Tubeless users: do you still carry a flat kit?
That is, a standard flat kit (tube, CO2, levers, patches, etc.)? I know you can use a tube in a tubeless tire in an emergency, but is that something I'm going to want to do, with all the sealant still in there? Wouldn't it make more sense to carry extra CO2?
Quoted: 892 Post(s)
Liked 2,050 Times
Plug kit, tube, pump, patch kit.
Sealant is the first line of defense
Plug kit is next
Tube next
Patch for when the sharp bit sticking through the tire punctures the tube.
On a long ass ride, I'll carry a second and maybe third tube, and maybe even a folding tire.
How much crap I carry is somewhat dictated by how much I want to avoid walking or calling for help.
Plug kit is next
Tube next
Likes For downtube42:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,026 Times
Nothing, not even a mini pump. Approaching 20,000 road miles without an issue. If I was touring I’d carry a plug kit, a patch kit (to repair the inside of the tire for a bad problem), a tube and a pump. But within 30-40 miles from home I don’t bother.
Quoted: 6934 Post(s)
Liked 10,939 Times
If I had a reliable ride home, I might go without a kit, like MattTheHat in the post above. But my wife works hard, all day long, so that I have all of this free time to ride my bike...So I carry a plug kit, two tubes, a pump, couple tire levers, and a patch kit.
The only time I've had to stick a tube into a tubeless tire was when I ran psi that was waaay too low on a very rough trail, and the tire burped out so much air that a tube was the only solution. Lesson learned.
Likes For Koyote:
Also keep in mind CO2 doesn't play well with some sealants and you may need to change the sealant after using CO2.
I asked a similar question, a couple weeks ago, when I decided to go tubeless for my new mountain bike. I received a lot of info about why you should still carry a repair kit and maybe even a tube. Since then, I have added a complete repair kit to my carry-on gear and even found a solution for carrying a big ass replacement tube.
https://www.bikeforums.net/mountain-...ess-tires.html
Quoted: 942 Post(s)
Liked 526 Times
Plug kit, pump and multi-tool. That's it....99% of the time a plug is going to work for punctures that cannot seal. Anything beyond that I'm calling my wife and she can pick me up (hasn't happened yet)...but I'm not going to get that involved on the side of the road trying to repair a tube or put one in for that matter.
Yes, on four of five bikes I currently have setup tubeless. The one exception is my fatbike where a tube is so bulky that I generally go without. Of course, my fatbike is the one bike I've had a flat on in four years of riding tubeless, lol.
Likes For Hiro11:
Quoted: 1455 Post(s)
Liked 1,477 Times
I carry a spare tube along with 2 CO2 shots, levers, patch kit, and a tubeless plug kit. I don't carry a mini-pump, as I'm typically riding in well populated areas and fine calling for a ride or taking transit home if I'm really stuck. If I'm doing a gravel ride in a rural area where I might not have cell coverage, I'll toss my mini pump in one of my back pockets.
Road tubeless is weird. I have more confidence that I won't flat from riding over glass or thorns or whatever, but I'm also nervous because I know if I do flat, I'm probably screwed. My tires (32mm GP5000 TL) fit so tight on my rims that I'm not sure I'd even be able to get a tube in there on the side of the road if I needed to. I've never used the plug kit so hopefully I could figure it out and be successful in plugging a hole. With 2 CO2 shots, I only get one try with that before I'd have to try to get a tube in.
I'm fine calling for a ride if I'm stuck, so with that in mind I'm not even sure why I carry the tube. I guess just out of habit.
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Just curious, for those with plug kits, do you also bring sealant? If a TL tire flats completely, does this somewhat mean that all of the sealant sprayed out of the hole that caused the flat, and don't plug kits require sealant to work?
For those who bring tubes as a backup, do plugs work with tubes -- IOW, I'd think a tire boot might also be necessary if the hole was too big for sealant to take care of?
Quoted: 18397 Post(s)
Liked 15,491 Times
Yes.
Quoted: 20805 Post(s)
Liked 9,448 Times
I don't understand the confusion about plugs, tubes and boots. If a cut is too big for the sealant, you use a plug. If a cut is too big for a plug, you use a tube. If a cut is big enough that the tube threatens to herniate, you use a boot. A plug isn't going to hinder a tube, but you wouldn't use a plug with a tube (unless there was already a plug in place from a previous puncture).
Likes For WhyFi:
Quoted: 942 Post(s)
Liked 526 Times
I have no practical experience with plugging a tube while it's in the tire, but my knee jerk reaction would be...it won't be very reliable due to the elastic nature of the tube...on the other hand, if it is inflated to the point it has enough pressure against the tire, it might get you home....at which point I would patch the tire from the inside and set it back up tubeless when I got back.
Quoted: 166 Post(s)
Liked 252 Times
I am gonna set it up tubeless in the next couple weeks and carry a plug kit and pump. No way I am going to waste space with that tube(its the size of like 3 sandwiches, I would rather have a flat and a sandwich).
Likes For sloppy12:
Advocatus Diaboli
Liked 1,531 Times
If a cut doesn't seal within the first 30 seconds, it's probably not going to seal on its own, but that doesn't mean that all of the sealant is gone. Rotate the tire so that the cut is facing up, pop in the plug and give the wheel a spin.
For a cut too big for a plug, as you say a tube is the answer, so hence why I questioned why nobody above included above a tire boot in their kit, but they do have tubes?
Interesting to also see one mention of bringing a pump and a plug, but no CO2. Presumably there are now combos for TL Tire/Rim where a TL tire can be seated with the relatively low volume minipump capabilities.
Advocatus Diaboli
Liked 1,531 Times
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
sometimes a tire is just beyond hope without a tube in it. most of my rides start and end at my driveway and walking home 20+ miles would suck. over the past 10 years or riding tubeless tires, I've had to put a tube in my tire 2 or 3 times over thousands of miles. I've also used my spare tube to bail out some riding partners. it's just common sense belt-and-suspenders preparedness.
Liked 9,448 Times
Ok. I was just picturing a flat from a larger hole that sealant doesn't work on, meaning the tire goes completely flat pretty quickly and by the time one comes to a stop to repair, that all of the sealant would have squirted out that hole.
I do carry a tube but don't have a dedicated boot; I always have a bill or a wrapper on hand.
CO2 might be handy for re-seating, but is generally not needed on the road. Many tires will stay seated even when completely flat and re-seating isn't a concern if you're going to pop in a tube.
n00b
Quoted: 428 Post(s)
Liked 466 Times
for the emergency, last resort tube: carry a slightly undersized tube. for my 29x2.3 tires, I carry a tube made for 275.x2.3 tires. I have not had to use it yet, but many riders do the same and report that it worked well. for my 650B 47mm gravel tires, I carry a 700x35-ish tube. I think it should work in a pinch, but again, I have not needed it yet.
Quoted: 166 Post(s)
Liked 252 Times
n00b
Quoted: 428 Post(s)
Liked 466 Times
I'll let someone with experience chime in on that as I have absolutely zero experience with fat bikes. I rode one once for about 30 seconds and did a wheelie on grass.
Liked 9,448 Times
Likes For WhyFi:
n00b
Quoted: 428 Post(s)
Liked 466 Times
you might be surprised at how much it will stretch. granted, the more it stretches, the thinner it gets. it's a risk but if you goal is to get you out of the woods or home from a long ride, almost any tube can work as a last resort.
Likes For mack_turtle:
