New bike, foot pain, flat pedals
Hello all,
I recently put together a new bike and have started experiencing foot pain. It feels kind of like a pain or cramp in the arches of both my feet, emanating from the point where the balls of my feet contact the pedal (using flat pedals). I put this bike together recently from a used frame I bought online and parts salvaged from my previous (now broken) bike. I've tried adjusting all aspects of the saddle over and over again (height, fore/aft, angle) but can't find a position that is comfortable for my foot. I'm not sure what could be the problem or what I could try next to address the issue. I would take this issue to a professional bike fitter but bike shops are not doing that in my area thanks to covid. This is my only bike and I use it for everything (which includes my daily commute, some light trail riding, and occasional exercise runs).
Details on me and the bike:
Could pedals be an issue? I am using the same (crappy) flat pedals that I had on my previous bike. I think they are on the small side, and don't have any pins for grip (cant post any pictures). I've used bikes that are too big for me or too small for me in the past and never experienced this issue before.
Thanks for any advice!
Edit: I didn't start experiencing this issue until about 2-3 days into riding this bike. I don't have specific cycling shoes but have experienced the pain wearing several of my shoes/boots
- Just around 5 ft 9 in (175 cm)
- 82.7 cm inseam (measured using a hardcover book shoved up my inseam and against a wall)
- 56 cm surly cross check (I know this is a bit on the large size, but there's just no supply of frames around me)
- Im using an adjustable stem but it is around 70 mm out from the steerer tube
- I usually ride with a slight drop between the seat and handlebar, but sometimes I'll move the bars up to make it more level
- 700c wheels with tires that are around 37 mm wide
- flat bar with bar ends (ergon GP5 grips)
- 170 mm cranks
- 122.5 mm bottom bracket spindle (not sure if this even matters)
Quoted: 6193 Post(s)
Liked 4,809 Times
Wear shoes with stiffer soles. Flip flops are a no-no.
Likes For Iride01:
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
The first thing I'd try would be clipless pedals and stiff cycling shoes, don't have to be expensive. Clipless allows you to put force on the pedals almost all the way around the circle: push forward at the top, just a little pressure on the way down, pull back at the bottom and about 20° up the backstroke. That vastly reduces the pressure on the pedals, in fact it's entirely possible to pedal just using the shoe uppers (with a lot of practice).
Results matter
Results matter
OTOH, I got hot spots with SPD pedals. Five Ten used to make shoes which could be used as stiff-ish flat shoes or as SPD shoes, but I just checked and they just list flat shoes, perhaps the Pearl Izumi X-Alp Launch SPD.
Liked 4,809 Times
I guess a question you might clear up. After what time or distance on the bike does your foot or feet bother you?
My feet swell a very little bit after 35 - 45 miles. Mostly I feel it in the ball of my foot. I used to think hydration was the key, but maybe only a part. What seems to help the most though is wearing socks that give my feet a little bit of compression. Also thin enough to leave room in the toe box of the shoe and not compete with the cushioning built into the shoe.
Scrubby duff
I have x-alp. very good shoes. check your fit first. they accommodate wide feet too(a tad)
