in Germany they were grinding bearings in bulk as early as 1879. They had been making marbles since early eighteenth century and figured out same process worked with steel just as with marble or agate. But outside of Germany no one knew. One of the reason German 'oldtimers' are used and ridden a lot more than American bikes of similar vintage is they always had good bearings. The rough lathed bearings beat the bikes to death.
SE Wis
Liked 3,390 Times
See pages 34-38.
https://ntrs.nasa.gov/archive/nasa/c...9810009866.pdf
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Ryp,
If you could measure the OD of the cage and use a micrometer to get the diameter of the balls I'll look in my parts stock and see if any match your needs. That is if you want to say with a caged bearing set. My pleasure to help you out sir!
The add one ball and grease well should work of the races are still in good condition, also. I have a good stock of high quality, loose Campagnolo balls on hand, you are welcome to some if you need. Just give me a shout.
Bill
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
Quoted: 659 Post(s)
Liked 595 Times
Ryp,
Bill
Bill
Likes For OldsCOOL:
Quoted: 659 Post(s)
Liked 595 Times
And yes, we used to play marbles with locomotive ball bearings when we were kids.
Quoted: 195 Post(s)
Liked 207 Times
You absolutely can not toss the cage for the balls and just add the balls alone. You'll need at least one or more ball to make the spacing uniform. I can't tell from the photo but the balls looked scarred and if that's so, check the race and cone for scarring. That will determine your next step. In most cases I'd try to buy a new cage style bearing replacement or half a dozen balls to add to the converted loose ball style bearing. I use marine grease or boat trailer grease.
Likes For Cycle Tourist:
Not disputing this but some places were producing beyond a lathe.
See pages 34-38.
See pages 34-38.
On a 1/4" ball accuracy to 0.001" is a grade 4000 bearing. That source says someone (?) got down to half that error in 1890s. OK. Grade 4000 or grade 2000 is a visibly rough ball, oldscool has shiny bearings.
Also note that as late as 1980s Roger Piel was producing and Sean Kelly was racing pedals with bushings instead of bearings. Where there's a will there's a way.
Likes For 63rickert:
Quoted: 1858 Post(s)
Liked 606 Times
Quoted: 659 Post(s)
Liked 595 Times
This is the subject bike:
Likes For OldsCOOL:
Quoted: 1372 Post(s)
Liked 1,751 Times
Pitch the cage and install a set of new ball bearings, without a cage. The cage just makes it easier (cheaper) to install bearing. This goes for head set and wheel hub bearings also...
